Indicators on my suzuki RF600
jackieflan00
PostPosted: 13:06 - 27 Jul 2013    Post subject: Indicators on my suzuki RF600 Reply with quote
hi,
i recently purchased a 1994 suzuki rf600, i took the rear indicators off the bike as they were corroded and rusted, and i want to replace them with some LED indicators.
i bought some 16LED indicators from ebay that i have tested with a power supply and they work, however when i connect them to the bike they don't light up at all, the front indicators light up as normal (flashing faster as they would if a bulb had gone).
i couldn't find any help online as people usually have the flashing problem when they flash too fast as apposed to not atall.
i also cant find a decent wiring diagram of the bike that isnt all blurey.
im new to the whole forum thing so any help would be greatly appreciated
thanks
Jackieflan00
jjdugen
PostPosted: 13:25 - 27 Jul 2013    Post subject: Reply with quote
usually reversing the connections works. LEDs are diodes, current only flows in one direction. You will probably find that your flash rate will still be too high as the LED's are a much lower resistance than the bulbs you had originally. Try hooking a 20Watt 20 /25 ohm resister across the two leads, this usually balanced the load. (Or just get a solid state flasher relay, fit and forget).
Timmeh
PostPosted: 15:18 - 27 Jul 2013    Post subject: Reply with quote
the resistor needs to be in series, not parallel duder.
jjdugen
PostPosted: 06:01 - 28 Jul 2013    Post subject: Reply with quote
Its much of a muchness where you put the resistor. I put it in parallel with the LED unit to replicate the bulb filament. Just as long as the flasher unit is seeing a load it will work.
(Having re-read my post, I should clarify, the resistor goes across, (or in line) with the two leads going to each individual indicator unit).
Kuz66
PostPosted: 19:44 - 07 Jan 2014    Post subject: Reply with quote
Jackie,
I have a 95 RF600 R and I am trying to do the same thing, and I was wondering if you found anything that works or if the resistor worked?
nowhere.elysium
The Pork Lord
PostPosted: 19:49 - 07 Jan 2014    Post subject: Reply with quote
LED indicators are crap anyway, so just stick with incandescents.
Kuz66
PostPosted: 21:36 - 07 Jan 2014    Post subject: Reply with quote
the problem is, that I already paid for the led ones, and with the modification I had to do i had to go with the smaller base turn signals anyway. I'm just not sure what resistors to buy or where to get them.
TheCatSatOnTh...
PostPosted: 21:41 - 07 Jan 2014    Post subject: Reply with quote
Search eBay for "motorcycle led resistors" and you should find appropriate items.
Islander
PostPosted: 21:58 - 07 Jan 2014    Post subject: Reply with quote
Parallel. You're trying to increase the current draw so that the electromechanical relay works correctly. Thumbs Up
The simplest solution and the most energy effective is to fit an electronic flasher relay. They don't have a load dependent flash rate.
The last post was made 12 years, 315 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.15 - MySQL Queries: 13 - Page Size: 59.36 Kb
