MOT booked for 3pm Tuesday.... (including 1st paint attempt)
MCW
PostPosted: 17:02 - 23 Aug 2013    Post subject: MOT booked for 3pm Tuesday.... (including 1st paint attempt) Reply with quote
....now to work out route:
https://i1355.photobucket.com/albums/q709/MCW999/Route_zps61a44c26.jpg
I can get to the big fat 1. on the map (am paint virgin, be gentle with me) without turning right. If I go the most direct route I will have to turn right at turnings 3. and 4. However, if I go the long way round, I will only have one right turn, on a roundabout at 5.
So. volunteers please, strategically placed along the route to pick me up as I keel over. If you are first-aid trained, so much the better...
Coming back is going to be much harder. Can anyone see a way of getting back to the big fat 1. without turning left right, or will everyone have to hang on at their turnings for the return journey?
Embarassed Embarassed Embarassed
Drake
PostPosted: 17:27 - 23 Aug 2013    Post subject: Reply with quote
why not turn right?
Shaft
PostPosted: 17:37 - 23 Aug 2013    Post subject: Reply with quote
I used to work a stone's throw from 1.
I'm confused, you don't want to turn right on the way there, then you don't want to turn left on the way back.
Obvious route is obvious, take the main road, one right turn there, one left turn back, both at the same roundabout.
MCW
PostPosted: 17:39 - 23 Aug 2013    Post subject: Reply with quote
Ah. I meant right. Brain addled.
Shaft
PostPosted: 17:45 - 23 Aug 2013    Post subject: Reply with quote
OK, that makes more sense.
IIRC, both the right turns on the way back are traffic light controlled, so if you time it right, you'll have a chance to settle before you make the turn and you won't have any oncoming traffic to deal with.
Also, if I may be so bold, why are you even on the road, if you can't make right turns?
New Sarum
PostPosted: 17:48 - 23 Aug 2013    Post subject: Reply with quote
If you do not carry out your own servicing or use another local dealer, have a chat with Vince at VP, he does good work and his prices are reasonable.
Turn 3 is a roundabout ( a big corner!!) and Turn 4 is a traffic light controlled junction; no problem.
PostPosted: 17:49 - 23 Aug 2013    Post subject: Reply with quote
Would you believe I'm STILL rubbish at playing the saxophone even after 35 years?
I've never tried playing one mind.
Carvel
PostPosted: 17:53 - 23 Aug 2013    Post subject: Reply with quote
That.
You sound dangerous.
mysterious_rider
PostPosted: 17:55 - 23 Aug 2013    Post subject: Reply with quote
Yeah agreed if you can't turn right stay off the roads. Or at least practice in a carpark. Shocked
KAWASAKIIIII
mysterious_rider
PostPosted: 17:57 - 23 Aug 2013    Post subject: Reply with quote
https://newsimg.ngfiles.com/268000/268080_0542645855-421862-34547910.jpg
KAWASAKIIIII
P.
Definitely just look where you are going. Lefts are the same as rights. Thumbs Up
MCW
PostPosted: 17:58 - 23 Aug 2013    Post subject: Reply with quote
Shaft, you must be the politest member of BCF. Smile
That's where I'm going for the mot.
Stinkwheel, you are the wisest man I have never met. Wub (Unless you were at the BBQ and I had zoned out by then.)
Drake wrote:
why not turn right?
Carvel wrote:
you sound dangerous
Indeed I am Mr. Green But not usually on a bike....
Sorry, this post obviously didn't come out as tongue-in-cheek as I meant it to. When I first started riding, I went through a short phase of keeling over if I turned right from a standing hill-start. Had the p taken mercilessly about it.
I just liked the idea of lots of BCF brethren in a supportive role getting me to my destination. Sorry. Embarassed
/goes off to brush up on communication skills.... Sad
-Matt-
PostPosted: 18:18 - 23 Aug 2013    Post subject: Reply with quote
Warning - Incoming high quality paint drawing that will blow peoples minds artistically.
Turning right without turning right Thinking May work if traffic is in your favour Razz
https://i41.tinypic.com/fnuxhl.jpg
MCW
PostPosted: 18:23 - 23 Aug 2013    Post subject: Reply with quote
Why is there no karma rating for 'Spectacular Paint Operative'???
-Matt-
PostPosted: 18:24 - 23 Aug 2013    Post subject: Reply with quote
Not to worry, my work sells for millions on the art market Shhh!
SQL
or just turn right.. how teh fook did you even get a CBT.
MCW
PostPosted: 18:27 - 23 Aug 2013    Post subject: Reply with quote
Do keep up... Wink
SQL
PostPosted: 18:28 - 23 Aug 2013    Post subject: Reply with quote
I am rather slow can you explain?
MCW
PostPosted: 18:29 - 23 Aug 2013    Post subject: Reply with quote
Drake wrote:
why not turn right?
Carvel wrote:
you sound dangerous
PostPosted: 18:31 - 23 Aug 2013    Post subject: Reply with quote
Make sure you don't put your feet down though; that would be a test fail for slow speed manoeuvres.
Correct technique:
https://www.youtube.com/embed/PY6Xh5YyfYQ?rel=0&start=29&end=31&autoplay=1
MCW
PostPosted: 18:34 - 23 Aug 2013    Post subject: Reply with quote
Correct technique:
He put his foot down! And I have to confess to being slightly disappointed that he didn't keel over on the right hand ones.... Confused
SQL
PostPosted: 18:35 - 23 Aug 2013    Post subject: Reply with quote
MCW wrote:
Stuff
Fair enough, I got scared by left turns after binning it so I went out and turnt left loads, same with drain covers i nearly crashed hitting one so I kept hitting them until the slight slide was normal.
My advice is go to the MOT by doing the opposite of what you intend.. ONLY turn right.**
** As much as you possibly can.
hedgehugger
PostPosted: 19:16 - 23 Aug 2013    Post subject: Reply with quote
Make right turns, especially on hills, your Bitch! MCW
seriously
Smile
PostPosted: 23:11 - 23 Aug 2013    Post subject: Reply with quote
stinkwheel wrote:
Every savage can turn left.
The last post was made 12 years, 119 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 126.21 Kb
