Improving the efficiency of the 4 stroke motor...?
jjdugen
PostPosted: 10:24 - 03 Sep 2013    Post subject: Improving the efficiency of the 4 stroke motor...? Reply with quote
Going to get a bit 'Teff' on you all. I've been looking at various methods of making more power from the 4 stroke engine and came up with this thought. Not found anything similar after a long search on the Google, but if its been tried before I'd like to know the outcome. At least its been published so I can claim ownership if BMW try to steal it!
The idea follows from the 2-strokes auxiliary ports found in most performance engines. There they have a 'blind' port in the barrel that adds a squirt of fuel during the combustion process. As far as I can tell, no-one has thought of putting just such an auxiliary port into a 4 strokes barrel.
1. Shows the piston on compression stroke, filling both cylinder and aux port with compressed mixture.
2. Shows piston at TDC the normal above piston mixture ready for combustion and the aux port covered / blanked by the piston skirt.
3. Shows the normal fuel combustion cycle.
4. Shows the aux port uncovered, the compressed mixture now combining with the spent but hot combustion gases, adding an extra combustion process, a double bang if you like.
5. Shows the normal exhaust stroke, poppet valve open.
6. Shows the rotary valve in the aux chamber open to purge the aux chamber of burnt gases.
Once the induction stroke occurs, aux chamber rotary valve closes to allow fresh mixture to fill the cylinder.
Anybody got the odd million or two spare for development costs?
Cheers.
PostPosted: 10:50 - 03 Sep 2013    Post subject: Reply with quote
I've seen a similar thing to this before... it was on an old episode of Top Gear IIRC.
Kris
PostPosted: 11:04 - 03 Sep 2013    Post subject: Reply with quote
Suzuki do this with air using their PAIR system.
www.prisonplanet.com
Aff
PostPosted: 12:11 - 03 Sep 2013    Post subject: Reply with quote
Doesn't the PAIR system just add fresh air from the airbox directly into the exhaust to help emissions?
Also I think I've read about something similar before called the Elywood Hybrid or something.
Electric Bike Project
sickpup
Old Timer
PostPosted: 12:19 - 03 Sep 2013    Post subject: Reply with quote
First of all rotary valves have the problem that they don't seal very well in the presence of high temperatures, this is why engines still have the valve arrangement that they have.
Your idea has been used for decades by the use of accelerator pump carbs and now by pressurised fuel injectors, what advantages does your system have over those considering it is more complex and more prone to raising hydrocarbons in the exhaust gasses?
As you are injecting an additional measure of fuel why do you think it makes the engine more efficient?
The engine you have designed is inherently inefficient as the fuel and exhaust inlets have an almost 90degree bend in them. Inclining the engine so as to use a down draught design would mean you can increase the velocity of the inlet charge especially at high revs meaning you could achieve volumetric efficiencies of over 100%.
P.
PostPosted: 12:34 - 03 Sep 2013    Post subject: Reply with quote
https://img.pandawhale.com/44059-are-you-a-wizard-Ls0H.jpeg
sickpup
Old Timer
PostPosted: 13:38 - 03 Sep 2013    Post subject: Reply with quote
Psst Paddy, what do you thing a Turbo or Supercharger does?
Wink Thumbs Up
jjdugen
PostPosted: 13:51 - 03 Sep 2013    Post subject: Reply with quote
Hi,
First off, as mentioned, PAIR type systems are just a way of putting fresh air into the exhaust gases to 'clean them up' a bit.
Second, treat the diagrams as an explanation, not the finished article. Down draughting the carbs / injectors is a given, as would be all the latest multi valve and high compression ratio tricks.
I take the point about emissions, but this will be a low compression secondary burn, so won't generate the nasty stuff of a very high comp burn.
My 'logic' on this was that most of the energy from the initial ignition dissipates over the first eighth of the pistons down-stroke, this would add an extra bit of gas expansion beyond that.
Only direct injection would allow for high pressure filling of the cylinder, and is high quality engineering.
I do take the point of rotary valve sealing, it might not actually need a vent to atmosphere, that will need investigating with the million or two development money!
Unlike turbos that need sufficient engine speed to work, or superchargers that are a mechanical drain on power produced, this is neither rev dependent nor requires the complexity of mechanical devices.
sickpup
Old Timer
PostPosted: 13:54 - 03 Sep 2013    Post subject: Reply with quote
I suspect you have that the wrong way around.
P.
PostPosted: 14:12 - 03 Sep 2013    Post subject: Reply with quote
Wink Thumbs Up
Turbo
Buuuuuuur PSHHHHH
and
Supercharger
Wizzy wizz wizz
That is about all I know. Laughing
P.
PostPosted: 14:50 - 03 Sep 2013    Post subject: Reply with quote
Would love some deadly TL. Add le turbo to a V twin though, doesn't look fun.
Varadero with chinese turbo and 5hp nos though. Sort me out Iain.
PostPosted: 19:02 - 03 Sep 2013    Post subject: Reply with quote
Not sure how much it would help.
The timing should already be set up so that the most useful amount of burning mixture occurs at the best time to turn the crank. If the mixture is burning too soon and too fast then just use more retarded ignition and a shorter stroke.
To me it looks like it is just going to suddenly lower the cylinder pressure as the port is uncovered at the time you want the pressure to be fairly high, pushing down on the piston and turning the crank, and only gaining a small amount back when that low pressure mixture does burn.
While the extra exhaust port might help, not sure how much. Exhaust valves and ports are treated as less important than intakes as there is little to gain there.
lihp
PostPosted: 19:13 - 03 Sep 2013    Post subject: Reply with quote
How do you propose to open and close the rotary valve?
Walloper
PostPosted: 19:32 - 03 Sep 2013    Post subject: Reply with quote
My most favourite emission is the day after a really 'Hearty Curry and Guinness' evening.
Nobby the Bastard
Harley Gaydar
PostPosted: 19:35 - 03 Sep 2013    Post subject: Reply with quote
Surely the pressure of the 'bang' would push the unburnt mixture into the area where the secondary valve is, preventing any extra boom out where the piston is and actually lower the power you achieve...
Triumph Sprint ST 1050
Walloper
PostPosted: 19:58 - 03 Sep 2013    Post subject: Reply with quote
Here is the bottom line on it.
Invention is all good and well. Application is another thing.
As Sickpup has clearly illustrated, sealing would be an issue.
Most of what can be done to squeeze the energy out of petrol has been done. As far as burning it goes.
If anyone wants to 'have a go' at improving efficiency then they need look at reducing thermal and frictional losses which make up about 60% of energy waste/inefficiency.
That's where the money is.
lihp
PostPosted: 20:10 - 03 Sep 2013    Post subject: Reply with quote
If this was a legit way of increasing efficiency they would be doing it with F1 and MotoGP engines where they have the worlds best engineers, with the worlds leading technology and are restricted on fuel level.
If it was worthwhile it would have probably been done.
1cyl
PostPosted: 20:26 - 03 Sep 2013    Post subject: Reply with quote
I admire your dedication OP.
But I'd advise channeling your mental invention energy into electric motors or more specifically the battery's. If you can nail the lightweight, huge power, long lasting, fast charging, cheap costing dilemma, then you'll do us all a favour.
The internal combustion engine is gonna have to go before this century is out, otherwise, we fail.
Chase my Witch up, Catch my Snitch up.
The SMC | The Pit | Stable
Walloper
PostPosted: 20:32 - 03 Sep 2013    Post subject: Reply with quote
The man who determined Longitude was an English carpenter who had an interest in making time pieces.
His first chronometer was made entirely of wood.
His devices were continually rejected for the King's Prize over many years.
Intervention of the Royal Navy saved the day for him.
His invention was one of the most important things of the modern age.
He was an amateur and uneducated man as far as the establishment were concerned.
lihp
PostPosted: 21:00 - 03 Sep 2013    Post subject: Reply with quote
Not entirely relevant.
If the dude had improved on 100s of years of the best technology of watches, say an atomic clock. With nothing made of wood then we are close to what I proposed.
This is not something new, but an improvement of something that is at a ridiculous level in terms of knowledge and understanding
jjdugen
PostPosted: 08:38 - 04 Sep 2013    Post subject: Reply with quote
Battery powered vehicles are the same dead end that steam engined cars were. Electric vehicles may be a future solution, but only when all roads have induction loops under the surface. I still think Hydrogen On Demand (HOD, great acronym), engines will prove the more usable solution, once I can find the right frequency / voltage to excite and crack water molecules, (I've been here before and got shot down in flames).
IF I could find any reference to this system being tried and any results, I would be studying them, but I have trawled t' interweb and can find no mention of anything like this system. As I have said, if anyone has found any relevant data that applies I would be glad to see it.
lihp
PostPosted: 08:43 - 04 Sep 2013    Post subject: Reply with quote
Hyundai currently sell a hydrogen car
Tarmacsurfer
PostPosted: 09:13 - 04 Sep 2013    Post subject: Reply with quote
Paddy. wrote:
Picture aimed @Sickpup
Bastard. That made me choke.
Possibly the funniest (and most apposite) thing I've seen on here in months, if not years Laughing
I'm immortal. Well, so far.
The last post was made 12 years, 160 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 2.14 - MySQL Queries: 13 - Page Size: 136.79 Kb
