Hey guys! Having trouble finding a gasket, anyone???
Is this bike a 2000 or 2002?
Yes.
0%
 0%  [ 0 ]
No.
33%
 33%  [ 1 ]
It was a seperate 2000 version.
66%
 66%  [ 2 ]
Total Votes : 3
tidyboy5050
PostPosted: 11:23 - 25 Aug 2013    Post subject: Hey guys! Having trouble finding a gasket, anyone??? Reply with quote
Heya guys, i got my piston sorted Smile)
Im now searching for a CG125Y Gasket set.
Im looking at my V5 paper and it says its a 2002
But
Frame No NMHJC27COYJ101539
Engine No JC30E 1001536
My Dad thinks its a year 2000 (Y)
But yeah ive been off the road AGES now its costing me so much money to fix.
Please if anyone could find a gasket suitable id be so grateful!!!
Smile
Marmalade
PostPosted: 11:26 - 25 Aug 2013    Post subject: Reply with quote
Have you compared the gaskets from both years?
I'd imagine one from a 1980 and a 2010 would still be the same, the engines have changed very little.
yen_powell
PostPosted: 11:35 - 25 Aug 2013    Post subject: Reply with quote
Most Hondas have a sticker saying which model they are, bikes can get registered any time after manufacture so plate not always a good guide.
On most of my Hondas it's been a white label on the frame under the seat.
XT1200Z and a DR350 in bits
bren_9311
PostPosted: 11:44 - 25 Aug 2013    Post subject: Reply with quote
Is there really a need to have a poll? Rolling Eyes
My opinion is neither copyrighted nor trademarked. If you like, I'll trade for one of yours.
Currently bikeless. Sad
Ps4- bren_9311
jeddy11
PostPosted: 11:52 - 25 Aug 2013    Post subject: Reply with quote
Hand make them lovingly from cereal boxes...
Fuelly My Z1000SX
cbt 06/08/11 mod1 (second go) 01/08/12 mod2 21/09/12
Varadero Viking YBR125>Varadero125>ER6F>Z1000SX !!!
tidyboy5050
Because this bike has a electric start and kick start - the gasket set for this bike is possibly different, also this model was supposedly made for 1 YEAR and that was in 2000.
It took us 2 weeks to track down a piston maybe longer.
So I need every bit of help
Smile
Marmalade
PostPosted: 12:00 - 25 Aug 2013    Post subject: Reply with quote
You need to get out of bike specific parts mentality.
For a piston, you could take it to someone that does rebores and proper mechanics or just has parts and knows what to do with them, like piston-broke in Bristol, hand over piston and say "can I have one like this please" Out with a vernier calliper to measure it and pick one off the shelf
It might be the same piston (just as an example) as a yzrdcbz600.
Your gasket set for the cg could well be the same as a chunglee chang Lbw125. Look around, get parts quickly, cheaply and easily with just a little research.
bren_9311
^You have your answer right there, but why not see what people comment your always going to get dicks like me who just click any random answer for the sake of it Thumbs Up
Ps4- bren_9311
tidyboy5050
PostPosted: 12:05 - 25 Aug 2013    Post subject: More problems.. Reply with quote
Also there is a loud mechanical noise coming from valve gear.
Valves snap shut after coming off cam??
Following items have been checked....
Valve Clearance 0.003
Cylinder Rebore 0.50' oversized
Is it a possibility that the Cam Shaft gear is badly worn or broken.This could cause excessive backlash forcing the valve springs to push the cams in the direction of rotation(once lifted) hence causing the the loud mechanical noise when valves quickly return to their seats Shocked
Smile
Marmalade
PostPosted: 12:06 - 25 Aug 2013    Post subject: Reply with quote
This is also a good answer, you can also buy gasket paper if you feel the need but cereal box works well.
I used a red bull cardboard wrap to make a thermostat housing gasket in the depths of Germany to get me out the poo and it was still there workingwhen I sold the vehicle a few months later.
tidyboy5050
PostPosted: 12:10 - 25 Aug 2013    Post subject: Reply with quote
Would you recommend a place to get them?
Also i would prefer the real thing!!
Thanks for your help, lets hope more people get in touch. Thumbs Up
Smile
Marmalade
PostPosted: 12:16 - 25 Aug 2013    Post subject: Reply with quote
This is your problem.
The real thing is often hard to get and almost always double the price of somethingthat is just as good.
I do 1000 a WEEK on bikes that have bits that will do the job. I only visit the dealer for specific bits that are just not available elsewhere.
One of my bikes has an engine out of a different make of bike, I use car engine oil, my pan european has a ford cortina air filter in it, the front rear pads are front pads from a different bike and the clutch slave gasket is something i hashed together.
It has saved me a fortune.
Making a gasket will cost you nothing but a little time, if it is no good. (which would be your making of it rather than anything else) then make another or go buy one.
Matt-
PostPosted: 12:33 - 25 Aug 2013    Post subject: Reply with quote
As mentioned above, making your own one out of a cereal box Is a good option, or buy some gasket sheets off eBay.
It can't be that hard to source a gasket for a cg Very Happy
RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010
Im-a-Ridah
PostPosted: 12:37 - 25 Aug 2013    Post subject: Reply with quote
Head gasket, base gasket, crankcase main gasket are the only ones that really matter, though there may be another depending on bike. The vast majority can be done with cardboard or gasket paper, just leave a bit of extra around the edges when you cut it out, and tack it in place with grease.
CestrianX
PostPosted: 13:00 - 25 Aug 2013    Post subject: Reply with quote
I remember making a head gasket for my mates TS50's 65cc kit from a Kellogs box when I was 17, worked a treat and don't ever remember changing it afterwards. I think a smear of red gasket squidge was used too.
Im-a-Ridah
PostPosted: 19:17 - 25 Aug 2013    Post subject: Reply with quote
There's no reason it won't work sometimes, it's just that the thickness can be critical as you change the squish, and so can increase the compression ratio or risk piston contact with the head.
mudcow007
PostPosted: 13:18 - 26 Aug 2013    Post subject: Reply with quote
is the model of the engine now stamped on the left hand side by the gear shifter?
mine is....?
lihp
PostPosted: 15:29 - 26 Aug 2013    Post subject: Reply with quote
Are you sure on that VIN number?
The vin data I have for CG125 that VIN number doesn't exist
orac
PostPosted: 16:22 - 26 Aug 2013    Post subject: Reply with quote
no they are different, a friend rebuilt a guy cg doing the same think, it kept pump oil out of the breather due to the differences
The last post was made 13 years, 41 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.21 Sec - Server Load: 1.14 - MySQL Queries: 15 - Page Size: 109.22 Kb
