Weird line in both tyres
Clutchy
PostPosted: 18:22 - 14 Aug 2013    Post subject: Weird line in both tyres Reply with quote
Got a good feeling I'm going to make a big nob of myself here but here goes.
There's a large line gouged into both tyres which goes all the way round and is exactly the same on the front tyre... No idea how it could be like this as the front and the back have the line in the exact same place.
My suspicious are that its a wear indicator like when it disappears you should change.
Two reason I don't think it is this is because it used to be a lot deeper than it is, but even if the line fully disappeared I still currently have loads of tread left.
The other reason is that the line is off centre.
So... Any idea? Need to zoom in on pics.
https://i.imgur.com/VoCz4JD.jpg[/img]
And the front tyre:
https://i.imgur.com/IJkX4cY.jpg
Fowlersrs
PostPosted: 18:28 - 14 Aug 2013    Post subject: Reply with quote
That's weird, I thought u where gonna put the classic compound edges up bit that's deffo not that. Bit of an off wear indicator if u ask me, it goes all wiggly for a start!! Is there much of a groove in the tyre when u run your hand over it or is it just colour difference?
What brand of tyre?
caragh
PostPosted: 18:39 - 14 Aug 2013    Post subject: Reply with quote
It's the anti static strip nothing to worry about.
regards
Steve
Triumph Tiger 800 XR
Acemastr
PostPosted: 18:40 - 14 Aug 2013    Post subject: Reply with quote
It's an antistatic line.
It is, trust me Smile
2016 Toyota Tacoma Limited
Clutchy
PostPosted: 18:41 - 14 Aug 2013    Post subject: Reply with quote
They're bridgestones forgot the model, will post later.
The grooves been there since I bought the bike as far as I know, about a thousand miles ago it was probably 1.5mm deep, its now around .5mm deep.
Very strange
Tungtvann
PostPosted: 18:45 - 14 Aug 2013    Post subject: Reply with quote
Seen that on my mate's bike, always wondered what that was.
sidewinder
PostPosted: 18:49 - 14 Aug 2013    Post subject: Reply with quote
Looks like a join from the molding process
Radis
PostPosted: 18:51 - 14 Aug 2013    Post subject: Reply with quote
https://www.bikechatforums.com/viewtopic.php?t=228311
PhilDawson8270 wrote:
Just got a reply from Michelin.
We would advise that it could be the “Anti Static Strip” explained as follows:-
When a Motorcycle is in use there is a build up of static within the machine. It is necessary to ensure that this is dispersed during usage. In order to facilitate this, there is a carbon black strip built into the tyre during manufacture. This strip is moulded into the tyre before curing using carbon as this is a good conductor of static electricity. This strip is practically invisible on a new tyre, but can appear as the tyre wears, especially if the usage of the motorcycle is not high. There is no detrimental effect on the performance of the tyre either before, during or after this strip has become apparent. The positioning of this strip is slightly “off centre” and all around the circumference of the tyre.
Clutchy
PostPosted: 18:58 - 14 Aug 2013    Post subject: Reply with quote
Bingo, thank you very much.
c_dug
PostPosted: 22:17 - 14 Aug 2013    Post subject: Reply with quote
As above, it is particularly noticeable on BT023's for some reason.
andym
PostPosted: 00:11 - 15 Aug 2013    Post subject: Reply with quote
Interesting thread, I have a similar line on my front tyre and wondered what it was, it had started off as a yellow line but has worn down and is darker than the rest of the tyre.
At least I now know it's nothing to worry about
lihp
PostPosted: 14:56 - 15 Aug 2013    Post subject: Reply with quote
Brought back memories Laughing
Timmeh
PostPosted: 16:28 - 15 Aug 2013    Post subject: Reply with quote
offtopic, but...
Has anyone ever actually got a static shock off a bike? Granted, the tyres are rubber and hubs tend to be fairly good insulators as they are coated, so will develop a charge as they rotate. However this will dissipate fairly rapidly into the air as it has such a massive surface area. Reminds me of the 80s when people used to put those conductive rubber strips on the backs of their cars. Dad never put one on his, and I can't ever remember getting zapped either.
I know I haven't. Even yesterday which involved accelerating up to 60, stopping and touching the rear to check for brake binding as my new pads were a little tight.
Contrast that with spinning rotor blades that can develop a couple of hundred kV under the right conditions. When flying at night we'd sometimes see a faint blue glow coming from the edge of the disc, which is the corona discharge from the tips.
PostPosted: 18:10 - 15 Aug 2013    Post subject: Reply with quote
I went through a number of cars that were guaranteed to zap me - multiple Minis, XR2i, Rover 214, Astra, Orion and a Montego. Never put a strip on one though. Not had a shock since 1995 when I switched to a Peugeot 405 - mebbe car tyre manufacturers have put them in too since then?
The last post was made 13 years, 52 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 83.76 Kb
