| jjdugen |
 jjdugen World Chat Champion
| MarJay |
 MarJay But it's British!
| Kris |
 Kris World Chat Champion
 Posted: 11:04 - 03 Sep 2013 Post subject: |
Suzuki do this with air using their PAIR system. ____________________ NSR125RR - ZXR750H1 - ZX9R E1 - GSF600S - GSF600SK3 - VFR400-NC30 - SV1000N - ST1100-R - CBR900RR-R - GSF1200SK5 - GSF600SK1 - VFR1200FA - GSXR1000K2 - ZZR1400 D8F
www.prisonplanet.com |
| Aff |
 Aff World Chat Champion
| sickpup |
 sickpup Old Timer
| P. |
 P. Red Rocket
| sickpup |
 sickpup Old Timer
 Posted: 13:38 - 03 Sep 2013 Post subject: |
Psst Paddy, what do you thing a Turbo or Supercharger does?
| jjdugen |
 Posted: 13:51 - 03 Sep 2013 Post subject: |
Hi,
First off, as mentioned, PAIR type systems are just a way of putting fresh air into the exhaust gases to 'clean them up' a bit.
Second, treat the diagrams as an explanation, not the finished article. Down draughting the carbs / injectors is a given, as would be all the latest multi valve and high compression ratio tricks.
I take the point about emissions, but this will be a low compression secondary burn, so won't generate the nasty stuff of a very high comp burn.
My 'logic' on this was that most of the energy from the initial ignition dissipates over the first eighth of the pistons down-stroke, this would add an extra bit of gas expansion beyond that.
Only direct injection would allow for high pressure filling of the cylinder, and is high quality engineering.
I do take the point of rotary valve sealing, it might not actually need a vent to atmosphere, that will need investigating with the million or two development money!
Unlike turbos that need sufficient engine speed to work, or superchargers that are a mechanical drain on power produced, this is neither rev dependent nor requires the complexity of mechanical devices. ____________________ The CBR900RR has been sold. Aprilia Falco worms its way into my heart.
| sickpup |
 sickpup Old Timer
| P. |
 P. Red Rocket
 Posted: 14:12 - 03 Sep 2013 Post subject: |
| _Iain_ |
 _Iain_ Banned
| P. |
 P. Red Rocket
| _Iain_ |
 _Iain_ Banned
 Posted: 19:02 - 03 Sep 2013 Post subject: |
Not sure how much it would help.
The timing should already be set up so that the most useful amount of burning mixture occurs at the best time to turn the crank. If the mixture is burning too soon and too fast then just use more retarded ignition and a shorter stroke.
To me it looks like it is just going to suddenly lower the cylinder pressure as the port is uncovered at the time you want the pressure to be fairly high, pushing down on the piston and turning the crank, and only gaining a small amount back when that low pressure mixture does burn.
While the extra exhaust port might help, not sure how much. Exhaust valves and ports are treated as less important than intakes as there is little to gain there.
| lihp |
 lihp World Chat Champion
| Walloper |
 Walloper Super Spammer
| Nobby the Bastard |
| Walloper |
| lihp |
| 1cyl |
 1cyl World Chat Champion
 Posted: 20:26 - 03 Sep 2013 Post subject: |
I admire your dedication OP.
But I'd advise channeling your mental invention energy into electric motors or more specifically the battery's. If you can nail the lightweight, huge power, long lasting, fast charging, cheap costing dilemma, then you'll do us all a favour.
The internal combustion engine is gonna have to go before this century is out, otherwise, we fail. ____________________ Chase my Witch up, Catch my Snitch up.
The SMC | The Pit | Stable |
| Walloper |
| lihp |
| jjdugen |
| lihp |
| Tarmacsurfer |
The last post was made 12 years, 161 days ago. Instead of replying here, would creating a new thread be more useful? |
