| ltiro |
 ltiro Derestricted Danger
| Eddie Hitler |
 Eddie Hitler World Chat Champion
| SQL |
 SQL World Chat Champion
 Posted: 21:12 - 07 Aug 2013 Post subject: |
If you are going to do it wear it on the outside and wear an MX helmet
I would only imagine it being bloody uncomfortable and likely to cause impact fractures on you if crashed. |
| -Matt- |
 -Matt- World Chat Champion
 Posted: 21:15 - 07 Aug 2013 Post subject: |
Why do you want armour if you already have it Or are you talking about a back/chest armour under a jacket with only armour in the arms for example? |
| ltiro |
| G |
 G The Voice of Reason
| STONEY! |
 STONEY! Brolly Dolly
| STONEY! |
| -Matt- |
 Posted: 21:29 - 07 Aug 2013 Post subject: |
Why arent you happy with the armour already in the trousers? Could you not upgrade it (i'll avoid a debate on ce levels again ) |
| G |
| ltiro |
| -Matt- |
 Posted: 21:45 - 07 Aug 2013 Post subject: |
The foam is probably more for fitting and comfort than anything else i would of thought if behind the armour, see plenty with no foam. Id just ask yourself why dont you see 'top of thd range' gear with multiple layers upon layers of armour someone must of decided its not a wise idea somewhere along the line.
Personally - i wear leathers with ce approved armour in knees elbows and shoulders. Back protector (seperate) and then armoured boots and gloves. |
| STONEY! |
| G |
 Posted: 21:50 - 07 Aug 2013 Post subject: |
That type of off road knee pads do tend to move around a bit.
You get some that don't so much, but they restrict your movement. Ideal for the injuries associated with dirt biking, less ideal for road riding.
As far as impact protection goes; armour can displace force across time and space. It can not remove it.
Imagine you have a bread stick.
You knock the bread stick against the edge of the table.
Do it lightly and it won't break at all.
Do it hard and it will break.
You put a paper napkin around your breadstick on the expected impact point and hit the table just harder than was needed to break it before.
Now it doesn't break because the impact is spread across a bigger space and instead of being an instant 'hit', it's taken a little longer for the force to be transferred, so there's less force per micro second.
Now, you hit the bread stick with napkin harder.
It breaks anyway because even though the napkin has spread the force, there's more than the bread stick canhandle.
You get another napkin'd bread stick and this time hit it lighter, but continue pushing down for a bit longer.
Again, it breaks; this time while there was less force, as it was sustained for longer, there was still enough to overcome the bread-stick.
Yes, your leg/arm is the bread stick.
Armour only protects against a fairly narrow range of impacts.
It may help reduce bruising a little in minor impacts; but I'm presuming you're not a girl (they're not usually quite this silly, or not silly in the same manner anyway ), so that's not an issue .
Armour does not protect against abrasion - at least that's not it's intention. Good quality leather does that.
By adding extra armour underneath existing stuff, you're also likely to get the outer layer moving around, which can lead to bunching up and wearing through quicker.
Some good points from Stoney - I've put loads of holes in the palms of gloves. Barely touched the armoured bits. Crashes road and track. |
| STONEY! |
| chris-red |
 Posted: 21:54 - 07 Aug 2013 Post subject: |
What OP wants.
https://www.grace-collection.com/images/AR008_White_Knight_Armor.JPG ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
WANTED:- Fujinon (Fuji) M42 (Screw on) lenses, let me know if you have anything. |
| STONEY! |
| ltiro |
| STONEY! |
| ltiro |
| STONEY! |
The last post was made 13 years, 100 days ago. Instead of replying here, would creating a new thread be more useful? |
