Slapping/cracking noise
Clutchy
PostPosted: 15:04 - 21 Aug 2013    Post subject: Slapping/cracking noise Reply with quote
I've recently cleaned my chain on my sv650, man I've never seen a chain this shagged in lube, took me 3 hours and 2 litres of paraffin to get it clean, also did where the chain runs, rear sprocket etc.
Now a round about since then, can't remember if was as soon as I had done it, there's been a weird noise coming from the back of the bike.
Sort of a crackling noise but spaced apart, really hard to describe, and ONLY at low revs, when for example short shifting to keep revs down, can only only hear it between 2-3k rpm.
You can not hear it at any point if put in neutral. Also it doesn't do it when coasting, so it seems just when under strain at low revs.
My theory is that the clean chain no longer has a cushion of soft built up chain lube to slap against and is now noisy.
Any ideas? Should I be worried...
Dalemac
PostPosted: 15:06 - 21 Aug 2013    Post subject: Reply with quote
noticed similar squeaks and slaps after i did mine last, no idea what it was though, Seems fine now.
YBR125 -> GPZ500S -> SL1000
Supermoto_Fan
PostPosted: 15:43 - 21 Aug 2013    Post subject: Reply with quote
What's your chain slack btw?
J.M.
PostPosted: 16:04 - 21 Aug 2013    Post subject: Reply with quote
Do you have a tight spot in your chain anywhere?
Chain too loose?
2004 R1 & 2018 XSR900
Clutchy
PostPosted: 18:10 - 21 Aug 2013    Post subject: Reply with quote
Chains all good, all the way through
The last post was made 13 years, 87 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 43.5 Kb
