Drift HD 720. brand new and not charging.
DottyDuck
PostPosted: 00:32 - 18 Aug 2013    Post subject: Drift HD 720. brand new and not charging. Reply with quote
Hello all, basically i bought a brand new drift HD 720. I put the battery in the camera and plugged it into my laptop via USB. 2 hours later i go to switch it on and it wont turn on. So i plug it back into laptop and turn the camera on and it works. I then unplug the cable and it knocks off again. Now it says in the manual (online) that when it is charging it shows a blue light. I then tried plugging the usb in the camera and as i was slowly putting it in the camera the light went blue, the thing is, it only flickered blue and trying to get it in a position where it stays blue is impossible! Now where is the problem? is it the actual camera or USB cable?
Any help will be greatly appreciated! Smile as right now i am stressed out! sigh! Brick Wall Embarassed
CBT- 2012 Theory- 18/12/13 Mod 1- 07/01/14 Mod 2- 15/01/14 Very Happy
Old Bike: Zontes Panther 125cc - wrote off Sad Current Bike: Kawasaki ZR7 Very Happy Wub
kerr
PostPosted: 00:33 - 18 Aug 2013    Post subject: Reply with quote
Send it back for a replacement?
aprilia 125 Af1 Futura >> Suzuki gsxr 600 srad >> J1 zx6r >> cbr 600rr >> Speed Triple
DottyDuck
PostPosted: 00:48 - 18 Aug 2013    Post subject: Reply with quote
think you are right kerr i was just hoping there was another way.. as no doubt i will have a long wait to send it back then get a replacement!
smithyithy
PostPosted: 00:54 - 18 Aug 2013    Post subject: Reply with quote
Where did you buy it from?
DottyDuck
PostPosted: 01:08 - 18 Aug 2013    Post subject: Reply with quote
https://www.actioncameras.co.uk/drift-hd-720-helmet-cam
here lol
trevor saxe-coburg-gotha
PostPosted: 06:45 - 18 Aug 2013    Post subject: Reply with quote
I might have this wrong, but it seems there are three components here - not two. What I mean is, you ask whether it's the cable or the camera - but if I've read you right, the laptop is also in the "chain," correct? If so, it may be that the usb port itself is dodgy. Something like this has happened to me, at least.
So let me ask - do you regularly use that port with other leads, without encountering faults? If so, eliminate that possibility.
Secondly, is there any way to test that particular lead with another piece of hardware? Or is it specific to the camera? Probably the latter, knowing this kind of stuff. But if not, check it with something else if you haven't already - this way you can eliminate the lead.
If you can't test the lead in this way can you buy another easily and quickly? It'd be a quick way to suss out if the camera is being a bastard.
J.M.
PostPosted: 08:28 - 18 Aug 2013    Post subject: Reply with quote
Try charging it from another computer.
Some devices refuse to charge unless they're getting enough mA at the right voltage. For example, my HTC Wildfire will quite happily charge from 500mA or a little less. My tablet wont even register that it's plugged in if I connect it to the same source.
2004 R1 & 2018 XSR900
Nb
PostPosted: 08:33 - 18 Aug 2013    Post subject: Reply with quote
Try plugging into into the mains, i use my wifes iphone charger or my samsung one.
DottyDuck
PostPosted: 15:45 - 18 Aug 2013    Post subject: Reply with quote
Thanks for all replies Smile Thumbs Up
I have 3 usb ports on my laptop and have used my sister's laptop too and all ports are fine. The camera works when it is plugged into my laptop and will switch on but it just doesn't charge the battery. When it is plugged in i took the battery out and the camera was working by getting power from my laptop. Now i am not sure what is wrong, could it be faulty housing where the cable connects to the camera? when it is charging the light is meant to be blue but it only flickers when inserting it and instantly the light turns off again.
I have tried using my phone charger as i can plug the usb into it and it does the same, i place the end into the camera and it will flicker blue before not registering the fact it is fully in.
I was hoping for a solution because i can't be bothered with the faff of sending it back! looks like i wont have a choice. What an inconvenience!
smithyithy
PostPosted: 16:34 - 18 Aug 2013    Post subject: Reply with quote
To be fair, if it is the camera that's at fault, Action Cameras and Drift are both renowned for very good customer service so I'm sure they'll resolve the problem quickly for you.
J.M.
PostPosted: 07:55 - 19 Aug 2013    Post subject: Reply with quote
In which case I would hesitate that either the camera or cable is at fault. Contact the customer service and inform them of your issue.
It's not ideal to have to get a replacement item, but it's better than having a non-working item Very Happy
PostPosted: 09:55 - 19 Aug 2013    Post subject: Reply with quote
Sounds like GoPro with a faulty cable, try another cable.
Dalemac
PostPosted: 13:16 - 19 Aug 2013    Post subject: Reply with quote
Action cameras are very very good in terms of customer service.
The universal clip on my hd720 broke, i phoned them, they sent out two replacement clips which were here the next day, all covered under warranty.
YBR125 -> GPZ500S -> SL1000
uriar
PostPosted: 05:57 - 11 Sep 2013    Post subject: Re: Drift HD 720. brand new and not charging. Reply with quote
Hi,
sorry for bringing up this old topic but i found it when searching Google, having the exact same problem, and was I wondering how it was resolved. could you please update?
thanks, Uri
There is a gap of 2 years, 71 days between these two posts...
dagiles
PostPosted: 05:09 - 22 Nov 2015    Post subject: DRIFT HD 1080 will not work unless plugged in light Reply with quote
I know this is an old post but my drift hd 1080 is doing the same thing. Blue flickering light and wont work with the battery only if it is plugged in will it work. Did anyone get this solved if so what fixed it?
thanks
David
uriar
PostPosted: 07:12 - 22 Nov 2015    Post subject: Re: DRIFT HD 1080 will not work unless plugged in light Reply with quote
thanks
David
Replacing the battery worked for me.
doggone
PostPosted: 09:14 - 22 Nov 2015    Post subject: Reply with quote
Batteries are cheap enough, you can get one plus a 12v and 240v charge here for example under £10
https://www.ebay.co.uk/itm/301212887910
I'd suspect some computer USB outlets will barely supply enough power to charge an ageing battery.
iooi
PostPosted: 10:35 - 22 Nov 2015    Post subject: Re: DRIFT HD 1080 will not work unless plugged in light Reply with quote
thanks
David
God therre is some serious lack or trouble shooting... Embarassed
Works pluged in = device, cable & power source OK
Won't charge battery/work via battery = BATTERY FUCKED Rolling Eyes
Al
PostPosted: 14:09 - 22 Nov 2015    Post subject: Reply with quote
I have a really weird issue with my drift HD, I don't use tagging and the remote is disabled. I just turn it on and leave it recording when riding.
Since I got a new phone a few months ago (Moto G 3rd gen) every time I get a notification on my phone it stops the drift recording like it is sending the same signal as the camera remote.
I'm not sure if this is even possible? but it defiantly seems to be happening. I arrive at my destination and if I look and the green light is showing on the drift and it's stopped recording, I have notification on my phone.
Contacted Drift on twitter but they didn't reply.
Yamaha FZR400RR 3tj
My Instagram Thingy
Itchy
PostPosted: 14:21 - 22 Nov 2015    Post subject: Re: DRIFT HD 1080 will not work unless plugged in light Reply with quote
thanks
David
USB charging did not work. Plugging it into the mains did not work.
What worked?
Taking the battery out and using a wall charger with the battery in it (and not in the camera) this worked.
Itchy
PostPosted: 14:23 - 22 Nov 2015    Post subject: Reply with quote
Go to the menu and disable remote control functions.
Al
PostPosted: 18:10 - 22 Nov 2015    Post subject: Reply with quote
Yamaha FZR400RR 3tj
My Instagram Thingy
M.C
PostPosted: 18:17 - 11 Dec 2015    Post subject: Re: DRIFT HD 1080 will not work unless plugged in light Reply with quote
thanks
David
Just got one and had the same problem, turns out I had the battery in upside down Embarassed
The last post was made 10 years, 301 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 123.16 Kb
