| xocnai |
 xocnai L Plate Warrior
 Posted: 18:15 - 18 Aug 2013 Post subject: CBF125 turns over but doesn't fire - gearbox? |
New to the forum, but desperately searching for help diagnosing my CBF125's issue.
While riding recently, a 'rubbing' kind of sound started coming from the gearbox area (it almost sounded like a loose fanbelt would on a car). This was only happening in gears 2 and 3. Shortly afterwards, I lost all drive and the engine cut out.
Since then I have been unable to start the engine via ignition or bumping. It turns over but makes an unusual sound when doing so, again emanating from the gearbox area (I think!)
I have linked to a video that I've taken demonstrating the sound being made when turning over.
Does anyone have any ideas?
https://www.youtube.com/watch?v=iIVgzbO4X3w&feature=youtu.be
Thanks |
| misscrabstick |
 misscrabstick Crazy Courier
| wots |
 wots World Chat Champion
 Posted: 20:39 - 18 Aug 2013 Post subject: |
It could be the starter, missing teeth etc. The one time I tried to bump start mine I couldn't because of the FI, but I think it was because the battery was almost totally dead. If you don't have a compression tester, just take spark plug out and feel for any kind of compression. But that is just spinning, either the starter is spinning and not engaging to actually turn the engine, or there is zero compression as has been mentioned.
EDIT: Also, drop the oil and look for anything that shouldn't be there, it takes just under a litre I think. ____________________ Currently: Yamaha DT 125 LC2,Repsol Fireblade, and Bumblebee MSX 125 |
| Nemo |
 Nemo Could Be A Chat Bot
| wots |
| xocnai |
| tomh |
 tomh Scooby Slapper
| xocnai |
| Nemo |
The last post was made 13 years, 28 days ago. Instead of replying here, would creating a new thread be more useful? |
