Double disc on the back?
Yoyo This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
Timmeh
PostPosted: 13:20 - 09 Aug 2013    Post subject: Reply with quote
I suspect that it may down to be clearance issues. Any horizontal movement of the chain and rear spindle would cause it to strike the disc with disastrous results.
A shaftie, on the other hand, is a different story.
bikertomm
I guess in a lot of cases it's not necessary, you don't want to be locking up the back with ease, also.. the sprockets are usually in the way..
pdg
PostPosted: 13:29 - 09 Aug 2013    Post subject: Reply with quote
If I read it correctly he was implying that it would be possible to use the sprocket as a brake disc....
Obviously it would work perfectly, and the chain oil would stop any brake squealing.
fatpies
PostPosted: 13:43 - 09 Aug 2013    Post subject: Reply with quote
before putting in a whole extra disc and calliper.
They could just improve the calliper which is on there already, more pots, opposing pots, larger surface area and even bigger disc.
fatpies
PostPosted: 13:45 - 09 Aug 2013    Post subject: Reply with quote
Or a VFR400/800 those seem to fit the brake disc on the same side as the sprocket and chain.
DrDonnyBrago
PostPosted: 13:46 - 09 Aug 2013    Post subject: Reply with quote
You can lock the rear wheel on a high performance motorcycle at pretty much any speed with a single small disc and a single pot floating caliper, why would you want/need to make it more powerful?
That said, some stunters will have a second brake caliper on the rear disc and some faggy Yank chopper things do use the sprocket as a brake disc, I can only assume they don't oil their chains.
https://www.hoheydesigns.com/store/images/honda/F4i%202%20big-rotor-brembo.jpg
https://static.ddmcdn.com/gif/suicide-softail-chopper-profile-6.jpg
-Matt-
PostPosted: 13:49 - 09 Aug 2013    Post subject: Reply with quote
Never seen a caliper on a sprocket like that before Laughing looks like a recipe for disaster Shocked
RhynoCZ
PostPosted: 13:51 - 09 Aug 2013    Post subject: Reply with quote
Can you block the wheel with single disc brake? - Yes, you can.
Look at 70's and 80's bikes, there were way bigger discs on the rear wheel. Today, when most of your weight is above your front wheel, it'd be quite stupid to keep that ''powerful'' brake on the back.
Case closed Thumbs Up
Timmeh
PostPosted: 13:52 - 09 Aug 2013    Post subject: Reply with quote
Single-sided swinger so different story. Also there's a huge gap between the two, with the disc actually being down the centreline of the bike.
RhynoCZ
PostPosted: 13:53 - 09 Aug 2013    Post subject: Reply with quote
DrDonnyBrago wrote:
Let me guess, 'murican design? The heat from braking is going to drastically reduce durability of the sprocket. And 'muricans use only their rear brakes.
DrDonnyBrago
PostPosted: 13:54 - 09 Aug 2013    Post subject: Reply with quote
RhynoCZ wrote:
DrDonnyBrago wrote:
Let me guess, 'murican design? The heat from braking is going to drastically reduce durability of the sprocket. And 'muricans use only their rear brake.
Form over function - check
Still ugly - check
Terrifyingly stupid - check
Yep, it's Merkin made.
RhynoCZ
PostPosted: 13:57 - 09 Aug 2013    Post subject: Reply with quote
Have you seen this: https://www.youtube.com/watch?v=4ED8BfPtaTw ?
I think that'd be the source of OP's idea Thinking
Timmeh
PostPosted: 14:01 - 09 Aug 2013    Post subject: Reply with quote
Dudes need their head examining to think that's a good idea, lol
edit; and check the brake line routing... down, over and then under the chain. Bad shit's gonna happen if you let that go slack. Assuming you live long enough for it to go slack, that is.
DrSnoosnoo
PostPosted: 14:12 - 09 Aug 2013    Post subject: Reply with quote
How do these Mercans survive on a "sports" bike if they don't use their front brakes? I mean, damn!
Do they get their licence from collecting tokens from their corn flakes?
Im-a-Ridah
PostPosted: 14:15 - 09 Aug 2013    Post subject: Reply with quote
The best way to slow down quicker is bigger tyres. It's the grip between the tyre contact patch and the road that is going to let go soonest. Obviously Mark doesn't need brakes, he just crashes into the nearest wall at max speed, then walks off uninjured.
PostPosted: 14:30 - 09 Aug 2013    Post subject: Reply with quote
Err... Because the geometry of a motorcycle means that the rear brake is much more likely to lock up than the front?
Jeez Warped, you get dumber by the day.
bikertomm
PostPosted: 14:47 - 09 Aug 2013    Post subject: Reply with quote
Mark Roberts wrote:
Saying about locking up is pretty much the same as saying why put 2 on the front. You can flip a bike that only has one disc on the front. So not really that stupid.
Well, no.
PostPosted: 14:51 - 09 Aug 2013    Post subject: Reply with quote
Yes but when you flip the bike is the wheel locked? No. Are you under control of the bike until you pass the balance point? Yes.
When the wheel is locked are you in control of the bike? No.
Teflon-Mike
tl;dr
PostPosted: 15:02 - 09 Aug 2013    Post subject: Reply with quote
Why have a disc on the back wheel at all?
It's just extra unsprung mass.
Why not, put the brake on the gear-box out-put shaft?
Where, spinning about 3x as fast, it has 3x the mechanical advantage over the rear wheel; & is therefore more powerful and less 'grabby' providing much more 'feel'....
There is an answer to this one....
Any-one know what it is?
Can any-one else site examples of machines fitted with out-put shaft brakes?
And following on from that idea; what about epicyclic front brakes?
The floating disc, running on an epicyclic gear, at potentially 3, 5 or even 10X wheel speed. Even greater mechanical advantage over the wheel, means that the brake can be made smaller, hence lighter to do the same job, while at the same time offering greater braking feel.
There is also another pottential influence of geared front rotors; rotating at much higher speed, the gyroscopic effect of the brake rotor is amplified.
This opens up myriad possibilities over the dynamics of the machine. A high speed rotor, at lower speeds would not amplify the gyroscopic inertia so profoundly, so the machine could use quite 'unstable' geometry for low speed handling, the rotors effect increasing with speed, providing a much higher degree of stability at high speeds.
But conversely... the rotor could contra-rotate.... turn backwards compared to the wheel.... NOW the rotor's gyroscopic effect would be countering that of the wheel; this would mean that the geometry could be made 'naturally' more stable for slow speeds, but as speeds increase, the rotor would more effectively counteract the wheel's gyroscopic tendancies, such that the steering would not become so heavy and the bike would be much more eager to lean and turn....
Why don't bikes use these kind of technologies?
PostPosted: 15:11 - 09 Aug 2013    Post subject: Reply with quote
I thought about this and I guess it makes it possible to snap the chain using only the rear brake.
DrDonnyBrago
PostPosted: 15:38 - 09 Aug 2013    Post subject: Reply with quote
It's not just overall braking force though, you also need to consider heat dissipation. Not really an issue for the rear brake.
karoshi
PostPosted: 15:48 - 09 Aug 2013    Post subject: Reply with quote
Landrovers.. Series vehicles and 110s definitely, mid year defenders up to the puma model, classic range rovers too. all have hand-brake systems running off the rear prop-shaft.
Jags up to the 90s had inboard rear brake systems before the half shafts rather than on the hubs, also the Tesla Roadster and some old Alfas from memory?
Well, I've wrestled with reality for 35 years, Doctor, and I'm happy to state I finally won out over it. - Elwood P. Dowd
The last post was made 13 years, 97 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 134.83 Kb
