Random fuel pipe.
Damionh
PostPosted: 11:56 - 23 Aug 2013    Post subject: Random fuel pipe. Reply with quote
Hey, Ive got a piaggio zip 53 plate. Its 2 stroke. It used to run really well. Anyway, I started it up today first time in months. And fuel is leaking from the bottom... There a pipe at the very bottom between the wheel and engine. What the hell is it? I cant actualy see anywhere for it to go??
Your help would much appreciated. Thumbs Up
Thanks Damo!
Aff
PostPosted: 11:59 - 23 Aug 2013    Post subject: Reply with quote
It's a breather or an overflow pipe.
Most likely an overflow from the carb, if its pissing fuel you probably have a stuck float.
Electric Bike Project
Damionh
PostPosted: 12:01 - 23 Aug 2013    Post subject: Reply with quote
Okay. Awsome help thanks! Very Happy And I know I sound like a dumby. How you check that? means I got to take tank out?
Thanks pal
misscrabstick
PostPosted: 12:08 - 23 Aug 2013    Post subject: Reply with quote
Give the bike a vigorous shaking, often the leaking is a bit of muck in the float valve that stops it closing off the fuel when then float bowl is full, a good shake may shift it, ideally though, strip out the carb, fuel pipe and give them a good thorough cleanout and blow through with compressed air.
Matt-
PostPosted: 12:24 - 23 Aug 2013    Post subject: Reply with quote
Float is probably sticking. Take off the float bowl and clean the bowl and valve. When you have the float bowl off, clean everything in the carb thoroughly with petrol or carb cleaner, Once it's all cleaned, Make sure the float or float valve isn't damaged, and reassemble.
It's always a good thing to blow out the carb internals with a blow gun (compressed air) just to make sure theirs no blockages etc.
Hope that helps,
RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010
PostPosted: 13:14 - 23 Aug 2013    Post subject: Reply with quote
'it it wiv an 'ammer.
Serious advice is serious. Rubber or wooden mallet to the float bowl. If that doesn't unstick it, then start on disassembly.
ws4936
PostPosted: 02:41 - 24 Aug 2013    Post subject: Reply with quote
You can consume the fuel if you rag it, that'll stop you wasting it through the overflow - but I'd recommend degunking the float Razz
If everything seems under control, you're just not going fast enough.
Motorhate
PostPosted: 17:44 - 25 Aug 2013    Post subject: Reply with quote
Happened to me the other day. In my case, it was a simple case of overfilling the tank. Ridden it since, leaked stopped once petrol level dropped.
Current - Harley Davidson FXDB Street Bob | Harley Davidson FLTR Road Glide | Harley Davidson Road King
GONE - Honda CB500 Ratbike | Yamaha FZ750 | Yamaha XVS1100 | Kawasaki VN2000 | Kawasaki ER-6 F | Harley Davidson XL883L Sportster
There is a gap of 1 year, 76 days between these two posts...
tymaris47
PostPosted: 14:19 - 10 Nov 2014    Post subject: bown tank Reply with quote
Hi do you still have the bown petrol tank if so what would you want for it.and could you post it thanks chris.
c_dug
PostPosted: 18:24 - 10 Nov 2014    Post subject: Reply with quote
I want the brown petrol tank too!
I'll give you ten shiny pennies and a green m&m!
The last post was made 11 years, 191 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 2.06 - MySQL Queries: 13 - Page Size: 74.43 Kb
