| A100man |
 A100man World Chat Champion
 Posted: 20:05 - 19 Aug 2013 Post subject: No Spark _ Flummoxed. |
Hi All
Please forgive first post as a help request ..
I have a ratty Suzuki a100 I have been playing with for 'fun' but it's now driving me potty as I cannot get a spark. The summary of action is below..
Points check opening and closing (not worried about timing yet)
Condensor measures OK 200nF
Getting some AC volts of the source coil enough to make a small low tension spark on coil feed (difficult to measue off kickstart but maybe 6-9 VAC on DMM)
Charging coil measure about 0.9 Ohms but ignition source coil is 2.5 Ohms ( a problem ?)
Removed condensor no change.
Fittted new coil (primary 1.0 Ohm, secondary 6 KOhm)
Checked coil earthing - all seems good.
Tried sparking straight off HT lead - no change
Was thinking of swapping stator coils over next...
No specs for coil resistance in my manual as it covers older model
and mine is a later 79/80.
Anyone anything eles to suggest ?
Ta
JS |
| JakeW476 |
 JakeW476 Two Stroke Sniffer
| A100man |
| bikenut |
 bikenut World Chat Champion
| Blau Zedong |
 Blau Zedong Banned
| A100man |
 Posted: 16:48 - 20 Aug 2013 Post subject: |
OK, some more..
Tried an experiment this morning (before work..) - wired the coil direct to battery +6v and dabbed the negative to chassis/ground while holding the HT lead close to ground. Got the occasional 'weak as a kitten' spark.
On return home will double check all earth terminals etc.. Really expected this check to deliver a fat blue spark but..  |
| A100man |
| Ariel Badger |
 Ariel Badger Super Spammer
| Blau Zedong |
 Blau Zedong Banned
| bikenut |
| A100man |
| bikenut |
| A100man |
 Posted: 08:23 - 24 Aug 2013 Post subject: Sorted ! |
Aha ! After fannying about for hours I stuck a meter on the source coil output line to measure resistance of the coil/points to ground. Rotated engine and no change !
Thought I had cleaned points properly before, apparently not as they weren't shorting properly when closed. Situation could also have been help by the new coil..
Thanks all - was getting to thepoint of replacing stator coil..
JS |
| Blau Zedong |
 Blau Zedong Banned
The last post was made 13 years, 31 days ago. Instead of replying here, would creating a new thread be more useful? |
