Diagnostics kits
dransy
PostPosted: 21:06 - 02 Sep 2013    Post subject: Diagnostics kits Reply with quote
Having problems with missus fabia , fucking power steering shite failed MOT today
https://www.ebay.co.uk/itm/Skoda-Fabia-Octavia-Superb-VAG-CAN-BUS-Fault-Code-Reader-Scanner-diagnostic-tool-/221071868904
Anyone used one of these or something alike and are they any good?
Had all the scensors off the pump and the one on the steering rack , checked the fluid level , the PAS is working but stops every now and then when still so was gonna try one of these before i go replacing parts!
Nobby the Bastard
Harley Gaydar
PostPosted: 21:15 - 02 Sep 2013    Post subject: Reply with quote
Jeezus, I need to stop drinking so much.
Read that as you were having problems with your missus labia...
Triumph Sprint ST 1050
Aff
PostPosted: 21:30 - 02 Sep 2013    Post subject: Reply with quote
Those generic readers are never very good at reading codes from VAG cars.
Buy one of the Chinese copy VAG-COM leads and download VCDS Lite, you can do most things with it.
Electric Bike Project
dransy
PostPosted: 21:33 - 02 Sep 2013    Post subject: Reply with quote
Is that one of those? https://www.ebay.co.uk/itm/OBD2-II-Diagnostic-Cable-USB-for-Skoda-Octavia-MK1-MK2-/270657165120
Aff
PostPosted: 21:40 - 02 Sep 2013    Post subject: Reply with quote
Yep, they are all the same so get the cheapest you can.
You will almost certainly have issues with drivers, if you do have any problems, give me a shout because I've probably come across them, and I have 4 different laptops running various versions at the moment, all of which took an effort to get working. Laughing
Nb
PostPosted: 22:17 - 02 Sep 2013    Post subject: Reply with quote
That ebay shit wont help you, as has been said vcds lite would read the power steering codes which can point you in the right direction.
The genuine vcds is only 285 anyway, so cheap for what is near dealer level diagnostics.
Aff
PostPosted: 22:21 - 02 Sep 2013    Post subject: Reply with quote
You can get full VCDS for $99 with a 3rd party lead.
t121anf
PostPosted: 22:29 - 02 Sep 2013    Post subject: Reply with quote
How much??? My full vcds was about £30…but copies are poor and far from "full" (my car was quite a new model/variant at the time.
Nb
PostPosted: 22:41 - 02 Sep 2013    Post subject: Reply with quote
https://www.ilexa.co.uk/acatalog/vagcom.html second one down we use, never had much luck with copys. You can easily make mistakes with vcds on certain models if you dont know what you are doing.
jimspeed
PostPosted: 22:44 - 02 Sep 2013    Post subject: Reply with quote
I would think you are going to need a pump by the sounds of it if the wiring checks out ok (big earth wire gives problems) I work at a Skoda specialist (ex dealer), the racks fill with water where the sensor fits and that knackers the sensor, or water wicks down the wiring into the pump unit and shorts the ecu out inside it.
get yourself one of these,
https://www.ebay.co.uk/itm/Vag-Com-Vcds-11-11-1990-2013-Hex-Can-Usb-Latest-FULL-2013-/251330028878?pt=UK_Diagnostic_Tools_Equipment&hash=item3a846fe54e
works a treat (we have 2 genuine vcds leads and one of these) and it should give a few pointers but internal errors are common on pre 2004 units.
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
dransy
PostPosted: 23:15 - 02 Sep 2013    Post subject: Reply with quote
All the connections seem fine also checked the one on the steering rack cant afford a brand new pump so going to have to try some scrappers!
jimspeed
PostPosted: 15:56 - 03 Sep 2013    Post subject: Reply with quote
Laughing same pump on 9N polo and ibiza too mate plenty about on ebay
Yoyo This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
MattEMulsion
PostPosted: 08:18 - 04 Sep 2013    Post subject: Reply with quote
I've got an Autel Maxiscan MS309 as a generic code reader and it is quite good as a basic device. Don't forget though that these generic basic OBD2 code readers only read present fault codes and generally if the engine management light isn't on or hasn't been on, there will be no code for it to read.
Yamaha YZF-R6
prawny1
PostPosted: 13:16 - 04 Sep 2013    Post subject: Reply with quote
The boggo fault code readers are good for clearing codes which is often the biggest issue when cars play up because sometimes the cars just get all stubborn while a code is stored and won't work again until you get it cleared.
They read basic management codes but that's it, nothing brand or model specific and they don't do abs, airbags, steering etc.
The usb leads hardly work with any software, the vagcom ones are good but the opcom/vauxcom ones are a pain in the arse if you get the wrong type of lead.
hellkat wrote:
dransy
PostPosted: 13:20 - 04 Sep 2013    Post subject: Reply with quote
Would I be best just to take it to a garage and tell them to clear the codes and then get a pump ?
prawny1
PostPosted: 13:31 - 04 Sep 2013    Post subject: Reply with quote
Does the car have one of those city steering type buttons where you can turn power assistance up or down? could be a fault in that.
If it is powered by an electronic pump, check the wiring to it and check the fuse isn't blown (sometimes they just break and lose contact intermittently) had it with a Peugeot last year the steering would randomly shut off and we would have to get it cleared at Peugeot found out that was down to a dodgy fuse..
Nb
PostPosted: 15:42 - 04 Sep 2013    Post subject: Reply with quote
Why not take to someone with vcds and get them to take a look? Probably cost 30 quid or there abouts, if you were nearer me id take a look for nowt.
The last post was made 13 years, 47 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.04 - MySQL Queries: 13 - Page Size: 100.4 Kb
