engine cranking slowly
mikey909
PostPosted: 15:24 - 22 Aug 2013    Post subject: engine cranking slowly Reply with quote
i have a gilera dna 125. the bike is starting to crank really slowly under load, but when i take the spark plug out the engine will crank normally. the battery is brand new and fully charged. my guess is that the starter solenoid has, or is starting to go?
CestrianX
PostPosted: 15:54 - 22 Aug 2013    Post subject: Reply with quote
Check all the connections that carry plenty of current, clean with a wire brush as any debris can cause resistance to current flow, you may find a dirty connection will warm up more than the others. Also, get a multimeter on the battery and check the voltage whilst the starter is turning, I know you said it's a new battery but you should check all possibilities.
Clutchy
PostPosted: 16:47 - 22 Aug 2013    Post subject: Reply with quote
Sure its fully charged? As stated get readings for battery when not in use and then when cranking.
PostPosted: 17:17 - 22 Aug 2013    Post subject: Re: engine cranking slowly Reply with quote
Does it even have a starter solenoid?
Some bikes probably do have them (never looked at a scooter one), but it's pretty rare if they do and I've never seen one.
Usually just have a normal relay and a clutch arrangement on to the flywheel or similar.
Also, what they said above Smile.
mikey909
PostPosted: 23:53 - 22 Aug 2013    Post subject: Re: engine cranking slowly Reply with quote
yep the bike has a starter motor. and a starter bendix to spin up the flywheel. when the spark plug is removed, the engine will turn over nicely. its just when the spark plug is back in place and there is compression, thats when the engine will crank really slow. the battery is fully charged also.
PostPosted: 00:32 - 23 Aug 2013    Post subject: Re: engine cranking slowly Reply with quote
But are you sure it has a solenoid?
The only items listed under that for your bike I can easily see on the internet are normal bike style relays.
As above - I'd check the voltage as you turn it over and check connections etc.
Also; do you have a battery tester?
It may be you've got a duff battery.
Even one showing full voltage may not do so well with a proper battery tester that puts it under load.
mikey909
PostPosted: 09:48 - 23 Aug 2013    Post subject: Re: engine cranking slowly Reply with quote
no, theres no solenoid, just the starter. im going to also check the voltages later. i'll post results.
PostPosted: 09:59 - 23 Aug 2013    Post subject: Re: engine cranking slowly Reply with quote
I'd also try connecting up a car battery with jump leads; that way you can be absolutely sure it isn't a case of battery cranking amps that's the issue.
However, it might be worth checking for shorts first - if it was a short circuit causing low amps to get through, giving it even more may not be ideal!
The last post was made 13 years, 86 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.7 - MySQL Queries: 13 - Page Size: 57.35 Kb
