Red Grease for brakes
Nobby the Bastard
Harley Gaydar
PostPosted: 18:02 - 18 Aug 2013    Post subject: Red Grease for brakes Reply with quote
I've read the threads on brakes and notice that there's no mention of red grease. I was wondering why.
To explain, red grease, is basically a gelled veg oil that is formulated specifically for the seals and pistons of brakes. After 4 years of shit with my brakes, a good dose of red grease has sorted them.
Note: Don't confuse this for coppaslip, this is to go on the pistons, not the back of the pads. Coppaslip on the back of the pads reduces/prevents squeal as it damps down vibration.
Triumph Sprint ST 1050
sprintster
PostPosted: 18:12 - 18 Aug 2013    Post subject: Reply with quote
I know about using red grease on rubber seals as normal grease perishes rubber but I've never put it on my brake pistons as I imagine all the crap off the road will just stick to it. Thumbs Down
Nobby the Bastard
Harley Gaydar
PostPosted: 18:14 - 18 Aug 2013    Post subject: Reply with quote
Have you seen the crap that sticks to the pistons anyway? You obviously haven't riddden through winter.
The grease actually keeps the crap away from the pistons.
Edit: dyslexic fingers...
sprintster
PostPosted: 18:34 - 18 Aug 2013    Post subject: Reply with quote
I live in the north of Scotland and do about 9K miles a year...I think I can safely say I've seen more shit weather than you in my lifetime! Laughing
I'm not saying your wrong,just what my preference is! I know my pistons get dirty but at least I don't have big chunks of grit and salt stuck to them.
BTW I'm still on the same set of seals after 65k miles so I must be doing something right! Wink
Nobby the Bastard
Harley Gaydar
PostPosted: 18:40 - 18 Aug 2013    Post subject: Reply with quote
Can I ask what you are riding/what sort of brakes (no of pistons etc) you have?
I've got two 4 pot callipers on my FZ and it's been a fucking bastard to keep the fuckers un-seized for the last 4 years until I used the grease.
I've cleaned then (with switch cleaner) and lubed them/added anti corrision with ASF80 to no success. Smeared the red grease round the pistons and worked them into the callipers and immediately noticed the difference and haven't needed to touch them since.
Skudd
PostPosted: 19:34 - 18 Aug 2013    Post subject: Reply with quote
I always used copperslip on brakes as I thought it was the right thing to do, always had issues every year with brakes, kept cleaning them again and again. Just started to use red grease (bought a big tub of it) and all seems to be going smoothly.
Now what s white grease for?
Nobby the Bastard
Harley Gaydar
PostPosted: 20:00 - 18 Aug 2013    Post subject: Reply with quote
Lubing your missus...
Skudd
PostPosted: 20:11 - 18 Aug 2013    Post subject: Reply with quote
She needs lubing with sand paper. Twisted Evil
Nobby the Bastard
Harley Gaydar
PostPosted: 20:21 - 18 Aug 2013    Post subject: Reply with quote
I suggest, with all due respect, that someone has a small penis...
PostPosted: 20:24 - 18 Aug 2013    Post subject: Reply with quote
The old Yamaha 4 pots were renowned for it. Many years ago I stopped for a broken down bike, but he was just waiting for recovery. A 1 year old FJ1200 on which the brakes had seized. Don't think this was that unusual.
There was a bit of a hoo haa over Yamaha brakes at the time. From memory the solution was that Yamaha issued sachets of copper grease for use on the brakes.
sprintster
PostPosted: 20:47 - 18 Aug 2013    Post subject: Reply with quote
I ride a Sprint ST(the commuter) and a Sprint RS(the fun!).Triumph's are well know for sticky calipers,but I clean them maybe twice a year or whenever I've got the wheel off for a new tyre,20 minutes per caliper,it's not a big deal.I always use brake cleaner(who knows what shit is in switch cleaner attacking your seals)and push the pistons back in with some fresh brake fluid on them. Thumbs Up
sprintster
PostPosted: 21:01 - 18 Aug 2013    Post subject: Reply with quote
White Grease is ideal for lubricating brake linkages,latches,cams,window regulators,hinges,wires,cables,etc.It can be used in anti-friction,plain bearing and pumping equipment where the ingress of water has previously reduced lubrication effectivness.It finds particular use where,for visual reasons,a light coloured grease is desirable.Operating temperature range of approximately -10 to 120C............If I remember correctly! Wink
Nobby the Bastard
Harley Gaydar
PostPosted: 21:05 - 18 Aug 2013    Post subject: Reply with quote
Do you get all your information from Wiki?
Ariel Badger
PostPosted: 22:11 - 18 Aug 2013    Post subject: Reply with quote
Evidently not
barrkel
PostPosted: 22:30 - 18 Aug 2013    Post subject: Reply with quote
Ariel Badger wrote:
Try this:
https://www.google.com/search?num=50&q=%22for+visual+reasons+a+light+coloured+grease+is+desirable%22
Ariel Badger
PostPosted: 22:47 - 18 Aug 2013    Post subject: Reply with quote
Very Happy
Skudd
PostPosted: 23:52 - 19 Aug 2013    Post subject: Reply with quote
No she is just a cow of an ex. So sand paper would hurt big time. Twisted Evil
The last post was made 13 years, 87 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.15 - MySQL Queries: 13 - Page Size: 98.84 Kb
