How did he lose that spring? - sidestand
map
Mr Calendar
PostPosted: 12:15 - 09 Aug 2013    Post subject: How did he lose that spring? - sidestand Reply with quote
Got a call from my lad.
He was riding along and the spring on the side stand (Varadero XL125V) decided it didn't like where it was and went off exploring the road.
My reaction was along the lines of WTF, how do you manage to destroy your bikes? The motorcycles Noah took on his ark still have their sidestand springs Shocked It's not a component I've seen fail*
So, any reason why it should fail and the easiest way to replace?
I'm interested in the failure as want to check it can't re-occur. FWIW his sidestand has always been a bit on the straight side so care is required when leaving the bike.
As always, thanks in anticipation Thumbs Up
* this is where BCF proves me wrong as it's a common occurrence and I should get out more Wink
Timmeh
PostPosted: 12:20 - 09 Aug 2013    Post subject: Reply with quote
Any part can suffer mechanical wear or sudden random failure. Just be thankful its the stand spring rather than the conrod.
However, by robbylogic it's prolly the battery, so check the reg/rec.
Aff
PostPosted: 12:21 - 09 Aug 2013    Post subject: Reply with quote
They are low down and get covered in road crap, if not cleaned they will rust and snap.
I have had 2 do this.
Electric Bike Project
map
Mr Calendar
PostPosted: 12:52 - 09 Aug 2013    Post subject: Reply with quote
Aff wrote:
They are low down and get covered in road crap, if not cleaned they will rust and snap....
Which is why I tend to cover bits like this in oil. Not your namby pamby WD-40 spray oil either. We're talking proper oil out of an oiler can. I'm sure it's the sort of item that's covered in the history books and museums for the younger members of the forum (see clicky link in last sentence). Which is probably why my lad is a stranger to using it Very Happy
-Matt-
PostPosted: 15:01 - 09 Aug 2013    Post subject: Reply with quote
Think its time i'd best go clean my sidestand Embarassed and the 3 years muck on it
Ariel Badger
PostPosted: 21:05 - 09 Aug 2013    Post subject: Reply with quote
This is why the ACU say that stands must be wired up in competition.
map
Mr Calendar
PostPosted: 22:46 - 09 Aug 2013    Post subject: Reply with quote
For competition machines I'd always assumed they'd be removed.
What happens for a run/ride what ya brung track day though?
Also any tips on putting this type of spring back on would be helpful. Ta Thumbs Up
Ariel Badger
PostPosted: 22:51 - 09 Aug 2013    Post subject: Reply with quote
Competition bikes have no stands but there are RWYB classes in Sprint and Hillclimb and the rules state wireing up.
Ariel Badger
PostPosted: 22:58 - 09 Aug 2013    Post subject: Reply with quote
To put it back on you need a lot of 1p coins. Hold the spring in a vice and with a friend helping bend the spring to open it and slot the coins between the coils, then bend it the otherway and do the same. Fit spring and pull coins out with pliers.
Do not do what I did last week and try and use mole grips to fit the spring because you are too lazy to do it properly. This will result in a bump on the head and blood in the eye from headbutting the kickstart when the grips slip.
ian505050
PostPosted: 01:12 - 10 Aug 2013    Post subject: Reply with quote
had an sv650 once and it jumped off while riding
serlant
PostPosted: 11:40 - 10 Aug 2013    Post subject: Reply with quote
spring came off my husky stand while riding when i hit a large pothole. so to stretch the spring around I just used a
https://www.keyring.com/images/categories/92900_Split_Key_Ring.jpg from my keys and put my finger in it to pull it over the hook, then when done you can just split it then unwind it. easy to do while out and about.
04 CBR1000RR, 1995 Husqvarna TE410, 1998 VTR1000(Sold), 1990 XJ600(sold), 1996 KH125(dead and sold)
PostPosted: 13:56 - 10 Aug 2013    Post subject: Reply with quote
The sidestand bolt on my Buell failed, leaving the sidestand, the spring and the spring stop in the street. As I then could not leave the bike I had to get an old man to pick it up for me.
Mysteriously the replacement bolt was of a different design to the one originally installed on my bike... Thinking
Bomberman
PostPosted: 17:40 - 11 Aug 2013    Post subject: Reply with quote
I lost one off the centre stand on my GPZ once - the actual stand bar that it hooks on had rusted away Shocked Bastard scary when it happened, the stand made a hell of a racket being dragged down the road!
There is a gap of 346 days between these two posts...
Skyblue
PostPosted: 21:42 - 23 Jul 2014    Post subject: Reply with quote
Mine came off earlier today & did i struggle getting the spring back on in the heat. i'm grateful of the information about getting the spring back on without proper tools.
mentalboy
PostPosted: 02:57 - 24 Jul 2014    Post subject: Reply with quote
Where's the 'classic' rating when you need it??
(Don't you just hate it when you rate a post and then see that it's ancient! Rolling Eyes )
Make mine a Corona.
Nexus Icon
PostPosted: 13:57 - 24 Jul 2014    Post subject: Reply with quote
It's baffling when you go to rate a post (that turns out to be ancient) only to find you've already rated it but don't recall ever reading it before.
Or worse, when you read a resurrected thread and find one of your own posts that you don't even recognise.
Greetings from Shitsville!
The Artist
PostPosted: 14:32 - 24 Jul 2014    Post subject: Reply with quote
A true engineers mind. Thumbs Up
The last post was made 12 years, 84 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 100.09 Kb
