Fitting Heated Grips: Top Tip
McJamweasel
BCF Junkie
PostPosted: 22:02 - 11 Dec 2004    Post subject: Fitting Heated Grips: Top Tip Reply with quote
If you are having trouble getting one to slide onto the bar, instead of stuggling for ages trying to force it on with a rubber mallet and warm water - switch them on and walk away for a few minutes.
Et voila - fitted grips. Thumbs Up
mchaggis
PostPosted: 22:04 - 11 Dec 2004    Post subject: Re: Fitting Heated Grips: Top Tip Reply with quote
You reckon that'd work for fitting normal grips too, just stick a wraparound heated grip over the top?
I must not be a troll...
Mmmm, Guinness
McJamweasel
BCF Junkie
PostPosted: 22:10 - 11 Dec 2004    Post subject: Reply with quote
It may well do, although normal ones tend to be a lot more flxible than these heated ones I was fitting.
Jon
Anyone for donuts?
PostPosted: 22:12 - 11 Dec 2004    Post subject: Reply with quote
How are you finding the heated grips? Tempted in buying some this Winter.
Flip
PostPosted: 23:08 - 11 Dec 2004    Post subject: Reply with quote
Hair spary is a top tip for normal grips, they slide straight on and stay put when dry Thumbs Up
True Blue
PostPosted: 23:09 - 11 Dec 2004    Post subject: Reply with quote
I'm tempted myself, I'd be interested to know what you think of them.
Past >>>> Honda NSR 125 >>>> Suzuki GSXR 600 K1 >>>> Suzuki GSXR 600 K4 >>>>Kawasaki Z1000 DAF >>>>Suzuki RMZ 250 >>>> Current >>>> KTM Superduke R 1290 >>>>
Tarmacsurfer
PostPosted: 23:31 - 11 Dec 2004    Post subject: Reply with quote
Use heated grips with a decent set of bar muffs and they're well worth it Thumbs Up
I'm immortal. Well, so far.
WildGoose
White Van Man
PostPosted: 00:02 - 12 Dec 2004    Post subject: Reply with quote
cant fault the oxford hot grips
altho i never used the glue, and now the left grip slips round the bar when warm, but its not a big problem, once you work out why your clutch lever isnt coming back all the way Razz
ive been wearing my summer gloves since i fitted them, its ace Very Happy
Ian (GPX)
PostPosted: 04:36 - 12 Dec 2004    Post subject: Reply with quote
I got the Oxford temp controlled grips on both my bikes and I can say that they have saved my fingers a few times when it's been very cold out in the country side late at night. They have a small dial that you can turn to adjusts the heat.
Best thing I've added to my bike(s) I can tell ya.....
Azmodeus
PostPosted: 13:09 - 12 Dec 2004    Post subject: Reply with quote
On a similar note:
Ive got some replacement grips coming in the mail, as my old ones are torn at the edges (previous owner had an off).
Do you just yank the old ones off, or is there more to it than that?
mrchips
PostPosted: 13:47 - 12 Dec 2004    Post subject: Reply with quote
Twist and pull them and they should come off. Maybe get the fairy liquid if you're really stuck. As for putting new grips on, I find if you soak them in boiling water for a few minutes they just slip on, and tighten up again as they cool.
Northern Irish? www.nibikers.com
Azmodeus
PostPosted: 13:53 - 12 Dec 2004    Post subject: Reply with quote
Ok, sounds good.
No risk of say... breaking the throttle grip if I twist it too far/hard?
McJamweasel
BCF Junkie
PostPosted: 21:37 - 12 Dec 2004    Post subject: Reply with quote
I've not tried them yet as you're supposed to leave them for 24 hours for the glue to set. I'll let you know tomorrow after I've tested them with my commute.
pipnet11
PostPosted: 23:14 - 12 Dec 2004    Post subject: Reply with quote
For getting old grips I always cut them off as they are going in the bin anyway. Svaes a lot of effort.
I love the girls that do, I hate the girls that dont, I hate the girls who say they will and then they say they wont, but the girl I like most of all and I think youll say Im right, is the girl who says she never has but looks as though she might. - Max Bygraves
Azmodeus
PostPosted: 23:18 - 12 Dec 2004    Post subject: Reply with quote
Yeah, thats true, but I was hoping to keep my old ones as... well... I dunno, but im sure I could find a use for them. Dick warmers maybe... Confused
Marc_Buck
PostPosted: 23:19 - 12 Dec 2004    Post subject: Reply with quote
One slash with Stanley and the're a gonner. Thumbs Up
94 fzr600r
TiN
Pocket Tin
PostPosted: 01:13 - 13 Dec 2004    Post subject: Reply with quote
McJam - so you apply the glue after they have warmed up? I might contemplate the idea of heated grips this winter...
TiN
dotgems.net
EuropeanNC30R...
Gay Hairdresser
PostPosted: 15:13 - 13 Dec 2004    Post subject: Reply with quote
Think the idea is to apply the glue 24 hours before they warm up, to give it time to bond etc.
My oxford heated grips were a right b@stard to fit. Had to spend a couple hours sanding down the clip-ons as they both had slight dings in them and the grips wouldn't slide on.
R6Armadillo
PostPosted: 16:54 - 13 Dec 2004    Post subject: Reply with quote
Another vote for hairspray, my throttle grip started slipping recently. Removed it and reapplied using hairspay, it went on very easily and hasn't moved since.
The last post was made 21 years, 323 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.14 - MySQL Queries: 13 - Page Size: 100.09 Kb
