Divvy + hedge = a lot of explaining
sidewinder
PostPosted: 19:16 - 22 Aug 2013    Post subject: Divvy + hedge = a lot of explaining Reply with quote
Well it's happened again i hedged it Sad
So riding along going home i hit a pot hole ( a rather big one) thought nothing of it quite use to it on the old welsh back roads.Approaching a corner i can take at 30 - 40 mph easy enough.But this time it didn't i went straight on Shocked which resulted in the bike almost upside down it the hedge. Luckily a farmer passing by helped me get the bike back on road not a lot of damage few more scratches cracked indie etc and it fired up after a few attempts little bit of white smoke which cleared away.So what caused this on closer inspection i noticed the fork seals were almost out the forks e-bay shite i guess and oil all over the place tires brake disc etc .Now to explain to the lovely missis that bikes are not not dangerous chocolate and flowers should do..Better get some decent oem seals this time and pay some body more competent to fit.. Thumbs Up
https://i1128.photobucket.com/albums/m492/sidewinder11/Untitled_zps4f51e89b.jpg
Blue line correct route red line divvys route Smile
XanderZZR
PostPosted: 19:36 - 22 Aug 2013    Post subject: Reply with quote
That is seriously impressive to achieve that Shocked as long as you and the bike are (mostly) ok all is well!
Can't see how you could blow the seals out of the forks - even pattern ones - unless you forgot to put the retaining clips in.
sidewinder
PostPosted: 19:45 - 22 Aug 2013    Post subject: Reply with quote
i'm sure i did .But then again Embarassed Hence the need for some body more competent to fit next time.. Thumbs Up
nathan k
PostPosted: 20:38 - 22 Aug 2013    Post subject: Reply with quote
When it comes to mechanics, lessons learnt are always so expensive Sad
Lucky it was just a hedge!
MCW
PostPosted: 21:50 - 22 Aug 2013    Post subject: Re: Divvy + hedge = a lot of explaining Reply with quote
Glad that you are ok. Smile
If you would like to explain to me too that bikes are not dangerous, pink roses and suchard chocolates please... Mr. Green
-Matt-
PostPosted: 01:54 - 23 Aug 2013    Post subject: Reply with quote
Don't forget to mention your herioc actions as you swerved to avoid the run-away school bus, wild kittens and blind charity-runners that came at you head on, putting your own safety aside for the good of others Karma
Glad to hear you're alright Razz
J.M.
PostPosted: 10:19 - 23 Aug 2013    Post subject: Re: Divvy + hedge = a lot of explaining Reply with quote
Point out the fact that you're still alive and uninjured. Thumbs Up
2004 R1 & 2018 XSR900
garth
PostPosted: 10:52 - 23 Aug 2013    Post subject: Reply with quote
Pics of bike and forks plz.
prawny1
PostPosted: 12:59 - 23 Aug 2013    Post subject: Reply with quote
Either way too much fork oil or missing/weak circlips.
was it just lack of brakes or a front wheel wash out that led to your introduction to the occupants of the hedgerow?
hellkat wrote:
sidewinder
PostPosted: 16:28 - 23 Aug 2013    Post subject: Reply with quote
Sorry no pics of the forks bike has gone to the local bike shop for repairs but.
On inspection of the probable cause my mech has found a fault quite serious to.Where the dust seal fits from there down it has actually cracked which he recons is the cause of every thing slipping out.He recons it's quite common if the bike has had a crash before Shocked .I did have a small one last year so could this of caused it?.Any way i'm now on a the search for some new forks so might as well do a twin disc conversion.
now my lovely has finally realised it's not mine or the bikes fault so is quite happy for me to carry on riding but i have to do more checks etc Very Happy lesson learn't i suppose.So if you do have a off even a small minor one give your bike a good check over you never know Thumbs Up
The other Paul Rudd
PostPosted: 17:09 - 23 Aug 2013    Post subject: Reply with quote
I once blew a fork seal jumping off of a hump back bridge. Only so much oil will flow through the damping rod. If you move it too quickly, and it pressurizes the top side of the damper, then the air/oil will try and find an exit somewhere.
PostPosted: 17:30 - 23 Aug 2013    Post subject: Reply with quote
Blow a seal, yes, done that in my yoof. Blow the seals clean out of the fork tops - not so much...
Ichy
PostPosted: 17:37 - 23 Aug 2013    Post subject: Reply with quote
I agree, the metal clips that hold them in place are never easy to remove at the best of times, assuming they are seated correctly.
The other Paul Rudd
PostPosted: 18:05 - 23 Aug 2013    Post subject: Reply with quote
Ah yeah. Sorry. I actually didn't the post properly this time. Laughing
i.p.phrealy
PostPosted: 23:55 - 23 Aug 2013    Post subject: Reply with quote
Reminds me of the old joke, Eskimo breaks down in his jeep so calls the local mechanic to look, mechanic has a look at the engine and says to the Eskimo "you've blown a seal" to which the Eskimo replies
"No, that's just frost on my beard"
...I'll get my coat. Mr. Green
radicalrabit
PostPosted: 23:57 - 23 Aug 2013    Post subject: Reply with quote
SURPRISED NO ONE MENTIONED GETTING HOLD OF THE LOCAL COUNCIL AND GETTING THEM, TO PAY FOR GETTING THE FORK SEALS DONE AS YOU OBVIOUSLY DITCHED THE BIKE BECAUSE YOU WENT CRASHING DOWN A POT HOLE IN THE ROAD AND ENDED UP GETTING DUMP[EDOFF THE BIKE AS A RESULT LET THEM pay for the cost of getting the bike sorted
o H FER FUCK SAKE
# SICK TO DAMNED DEATH OF THE BLOODY CAPS LOCK
I am sure it sometimes comes on just because I typed an a
VF1000 F2F, BLACKBIRD with carbs, 2nd VF1000F2F just need somewhere to go now..
DottyDuck
PostPosted: 00:57 - 24 Aug 2013    Post subject: Re: Divvy + hedge = a lot of explaining Reply with quote
also point out your penis is in fully functioning order, too.
CBT- 2012 Theory- 18/12/13 Mod 1- 07/01/14 Mod 2- 15/01/14 Very Happy
Old Bike: Zontes Panther 125cc - wrote off Sad Current Bike: Kawasaki ZR7 Very Happy Wub
i.p.phrealy
PostPosted: 07:28 - 24 Aug 2013    Post subject: Re: Divvy + hedge = a lot of explaining Reply with quote
...intrigued to know how you know. Thinking
sidewinder
PostPosted: 11:29 - 24 Aug 2013    Post subject: Re: Divvy + hedge = a lot of explaining Reply with quote
Secret Very Happy
The last post was made 12 years, 120 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.02 - MySQL Queries: 13 - Page Size: 114.16 Kb
