What is this and what does it do??
Jbiker12
PostPosted: 12:31 - 22 Aug 2013    Post subject: What is this and what does it do?? Reply with quote
Hi, can anyone tell me what the little metal tube in this photo is and what it does?
Im working on a 1998 derbi senda 50 and in case you hadnt guessed... the inlet manifold.Wink
https://i1299.photobucket.com/albums/ag79/peacemaker120/KGrHqVq0FEIIfS66SBRHDmoQNLQ60_35_zps89f28be3.jpg
shereen
PostPosted: 12:43 - 22 Aug 2013    Post subject: Reply with quote
It's where you fit the power band to.
Drake
PostPosted: 12:45 - 22 Aug 2013    Post subject: Reply with quote
Autolube 2t pipe
Drake
PostPosted: 12:46 - 22 Aug 2013    Post subject: Reply with quote
Autolube 2t pipe
PostPosted: 12:47 - 22 Aug 2013    Post subject: Reply with quote
^ That Thumbs Up , it links a tube to one side to the powerband actuator, the other side of that goes to the expansion chamber, usually 2/3 the way down it.
Usually aftermarket systems do not have this so you just blank it off. You will need the powerband actuator though otherwise it won't give you any power whatsoever. If you can't find them for sale, ring DEP pipes, they sell them as their expansion chambers make full use of them. Bought one for my RS125, cost £6 IIRC.
bikenut
PostPosted: 15:17 - 22 Aug 2013    Post subject: Reply with quote
:D i get my power bands from the swimming pool, there free and work better, colour dont matter as i twist them round the twist grip and the bike goes faster cos i can grip the grip better!!!!! :D
j, looks just like a 2 t pipe stub, autolube. 8o)
Jbiker12
PostPosted: 16:03 - 22 Aug 2013    Post subject: Reply with quote
Interesting.............Mr. Green
thanks alot guys really helpful.
map
Mr Calendar
PostPosted: 16:09 - 22 Aug 2013    Post subject: Reply with quote
Excuse me if I slip into technical jargon but it's the whatsit that fits to the thingy so the whatyamacallit works. Please don't mix up whatsit and whatyamacallit though, it's easily done. Of course you could always fit a dooda instead.
Hope mechanics speak that makes it clear Wink
Walloper
PostPosted: 18:24 - 22 Aug 2013    Post subject: Reply with quote
It looks suspiciously like a gozonti adapter for a 1998 R1?
UnspeedySam
PostPosted: 19:30 - 22 Aug 2013    Post subject: Reply with quote
It the flange pipe vacuum take off for the electricity pump. It's the supply that charges the battery so if it's not connected the battery won't charge.
Nobby the Bastard
Harley Gaydar
PostPosted: 19:40 - 22 Aug 2013    Post subject: Reply with quote
It's so you can connect vacuum guages so that you can balance your carb.
Triumph Sprint ST 1050
stevo as b4
PostPosted: 22:30 - 22 Aug 2013    Post subject: Reply with quote
It's the air injection port nozzle into the intake manifold.
It's normally blanked off for a smoother midrange, but if you leave it open you will find it allows extra air into the engine for noticeably more power and higher top speed when you go down hill at full throttle once over 50mph! Thumbs Up
Furrybiker
PostPosted: 22:56 - 22 Aug 2013    Post subject: Reply with quote
Your bike has a very small willy. Embarassed
The other Paul Rudd
PostPosted: 00:12 - 23 Aug 2013    Post subject: Reply with quote
That's the biggest load of old crap I've ever read.
Yoyo This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
Walloper
PostPosted: 08:34 - 23 Aug 2013    Post subject: Reply with quote
You obviously haven't been here long.
The other Paul Rudd
PostPosted: 17:29 - 23 Aug 2013    Post subject: Reply with quote
I was the one what wrote it. I borrowed Sam's computer and he was still logged in. Laughing
UnspeedySam
PostPosted: 20:51 - 23 Aug 2013    Post subject: Reply with quote
I got bcfraped Sad
Nobby the Bastard
Harley Gaydar
PostPosted: 21:08 - 23 Aug 2013    Post subject: Reply with quote
Count yourself lucky...
https://i428.photobucket.com/albums/qq9/Nobbythechihuahua/Bastard_zpsf17fa395.jpg
prawny1
PostPosted: 23:06 - 23 Aug 2013    Post subject: Reply with quote
vacuum pick up for the fuel tap?, its too big to be oil by the looks of it.
If the picture is for an aftermarket manifold it could be for one of those boost bottle things.
hellkat wrote:
jamesrs250
PostPosted: 23:29 - 23 Aug 2013    Post subject: Reply with quote
vacuum pipe for the fuel...pipe from the fuel tank/ vacuum pump should connect to it
stirlinggaz
PostPosted: 18:48 - 25 Aug 2013    Post subject: Reply with quote
100% 2 stroke oil intake.
if carb has also a 2t intake, blank the one on manifold off,
cheers,
GAZ
The last post was made 13 years, 39 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 111.15 Kb
