USD Fork Dust Seal
lihp
PostPosted: 18:36 - 17 Aug 2013    Post subject: USD Fork Dust Seal Reply with quote
Ok guys,
Bit of advice here, I have been replacing the seals on my USD forks and after seating the bush, oil seal and retaining ring, I pushed the dust seal down. However, compress the fork and extend and the dust seal just stays in place on the fork stanchion.
Is it safe to use some kind of bonding agent with it? If so, any recommendations?
Or just go back to supplier with regards to the seal?
SQL
PostPosted: 18:46 - 17 Aug 2013    Post subject: Reply with quote
Missing the spring? or the clip?
PostPosted: 18:51 - 17 Aug 2013    Post subject: Reply with quote
The dust seal should press in quite firmly. If its sticking to the stanchion when you bounce the forks and coming out of the recess I'd assume its either shit in the recess or the seal is the wrong size, which would be an utter cunt as you'd need to split it again Neutral
Me being me, bit of light fork oil to lube up the stanchion and some form of adhesive inside, but I wouldn't do that if you value you forks.
Speak with seller first I reckon...
lihp
PostPosted: 19:09 - 17 Aug 2013    Post subject: Reply with quote
Spring is there, you can feel it hook into the leg but doesn't stay.
I've not filled them with oil yet incase I need to split so nothing major to do so
Timmeh
PostPosted: 19:21 - 17 Aug 2013    Post subject: Reply with quote
If you've got the adjustable suspension, then you might find that you've got the wrong seals, as the stanchions are slightly wider than the standards, to the tune of a few thous.
PostPosted: 19:54 - 17 Aug 2013    Post subject: Reply with quote
Three thou? Five thou? HOW MANY THOUSANDTHS?
lihp
PostPosted: 20:12 - 17 Aug 2013    Post subject: Reply with quote
I could get the extra welded up to 4 thou?
Alternatively, they're not SP forks Wink
Timmeh
PostPosted: 20:51 - 17 Aug 2013    Post subject: Reply with quote
Honestly can't remember, but I know it's enough so cause the problem Phil describes.
In any case, it's a moot point as he hasn't got SP forks. So they're either the wrong ones or they've been put in on the piss which is not likely as OP knows what he's doing.
lihp
PostPosted: 22:00 - 17 Aug 2013    Post subject: Reply with quote
It may also be because I haven't actually cleaned the oil from my gloves off the rubber and inside of the fork leg Embarassed
Timmeh
PostPosted: 01:30 - 18 Aug 2013    Post subject: Reply with quote
Timmeh wrote:
...OP knows what he's doing.
I hereby retract this part of my previous statement.
sickpup
Old Timer
PostPosted: 13:28 - 18 Aug 2013    Post subject: Reply with quote
The dust seal has a steel spring strip that holds it in the outer leg. If it doesn't its the wrong type.
lihp
PostPosted: 13:51 - 18 Aug 2013    Post subject: Reply with quote
Made sure surface were totally dry and still no luck. I've messaged the seller, but I bought these 2 months ago and only just got round to it so will see how it goes with replacements.
There is a spring around the section on the slider, nothing for the outer leg.
Pup, any chance you can link me to the different types?
sickpup
Old Timer
PostPosted: 21:46 - 18 Aug 2013    Post subject: Reply with quote
Type as in size, sorry my bad English. Did they come in a yellow backed pack by any chance as this supplier seems to have some bad measurements on these items?
lihp
PostPosted: 23:39 - 18 Aug 2013    Post subject: Reply with quote
That is correct pup. I have re-ordered from elsewhere now
lihp
PostPosted: 17:13 - 20 Aug 2013    Post subject: Reply with quote
Replacement seals arrived from the original seller today from Kyoto which also have the exact same issue and are 0.75mm smaller in diameter than the spec.
Additionally, I ordered a pair from Wemoto to just get them done, also came from Sifam/Kyoto and are the exact same dimensions as the other pairs so same issue again.
3 pairs, 2 suppliers all incorrect. Guess I best get a price from Suzuki for OEM ones!
sickpup
Old Timer
PostPosted: 00:51 - 21 Aug 2013    Post subject: Reply with quote
All from the same wholesaler. I had the same problem with the bushes for Lozzy's Fireblade.
lihp
PostPosted: 09:15 - 21 Aug 2013    Post subject: Reply with quote
The Suzuki quote was
2x Dust Seal £19.55ea Part Number 51173-46E00
2x Oil Seal £14.90ea Part Number 51153-27C20
£70 for oil and dust seals!!
PostPosted: 09:54 - 21 Aug 2013    Post subject: Reply with quote
I did the same when I went to a dealer to get just the oil seals. Were £19 each... when you factor in the bushes too, shit gets expensive Laughing
lihp
PostPosted: 10:35 - 21 Aug 2013    Post subject: Reply with quote
Trying some from a generic seal and engineering supplier from correct spec. If they're the same I'll have no option other than get Suzuki OEM parts
The last post was made 13 years, 23 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 103.54 Kb
