| Yoyo |
 Yoyo Brolly Dolly
| Timmeh |
 Timmeh World Chat Champion
| bikertomm |
 bikertomm World Chat Champion
 Posted: 14:20 - 09 Aug 2013 Post subject: |
I guess in a lot of cases it's not necessary, you don't want to be locking up the back with ease, also.. the sprockets are usually in the way..
 ____________________ 07' Honda Hornet now full powaah! My guide on performing an oil change! |
| Pol Anorl |
 Pol Anorl Banned
 Posted: 14:23 - 09 Aug 2013 Post subject: |
Just stick your face in the back wheel. Job done. ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
20:30:37 Pyro.: I don't sort of like men, I take every advantage to choke on dick.
Jewlio Iglesias: You live in Liverpool - Chances are, the front door has already been kicked off the hinges |
| pdg |
 pdg World Chat Champion
| fatpies |
 fatpies World Chat Champion
| fatpies |
| DrDonnyBrago |
| -Matt- |
 -Matt- World Chat Champion
 Posted: 14:49 - 09 Aug 2013 Post subject: |
Never seen a caliper on a sprocket like that before looks like a recipe for disaster  |
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 14:51 - 09 Aug 2013 Post subject: |
Can you block the wheel with single disc brake? - Yes, you can.
Look at 70's and 80's bikes, there were way bigger discs on the rear wheel. Today, when most of your weight is above your front wheel, it'd be quite stupid to keep that ''powerful'' brake on the back.
Case closed  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| Timmeh |
| RhynoCZ |
 Posted: 14:53 - 09 Aug 2013 Post subject: |
Let me guess, 'murican design? The heat from braking is going to drastically reduce durability of the sprocket. And 'muricans use only their rear brakes. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| DrDonnyBrago |
 Posted: 14:54 - 09 Aug 2013 Post subject: |
| RhynoCZ wrote: |
Let me guess, 'murican design? The heat from braking is going to drastically reduce durability of the sprocket. And 'muricans use only their rear brake. |
Form over function - check
Still ugly - check
Terrifyingly stupid - check
Yep, it's Merkin made. |
| RhynoCZ |
 Posted: 14:57 - 09 Aug 2013 Post subject: |
Have you seen this: https://www.youtube.com/watch?v=4ED8BfPtaTw ?
I think that'd be the source of OP's idea  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| Timmeh |
| DrSnoosnoo |
 DrSnoosnoo World Chat Champion
| Im-a-Ridah |
 Im-a-Ridah World Chat Champion
| MarJay |
 MarJay But it's British!
| Yoyo |
 Yoyo Brolly Dolly
| bikertomm |
| MarJay |
| Teflon-Mike |
 Posted: 16:02 - 09 Aug 2013 Post subject: |
Why have a disc on the back wheel at all?
It's just extra unsprung mass.
Why not, put the brake on the gear-box out-put shaft?
Where, spinning about 3x as fast, it has 3x the mechanical advantage over the rear wheel; & is therefore more powerful and less 'grabby' providing much more 'feel'....
There is an answer to this one....
Any-one know what it is?
Can any-one else site examples of machines fitted with out-put shaft brakes?
And following on from that idea; what about epicyclic front brakes?
The floating disc, running on an epicyclic gear, at potentially 3, 5 or even 10X wheel speed. Even greater mechanical advantage over the wheel, means that the brake can be made smaller, hence lighter to do the same job, while at the same time offering greater braking feel.
There is also another pottential influence of geared front rotors; rotating at much higher speed, the gyroscopic effect of the brake rotor is amplified.
This opens up myriad possibilities over the dynamics of the machine. A high speed rotor, at lower speeds would not amplify the gyroscopic inertia so profoundly, so the machine could use quite 'unstable' geometry for low speed handling, the rotors effect increasing with speed, providing a much higher degree of stability at high speeds.
But conversely... the rotor could contra-rotate.... turn backwards compared to the wheel.... NOW the rotor's gyroscopic effect would be countering that of the wheel; this would mean that the geometry could be made 'naturally' more stable for slow speeds, but as speeds increase, the rotor would more effectively counteract the wheel's gyroscopic tendancies, such that the steering would not become so heavy and the bike would be much more eager to lean and turn....
Why don't bikes use these kind of technologies? ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| MarJay |
| DrDonnyBrago |
| karoshi |
 karoshi Brolly Dolly
The last post was made 12 years, 322 days ago. Instead of replying here, would creating a new thread be more useful? |
