Starting issue - please see video
Raggadubz
PostPosted: 13:38 - 25 Jul 2013    Post subject: Starting issue - please see video Reply with quote
Hello,
Please have a look at the video. Any idea what might be wrong and how to fix it?
Cheers!
Honda CB125 TDE
DB50QT-11 Scooter
Nick 50
PostPosted: 15:06 - 25 Jul 2013    Post subject: Reply with quote
What is the make and model of the bike out of interest?
Raggadubz
PostPosted: 22:29 - 26 Jul 2013    Post subject: Reply with quote
Honda CB125 TDE Superdream
Honda CB125 TDE
DB50QT-11 Scooter
gregtaylor
PostPosted: 23:13 - 26 Jul 2013    Post subject: Not starting Reply with quote
It looks like the starter clutch is doing the business as the clutch basket is spinning some of the time. I had a similar problem with my CB250N when it would just not fire. I tried everything including new starter motor. Battery seemed fine but when I stress tested it (gave it some load off the bike) the voltage quickly dropped to under 10V which is just not enough to fire it up (though was enough to spin the starter). Can you try a spare battery? If the battery is the cause then check the rectifier (I don't think your model has a regulator/rectifier, just a diode bridge on a heatsink) as if that is failing then the battery is being overcharged which will have caused the plates to buckle.
Incidentally, I always check with a larger, fully charged, battery as you then know it has plenty of power in it. Just balance it on something close enough to get the connections to reach.
Greg
The last post was made 13 years, 78 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.35 - MySQL Queries: 13 - Page Size: 38.86 Kb
