Beams strong enough?
Paris2
PostPosted: 19:21 - 30 Jul 2013    Post subject: Beams strong enough? Reply with quote
How strong are thee beams?
https://i138.photobucket.com/albums/q276/parsalanpark/image-15.jpg
They are obviously supporting the roof of the garage, but Cathay bear much weight themselves. I want to hang a punch bag from them, probably weighing around 40-50kg. Is this a bad idea or should they hold up fine?
Cheeaaaaaaaaars
Current Ride: Daytona 600
fatpies
PostPosted: 19:28 - 30 Jul 2013    Post subject: Reply with quote
They should hold up fine. If you're paranoid don't hang it from one beam, put a beam across those beams and hang it from those beams to spread out the weight.
If you're even more paranoid put two beams up to spread the weight even more.
metalangel
PostPosted: 19:33 - 30 Jul 2013    Post subject: Reply with quote
But will those beams be strong enough?
Al
PostPosted: 19:41 - 30 Jul 2013    Post subject: Reply with quote
I've climbed on those sort of trusses loads of times. I think they'd take the weight but the movement of the bag swinging about might cause an issue.
I'm not sure how strong those metal joins are either?
I'd probably brace the beams overlapping the bit where the joins are with some more wood and then use a fence post or scaffold bar laid across the beams the other way to hang the bag from.
Yamaha FZR400RR 3tj
My Instagram Thingy
Paris2
PostPosted: 20:33 - 30 Jul 2013    Post subject: Reply with quote
That's what I'm worried about, the movement of the bag. If it is bashed around too much (which it should be) it may cause problems. Ill see if I can distribute the weight more and add some support in there. I obviously don't want to damage the roof supports, as the roof may come down Laughing
Fisty
PostPosted: 21:03 - 30 Jul 2013    Post subject: Re: Beams strong enough? Reply with quote
Cheeaaaaaaaaars
Hmmmmm you been chatting to Krad? You sure thats a bag you want to hang?
Fatter and faster than Fret
T0MMY
PostPosted: 22:23 - 30 Jul 2013    Post subject: Reply with quote
We had a punchbag hanging in our garage with beams exactly the same as that. The beams can take it but it shook the whole roof when you punched it so I wouldn't really advise it. I think sooner or later it would damage it.
ZX6R + CBR600RR
Ariel Badger
PostPosted: 22:37 - 30 Jul 2013    Post subject: Reply with quote
Those beams are designed to take a static load under compression not a moving load under tension.
PostPosted: 22:43 - 30 Jul 2013    Post subject: Reply with quote
https://rogerborg.dnsd.me/kirk-phaser.jpg
Scanners say... outwith design specifications.
angryjonny
PostPosted: 22:53 - 30 Jul 2013    Post subject: Reply with quote
Looks a lot like the construction of my garage. I've boarded it out to use as a loft and got probably a couple of hundred kilos of stuff up there. No probs so far.
If you're fussed about movement, run a beam over the top of a few rafters up to the end-wall and fix it to the wall with angle brackets. Worst case scenario is you crack a hole in the wall, in which case you'll not be too fussed about your roof.
binge
Emo Kiddy
PostPosted: 22:54 - 30 Jul 2013    Post subject: Reply with quote
I lifted an F7P Renault Clio 1.8 16v engine from the beams in my garage using a lorry ratchet strap.
Creaked a bit, but lifted the engine up high enough for me to mount it on the engine stand I have.
BTTD
PostPosted: 22:55 - 30 Jul 2013    Post subject: Reply with quote
Run a couple of 6" beams in parrallel to the trusses and use them to hang the bag? That way the bag isn't moving the roof.
If it was my garage I'd tempted to cost out running thicker beams all over alongside those trusses and have a big ol loft space. Accepted the trusses would get in the way a bit when up there, but still a lot of storage space.
swampy
PostPosted: 23:02 - 30 Jul 2013    Post subject: Reply with quote
You sure its only a punch bag you want to hang from there...
https://www.bikechatforums.com/viewtopic.php?t=276185
Shocked
kestrel
PostPosted: 23:08 - 30 Jul 2013    Post subject: Reply with quote
All of the members in a triangulated truss are designed to be either in tension or compression, they are not designed to support point loadings or bending moments.
Could you bolt a suitable hanging bracket to the block wall?
Isle of Man.........Road Racing Capital Of The World
Paris2
PostPosted: 23:20 - 30 Jul 2013    Post subject: Reply with quote
I'll look into some extra wall support I think, though the beams are pretty strong.
And yes swampy, it's for a punch bag. I no longer have a motorbike in there so am turning the garage into a mini gym. (Though I am super sad about not having a bike anymore Sad )
swampy
PostPosted: 23:22 - 30 Jul 2013    Post subject: Reply with quote
Where's the bike dude ?
Paris2
PostPosted: 23:32 - 30 Jul 2013    Post subject: Reply with quote
Gone. Had to sell as I now need a car for work and can't afford both. I'll hopefully be back on two wheels next year, even if it is another cheap old Suzuki Laughing
PostPosted: 00:57 - 31 Jul 2013    Post subject: Reply with quote
Structurally speaking. It would be best to hang it off the ridge beam, then it's all in compression, even if swinging.
This would probably result in altogether too much swing though.
mistergixer
PostPosted: 04:06 - 31 Jul 2013    Post subject: Reply with quote
Personally I'd go with a bracket bolted into the wall, bag won't swing as much either.
Space Monkey #7
cb1rocket
PostPosted: 07:58 - 31 Jul 2013    Post subject: Reply with quote
Hire a structural engineer
Im-a-Ridah
PostPosted: 11:12 - 31 Jul 2013    Post subject: Reply with quote
Or just hang it from the wall with a bracket! As for the beams, I don't really like the look of two bit of wood with a metal bracket on the side.
Can't afford bike, hire professional engineer? Shocked
pits
PostPosted: 11:52 - 31 Jul 2013    Post subject: Reply with quote
I think your best option would be to get a heavy duty metal plate with a ring welded into the centre of it, then fix it to the beam with some long M5 bolts Thumbs Up
BTTD
PostPosted: 12:18 - 31 Jul 2013    Post subject: Reply with quote
£20 to £30 for wall bracket (via a quick google), or about the same for a couple of 8" beams running the length of the garage (your builders merchant may vary a bit, but I'm estimating £3 a metre, 5 metre long garage).
Wall bracket is probably quicker to fit.
8" beams could also be used for pull ups, chain hoisting motorbikes etc....
map
Mr Calendar
PostPosted: 16:15 - 31 Jul 2013    Post subject: Reply with quote
jnw010 wrote:
£20 to £30 for wall bracket...the same for a couple of 8" beams running the length of the garage...8" beams could also be used for pull ups, chain hoisting motorbikes etc sex swing....
Just to make clear what you meant by etc Wink Very Happy
Sload
PostPosted: 08:59 - 01 Aug 2013    Post subject: Reply with quote
If you want it off the wall, you could run a long beam across the roof beams but affix one end to a wall or both ends preferably. The wall will keep it static and it should reduce excessive loading on the support beams as well as spreading the load out. Costs should be negligable.
Honda Varadero >> Triumph Speed Four >> Honda CBR1100xx
The last post was made 12 years, 253 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 127.93 Kb
