Cold Bloody Weather
freestyler_onli
PostPosted: 23:57 - 10 Dec 2004    Post subject: Cold Bloody Weather Reply with quote
How can you start your bike from cold if theres no power from the ignition switch??
It just makes some poofy noise then stops.
Git
PostPosted: 00:03 - 11 Dec 2004    Post subject: Reply with quote
Well if your batterys flat you can either recharge it, jump start the bike and go for a long ride to charge it up a bit or you could run up and down the road trying to bump it maybe in an attempt to get it running again but if the batterys that flat bumping it may not work. Thats assuming the battery is flat.
mchaggis
PostPosted: 01:25 - 11 Dec 2004    Post subject: Reply with quote
BTW, bump starting is where you put the bike into second gear, push it down the road until you're going near 10 mph, then slowly let the clutch out whilst still pushing. The wheels turn the engine over in place of the starter motor, so it works if the battery is flat. As soon as the engine catches, pull the clutch in, hop on and ride away.
Be careful though, and don't blame me if you drop the bike and break the plastics. Whistle
If it's cold, then you'll probably need some choke to get it started. Using the choke puts more petrol into the engine, so it's easier to start.
I must not be a troll...
Mmmm, Guinness
binge
Emo Kiddy
PostPosted: 01:27 - 11 Dec 2004    Post subject: Reply with quote
It may not work if the CDI unit/Immobiliser relies on the battery to work... Wink
<|Binge|>
Git
PostPosted: 01:38 - 11 Dec 2004    Post subject: Reply with quote
I know what bump starting is dude, some bikes will not start when you try and bump them if the battery is pretty flat, especially fuel injected bikes as they need a good 12v in the first place to get the things going.
mchaggis
PostPosted: 01:46 - 11 Dec 2004    Post subject: Reply with quote
It wasn't aimed at you, just you mentioned it and I thought I'd make it clearer.
Mmmm, Guinness
Git
PostPosted: 01:51 - 11 Dec 2004    Post subject: Reply with quote
And clearer you made it Smile
When I re read it I had a little feeling that it may not of been aimed at me, so, all's well with the world, apart from this machine that doesn't start.
freestyler_onli
PostPosted: 17:26 - 11 Dec 2004    Post subject: Reply with quote
Well i kept it in a warmish garage overnight so hopefully it should be ok-if not-ill look at the battery again. Cool
The last post was made 21 years, 273 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.32 - MySQL Queries: 13 - Page Size: 55.72 Kb
