Car handbrake cable (yes, sorry!)
cb1rocket
PostPosted: 23:52 - 02 Sep 2013    Post subject: Car handbrake cable (yes, sorry!) Reply with quote
I have my mondeo up for mot soon in 2 weeks and despite replacing the rear brake shoes in the drums and resetting the auto adjust, the handbrake still comes up too far and will fail (was an advisory)
https://www.ebay.co.uk/itm/2mm-3mm-4mm-5mm-Simplex-Wire-Rope-Grip-Cable-Clamp-316-A4-Marine-Stainless-/390641496919?pt=UK_Sporting_Goods_Sailing&var=&hash=item5af40c3357
Rather than new cables would the above work to put on the cable end stopper? Or is there a better idea? I don't want to go stripping the old cables off and fitting new if there is a quicker, and successful bodge job that can be done?
Walloper
PostPosted: 00:44 - 03 Sep 2013    Post subject: Re: Car handbrake cable (yes, sorry!) Reply with quote
Pale
It's the brakes man... Ye canny fcuk with brakes. Very Happy
A local garage wouldn't charge to too much to fit a cable. £50 ???
heapy
PostPosted: 00:59 - 03 Sep 2013    Post subject: Reply with quote
sometimes the auto adjuster sticks but you can turn it with a screwdriver and set it manually it takes a bit of pratting cos thers a lip on the drum so it has to be tighter than you think and tap it on with a mallet if its not tight enough take it off an give it some more, hope this helps
if it has 2 wheels and an engine its a bike
cb1rocket
PostPosted: 09:01 - 03 Sep 2013    Post subject: Re: Car handbrake cable (yes, sorry!) Reply with quote
I was quoted 175 just for my van handbrake cables Shocked
It's the handbrake not the actual brakes I'm fannying about with Laughing
YBR Ric
PostPosted: 09:32 - 03 Sep 2013    Post subject: Reply with quote
From memory from underneath my Mondeo, it had a single cable between the handbrake leading to a twin pull bar and then two single cables back from there, one to each side.
Never did need to adjust them, but on some cars I've owned there was an adjuster to be found underneath the handbrake gaiter to take up the cable slack and to lower the bite point of the handbrake arm itself.
cb1rocket
PostPosted: 09:39 - 03 Sep 2013    Post subject: Reply with quote
Yes the idea is too shorten that cable by putting a stopper further forward than where the original crimped on stopper is. Guess I will get the car on the ramp and have a look, cheers
Robby
Dirty Old Man
PostPosted: 14:31 - 03 Sep 2013    Post subject: Reply with quote
Is there an adjuster at the handle end?
Usually the auto-adjusting part of the handbrake is down at the business end, where it adjusts a small amount to account for wear in the shoes and to keep both sides balanced if one is wearing more than the other. You then have a manual adjuster at the handle to adjust how far you have to pull it, and to cope with the cable stretching.
If you don't have an adjuster at the handle end, a really dirty bodge is to wrap a loop of cable around a bolt and clamp it down hard with a nut.
bikenut
PostPosted: 15:47 - 03 Sep 2013    Post subject: Reply with quote
hi robby aint that an mot fail??
is there a plastic nut by the cable stop on the bodywork that will effectively change the outer cable length, so adjusting the cable...
care to comment on your thread about old and new stuff, mainly how the **** are the gears held in gear??
nice to have you back robby......... :D
nuts about bikes
PostPosted: 15:49 - 03 Sep 2013    Post subject: Reply with quote
Wrap in tape/cover in dirt.
Walloper
PostPosted: 16:44 - 03 Sep 2013    Post subject: Re: Car handbrake cable (yes, sorry!) Reply with quote
You need to find a cheaper garage. Smile
The hand brake is actually the Emergency Brake. Shocked
PostPosted: 16:46 - 03 Sep 2013    Post subject: Re: Car handbrake cable (yes, sorry!) Reply with quote
Is it? Where does it say that? Pretty sure its the parking brake.
heapy
PostPosted: 18:47 - 03 Sep 2013    Post subject: Re: Car handbrake cable (yes, sorry!) Reply with quote
r sorry thought you ment the adjuster wasnt tightening up properly
cb1rocket
PostPosted: 23:45 - 03 Sep 2013    Post subject: Reply with quote
Hidden by the exhaust heat shield Laughing
bikenut
PostPosted: 09:54 - 04 Sep 2013    Post subject: Reply with quote
self adjusting front cable as well as at the rear back plate and internals........
nuts about bikes
cb1rocket
PostPosted: 18:55 - 04 Sep 2013    Post subject: Reply with quote
I have the exact manual, where does it say self adjusting for front cable?!
bikenut
PostPosted: 14:17 - 05 Sep 2013    Post subject: Reply with quote
try looking at the next page in your book.......
nuts about bikes
cb1rocket
PostPosted: 23:22 - 05 Sep 2013    Post subject: Reply with quote
Thanks, maybe possible that the front pawl has seized up, or totally out of adjustment cheers
bikenut
PostPosted: 10:34 - 06 Sep 2013    Post subject: Reply with quote
:D you saw it then........
maybe the pawls are worn out and scipping or perhaps the cable nipples ( keep it clean ) have popped out.............
no need for a pic as we all know what nipples look like.....scammel wheel nuts! :D
nuts about bikes
cb1rocket
PostPosted: 23:06 - 07 Sep 2013    Post subject: Reply with quote
Thanks to all who helped, sorted the cable in the end by cutting off the nipple and soldering a nut on further up the cable Laughing
The last post was made 12 years, 206 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 103.08 Kb
