| Wonko The Sane |
 Wonko The Sane World Chat Champion
| MarJay |
 MarJay But it's British!
| Wonko The Sane |
| lihp |
 lihp World Chat Champion
| Wonko The Sane |
| MarkJ |
 MarkJ World Chat Champion
| Timmeh |
 Timmeh World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 14:55 - 26 Jul 2013 Post subject: |
| Timmeh wrote: | Indeed; the drive train is significantly more complicated. |
How so? Two pulleys and a belt = two sprockets and a chain.
Alignment? Oh noes, might have to drop a washer or two in to square it up.
The belt drive on my GPz305 was really rather good. Clean, quiet, no lash. And (reportedly) it's a straight conversion from pulley/belt to sprocket/chain if you feel so inclined.
I'm rather disappoint that BMW pussied out and went chain for the F800/650GS, presumably because of the silly offroad / round the world pretensions. I'd have another belt in an instant. ____________________ Biking is 1/20th as dangerous as horse riding.
| G |
 G The Voice of Reason
 Posted: 14:59 - 26 Jul 2013 Post subject: |
You could have just got the 'sensible' F800S, with the belt.
But not nearly as pretentious, of course .
If that weren't so damned expensive, I'd quite fancy one myself.
But as it goes, a TRX850 seems to be pretty similar and while it may drink more petrol and oil, will be pretty immune to depreciation.
Anyway - for the op - get a decent chain oiler. Sorted.
I always kinda fancied making an enclosed drive train like some small hondas and the like had. |
| MarJay |
| Wave2k |
 Wave2k G's Stalker
| lihp |
| Islander |
 Islander World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 15:48 - 26 Jul 2013 Post subject: |
| MarJay wrote: | Not just horizontal alignment, but directional alignment, hence belt drive bikes have no adjusters at the end of the swinging arm. |
Tensioners? GPz305 did. F800S/T does.
There's a analysis/discussion of the downsides of belts here, but the counterpoint to that is that some manufacturers do fit belts, and on beefy machinery, so it's not impossible wizardry.
Not a huge deal, but I'd like belt drive on a keeper bike. ____________________ Biking is 1/20th as dangerous as horse riding.
 Posted: 15:49 - 26 Jul 2013 Post subject: |
The belt drive on a GPz305 works in exactly the same way as a chain drive, just with belt and pulleys instead of chain and sprockets. It was really good. Best bit of the bike. No adjustment, no messing about with lube. Just a wee scribble with a pencil on the pulley if it started squeaking.
It's tensioned and aligned in exactly the same way as a chain using locknut adjusters on the end of the swingarm. No jockeywheels or messing about with sprung tensioners.
Doesn't have to be comlicated, it's just been made complicated by ze Germans and buell make a policy of not doing things like everyone else.
The difficulty would be in sourcing pulleys that fit and a sufficiently good quality belt. People used to use non-standard belts on the 305s and they snapped in short order. The OEM ones last for ages (I think you are supposed to change it after 20k miles).
They generally use a larger pulleys than sprockets to increase the friction and reduce bending. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Rogerborg |
 Rogerborg nimbA
 Posted: 15:54 - 26 Jul 2013 Post subject: |
Aside, the chap who bought my GPz305 had done his homework and asked all the right questions about the usual suspect bits.
Turns out he works for an engineering firm and can source industrial belts for tank-of-fuel money, so that was his area of least concern.
There's no particular reason why belts need to be expensive except that they're (now) used on relatively snooty bikes and there's little retail competition for the OEM parts. ____________________ Biking is 1/20th as dangerous as horse riding.
| C1REX |
 C1REX Traffic Copper
| MarJay |
| Mr_T |
 Mr_T Two Stroke Sniffer
| gavbriggs |
 gavbriggs Crazy Courier
| c-m |
 c-m World Chat Champion
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 17:34 - 26 Jul 2013 Post subject: |
Apparently not.
https://dl.dropboxusercontent.com/u/3526686/3.jpg ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
| Teflon-Mike |
 Posted: 18:34 - 26 Jul 2013 Post subject: |
| Black Sheep wrote: | How come more bikes aren't built belt drive? |
Considering that the majority of two-wheeled registrations, even in this country are light-weight machines, of which I think something like over 2/3 ore scooters.... and it's the 'convention' on a scooter to have a belt drive, rather than anything else....
The 'popularity' of belt drive is probably a lot higher than you think; and quite possibly based on number of models or machines made, likely to be higher than that of chain drive 'bikes'!
Main thing about a belt is tension, or more specifically changing tension.
They may be toothed to aid the grip they have on the pulleys, but essentially they are transmitting drive through friction, hence you get a larger power loss than with a chain, as they have to have extra friction to grip the pulleys, but then, you also have to keep the tension very very controlled.
When you have rear suspension, unless you have the the out-put sprocket / pulley 'co-incident' with the swing-arm spindle, as the swing arm moves through its arc of travel, the distances between the sprokets changes, depending on where the out-put sprocket is in relation to the swing arm spindle...
When the swing-arm spindle, gearbox shaft and wheel axle are all aligned, then the maximum distance around the sprockets is seen. As the swing arm drops beneath that or compresses above it, so the distance between the sprockets gets less and the chain goes slack.
Of course, most scooters don't have this problem; the engine is 'sprung', moving with the swing arm, the tension held constant regardless.
So on a bike, belts only work well, if they are designed so that the out-put pulley is almost co-incident with the swing arm spindle, and or the suspension has only a limited travel / change of tension.
More the tension change due to suspension travel, more slack there has to be in the bottom run to allow it.. more slack means less tension means less grip, means less power transmission is possible.
Its a less 'robust' design solution... cost, performance, weight, efficiency, they are all just part of the design compromise, and belt technology is simply not robust enough to work and work well in so many situations ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
 Posted: 19:51 - 26 Jul 2013 Post subject: |
Many years ago someone did try a belt drive bike in the 250cc GP series, but not sure they got anywhere with it (but plenty of other factors could affect that).
Down sides are bulk, cost, slightly greater power loss and tendency to fail without warning.
Plus points less maintenance, quieter and less likely to fail causing damage to the engine.
| Ariel Badger |
 Ariel Badger Super Spammer
The last post was made 13 years, 16 days ago. Instead of replying here, would creating a new thread be more useful? |
