Sediment in coolant tank?
mattd
PostPosted: 18:16 - 16 Aug 2013    Post subject: Sediment in coolant tank? Reply with quote
Hello chaps!
I went to see a 2004 B2H ZX6-R Ninja today, reasonably cheap at £2000 BUT!
Coolant level was low and the expansion tank has a good 0.5cms of brown sediment settling at the bottom.
Looks like very very fine sand.
What do you guys think? I was thinking maybe where the coolant has evaporated its caused some dissolved minerals etc to precepitate out?
Or maybe a sign of something more sinister?
Thanks Thumbs Up
Professional Hobo
-Matt-
PostPosted: 23:14 - 16 Aug 2013    Post subject: Reply with quote
https://www.kawiforums.com/2003-2004-zx-6r/91284-light-brown-much-coolant.html
It's casting sand.
Flush it out (which, if your bike is an 03 or 04 should be done NOW if it has never been) and it won't come back.
Ariel Badger
PostPosted: 23:39 - 16 Aug 2013    Post subject: Reply with quote
I seriously doubt it is casting sand..
1. sand would sink to the lowest point.
2. the Japanese die cast not sand cast.
Nemo
PostPosted: 00:57 - 17 Aug 2013    Post subject: Reply with quote
Rust?
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
Yoyo This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
Symon27
PostPosted: 16:12 - 17 Aug 2013    Post subject: Reply with quote
Could be radweld?
Honda Nsr 125 - Sold
Zxr 400 - Sold
Bandit 600 - Current (Y)
The other Paul Rudd
PostPosted: 16:26 - 17 Aug 2013    Post subject: Reply with quote
Nemo wrote:
Rust?
Pretty much. Someone has either used the incorrect coolant, the original stuff has never been changed, or someone has topped it up with tap water rather than distilled water.
The correct coolant with distilled water will prevent galvanic corrosion between the steel and aluminium parts in the motor. There aren't may steel parts but I'd guess it has some hard pipes for the coolant system that are steel.
gixerladsw
PostPosted: 16:44 - 17 Aug 2013    Post subject: Reply with quote
Could very well be K-seal fella. K-seal is a brilliant temporary coolant loss fix if the leak is small. I have used it a good few times. The down side is that it leaves a deposit exactly like you are mentioning.
Thing is I would take it that it still has the issue if the sludge is there. If someone had temporary used it as is meant, then part of the sorting out would be a flush with clean water and fresh coolant.
I would reckon the leak is still there and being held by the K-seal. So would either leave it or negotiate massively on the price.
I had an old landy I was running into the ground and used 2 bottles of K-seal to get me another 15,000 miles out of the engine. Had exactly what you described.
The last post was made 13 years, 88 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 56.63 Kb
