Are 929 Fireblades unreliable?
Chilled76
PostPosted: 16:17 - 03 Sep 2013    Post subject: Are 929 Fireblades unreliable? Reply with quote
Hiya folks,
Been reading a few horror stories on here about problems with reg/rectifiers and alternators on 929's.
Dodgy earths and various other electrical issues....
My question is, are they really that much more unreliable than a comparable age and mileage CBR600? I mean they are built by Honda, i'd expect better build quality than what reading a few threads on here are leading me to believe.
I've found a nice example for the right money and thought I'd just google a bit of research and came across this forum... if I'm honest it has nearly put me off buying the bike...
Any advice/info would be much appreciated, thanks in advance.
Paul
j.silvs
PostPosted: 16:19 - 03 Sep 2013    Post subject: Reply with quote
Tbh if ere are electrical gremlins all you need to do is find a guy who's amazing at electrics to get it sorted.
Wouldn't let it put you off.
Electrical issues tell me it was a Friday afternoon bike. You might buy a Tuesday morning one
supZ
PostPosted: 16:30 - 03 Sep 2013    Post subject: Re: Are 929 Fireblades unreliable? Reply with quote
Chilled76 wrote:
Hiya folks,
reg/rec issues and cam tensioner issues are universal amongst hondas but nothing to worry about.
I've certainly not heard any 'horror' stories other than that realisation that you should have got a 954 Wink heh
CBR954RR - Daily toy
CBR600RR - Trackbike
jjdugen
PostPosted: 17:27 - 03 Sep 2013    Post subject: Reply with quote
929's do have an issue with the wiring loom. A large number of earths are gathered into a block inside the loom, just under the tank. Once these start to verdigris it gives rise to all sorts of wierd electrical faults from instrument clusters going erratic, lights and indicators not working properly to actual miss fires or failure to start.
But, a very easy fix with a good soldering iron and an hour or so unpicking the loom and making the earths good.
My info is that the alternator is fine on the 929, its the 954 onwards that causes problems.
Treat OEM reg/recs as a consumable item, replace with R1 - Fazer 1000 units, much better design (Mosfet current limiter, not current dump).
CCT's don't seem to be much of a problem either, very easy fix if it does start to rattle.
Only downer noted is the early F.I. system is snatchy just coming onto throttle, can make trickling along a bit jerky, not really that bad actually.
A bit more power than the earlier carbed 'blades, but not that much faster, does (finally) have a 17'' front wheel and gigantic discs up front. Bit of a rush job on Hondas part to try to catch up to the R1, which it didn't!
Aff
PostPosted: 17:50 - 03 Sep 2013    Post subject: Reply with quote
Don't let it put you off. All of their problems can be avoided or lessened with some preventative maintenance.
Fit a voltage display to warn you when your RR is about to go or your stator starts playing up, this will stop them destroying your loom.
Make sure all of the earths are in good nick too, especially the common earth block (behind the dash, not under the tank).
The CCT rattle can supposedly be fixed with a single M6 bolt, I am yet to test it though. Otherwise just swap it out to an APE MCCT.
The low down fuelling can be completely sorted with a Power Commander.
I love mine, it's a brilliant bike.
Electric Bike Project
Chilled76
PostPosted: 18:08 - 03 Sep 2013    Post subject: Reply with quote
Thanks for the comments folks.
How easy is it to fix a voltage meter and a power commander?
This is going to be my first bike so I've never worked on one before (done a few jobs on cars though but not much electrical).
I'm now probably going to be yelled at by everyone telling me it is too much bike for a first bike... please don't that's not what I've asked advice about.
Aff
PostPosted: 18:28 - 03 Sep 2013    Post subject: Reply with quote
Power commander is just 2 plugs that fit between the ECU and main loom, just need to prop the back of the tank up to get to it.
I wired my volt meter into the power supply for the dash.
The one I use.
:edit: This gives you an idea of where I placed mine:
https://i1135.photobucket.com/albums/m637/Biles/20130827_171147_zps49dbf17e.jpg
Ariel Badger
PostPosted: 18:35 - 03 Sep 2013    Post subject: Reply with quote
Is a 929 Blade a good first bike?
Chilled76
PostPosted: 18:48 - 03 Sep 2013    Post subject: Reply with quote
Aff, thanks for that. Really appreciate it.
Badger... I know it's not everyone's first choice but it's what I want. If it bites me then that's my problem. I've weighed it up and it's only the reliability I am really bothered about looking into now before a purchase.
It's not ideal for everyone as a first bike but for me it makes sense.
I find the CBR600's a bit small, I also would like to use it to do some big mileages on. I want to track it occasionally too. I've got 14 years experience behind a car wheel and have never had an accident so have pretty good road sense.
I've also raced DH mountain bikes to a very high level and spent a bit of time in the air on a mx bike...
Of all the bikes within a 30 mile radius the best example of various offerings that I can afford is a 929... so no probably not the most normal of choices for a first bike but it is something I feel I can behave sensibly with and warm into with time.
swampy
PostPosted: 19:52 - 03 Sep 2013    Post subject: Reply with quote
I do hope that doesn't come back to bite you on the arse... Wink
ThoughtContro...
PostPosted: 21:16 - 03 Sep 2013    Post subject: Reply with quote
Which 'blade was it that Titz had a problem with, where Galvanic corrosion was eating the sump?
Prize cunt
Doovy
PostPosted: 21:25 - 03 Sep 2013    Post subject: Reply with quote
I have summoned him to bequeath us with insight.
The Tot
PostPosted: 21:57 - 03 Sep 2013    Post subject: Reply with quote
Hello, I am here!
The 929 should really have a Ducati sticker on the tank, especially from the Texas Pacific Era! Mine's an RRY so in addition to the issues that have been raised, here's what to check out for.
Arrow Fork Bottom Recall
Honda probably employed some retard metallurgist and got their material specification wrong for the fork bottoms making them susceptible to SCC; Stress Corrosion Cracking - I can't be bothered to explain this on the forum, but effectively, chlorides and other ions + stress loading from the shock movement + susceptible material = brittle fork bottoms. If your bike is affected, as mine was, check that the recall was done.
Now the issues I've had on my bike - in order of cost
Bear in mind I used my bike as RAT rider - It's now on 44k miles, clocking 12k miles a year under my ownership!
Arrow Cam Position Sensor Fault - £500
A bloody dog to diagnose! It throws up no fault codes and won't allow your engine to spark. Typical symptom of an earth fault, so it took a while for the mechanics to trace this down. Sensor itself was £150, most of it was diagnostic labour! So if your bike is fully charged, but won't spark up and not throwing fault codes, this is a common culprit! Has been known to occur on CBR600's too
Arrow : Regulator Rectifier x 3 - £220
2 Reg Recs blew; considering that I also had the alternator rewound/replaced TWICE! The 3rd time, I took sickpups advice and bought an 09 R1 MOSFET reg/rec (shindingen) off ebay. Bypassed the internal charging loom, so my battery is effectively connected to the reg rec and alternator directly - I assumed there was a fault in the loom which I couldn't be bothered to trace down. Problem hasn't recurred in the last 2 years
Arrow Rewound Alternator x 2 - £160
So if your charging system, typically your battery, is throwing wobblers, check the rest of your system! So, my battery was showing 14.3-14.7 V at 5k RPM when I ran my regular checks. This is where a volt-meter wired in directly is a wise mod, especially by being able to tell what sort of juice you're showing up when at >4k RPM
Arrow Earth Fault - £120
I used my bike every day, including in the snow, so this was more of an inconvenience that left me stranded in Oxfordshire! Allow dat! I just don't have the patience to track down wiring faults, so left this one at Branson's honda
Arrow Speedo Fault - £120
I rode to the BCF BBQ with no speedo! Multiple instances of 929 clocks having corrupt EPROM chips leaving your digital display completely blank! Your indicator lights work, but that's all! A known issue, and there's a chap in Kings Lynn that makes a living out of reflashing the EPROM chips - Honda basically tell you to find a replacement clock on ebay if you can, or try scorpio electonics.
Other gripes being that you CANNOT remove your tank! There is no quick disconnect line from the fuel pump. The fuel pump itself does not seal or isolate itself. Swingarm bolts directly to the back end of the crankcase, so bear that in mind when you want to take the bike apart etc.
BUT discounting that, it is probably one of the sweetest handling litre bikes out there! It's a connoisseurs superbike. Chavs went for R1, nutters went for gixxers, and fuddy duddy types went for the ZX-9R.
I treat my 929 like a 600 on roids and the handling is second to none! When the chassis is THAT good, you can make some concessions, like on power. Bike is settled on whatever surface your on. Yes it can get flighty, but rest assured, if you're going THAT fast, you'll be glad you're on a composed 929!
954 is THE blade to get.
FYI, bimetallic corrosion issue was prevalent on 06-07 Fireblades - Honda vehemently refuse to take accountability.
Great bikes, but has its issues. But 929/954 will make you smile more than most because you can use a lot of the bike, a lot of the time.
Quite economical too - 150 to the tank on serious hoons is achievable!
A bit of whoring, but here's my 13 year old Lad - Marco
https://fbcdn-sphotos-g-a.akamaihd.net/hphotos-ak-ash4/998669_10151756606080712_1784622856_n.jpg
Never argue with autism
thelamoth
PostPosted: 22:01 - 03 Sep 2013    Post subject: Reply with quote
The 929's stator has an inherent design flaw, electrex do a fix but you'll pay for it ...
The Tot
PostPosted: 22:05 - 03 Sep 2013    Post subject: Reply with quote
I had mine sent to West Coast Windings - Bransons Honda did deal with Electrix, but changed suppliers when they had numerous quality control issues.
Mechanics said it was a prevalent issue found commonly on 929, 954 and certain '04 First Gen CBR1000RR's
thelamoth
PostPosted: 22:12 - 03 Sep 2013    Post subject: Reply with quote
The assembly which the stator spins in is typically over engineered..too many magnets..hence stator burn out.
Rewinds don't solve it, hence check electrex =)
Plus a quick spray of acf50 on the main earth and block connectors prevents stupid problems...
thelamoth
PostPosted: 22:20 - 03 Sep 2013    Post subject: Reply with quote
P.s....you can remove the tank...just siphon it...
The Tot
PostPosted: 22:52 - 03 Sep 2013    Post subject: Reply with quote
It's a tragic oversight purely because of the amount of overengineering honda have done elsewhere on the bike. It's just a major bugbear to be honest. What i normally do is just put a block of wood under the tank and chock it up, or have it suspended from my garage beams with tie straps. It was a major pain when I didn't have the Torx socket to remove the fuel line when it came to painting the tank.
In all honesty, 954 is the way to go! A much nicer looking bike, 32bit ECU so it's less choppy at lover revs.
When it comes to electrics and electronics, I'm pissing in the wind... Metallurgy, on the other hand is my bread and butter! Bar the SCC issue I eluded to earlier, you're highly unlikely to spot corrosion on the cycle parts and chassis of the bike. I can vouch for that aspect of Honda build quality
Chilled76
PostPosted: 07:05 - 04 Sep 2013    Post subject: Reply with quote
Thanks for such a detailed response, really appreciate the advice.
How do I know if it is an RRY? it just says RR on the log book?
Will a Honda Main dealer be able to tell me if this work has been carried out?
This scares me Sad
Reg/Rec...£220! Is that each or for all three? It's had a new one fairly recently... how long before it goes again?
Again is that each?
Earth Fault - £120
This sounds common
Speedo Fault - £120
Again a scary prospect for a Jap built "reliable" manufacturer
I won't be going that fast, it's going to be my first bike and I WILL treat it with EXTREME caution
I can't afford a 954 and there is a two owner from new 18k example of a 929 in the local garage which has got me looking at them. I prefer the size and position to all the 600cc bikes I've sat on. I think I will be able to do 200 mile trips easier on it and ultimatly it will end up on a track on the occasional weekend hence looking at one of these over a VFR.
How much juice do they hold?
And I guess you've answered my question, seems they are fairly unreliable.. more so than a CBR600 of similar age and mileage?
Aff
PostPosted: 07:54 - 04 Sep 2013    Post subject: Reply with quote
Remember to take into account that Tot has done a lot of mileage, a lot of which has been in bad London winters. I think Tot was a bit unlucky with some things, and some of the prices seem very high because he was paying for dealer diagnostics labour, which is never cheap.
I genuinely don't think they are any more unreliable than any other bike, and with regular maintenance they shouldn't be a problem.
They have common issues, but they are generally common issues to all Honda's of this time period.
Also remember that generally you only hear about it when things go wrong, for instance my 929 is on 28K miles and it still has original CCT, Stator and RR and most of my issues so far have been small electrical problems which required nothing other than my time to fix.
Ultimately it's up to you, if it is a bike you think you want to own, buy one, if it turns out you don't like it a couple of months down the line then sell it, I doubt you will loose that much.
Just make sure before you buy you check as much of the electrical system as possible, I took a multimeter to the dealer when viewing mine so I could check the charging system.
The Tot
PostPosted: 12:53 - 04 Sep 2013    Post subject: Reply with quote
In my case, my bike was an extemely used example. I was putting on 1500 miles a month for 2 years. I got it at 11k miles in 2009. By 2011, it hit 43k! In the last 2 years, I've only done 1300 miles and now lives in a garage.
Most of my issues started at around 30-35K miles. First reg-rec went at 20k, then went again at 38k.
I couldn't afford to have the bike off the road since I needed it for long distance commutes, but I had all the money to let somebody else have a look at it.
If you do less than 8k on it whilst keeping it garaged, then you'll be fine. Mine lived outdoors, uncovered mostly, for 3 years! So, that will explain why my reliabilty has been horrendous!
Juice; it holds 18 litres.
If it's about 30k, get the suspension refreshed to restore its handling! Like i said, brakes and suspension are its stronges points. Brilliant chassis!
The Tot
PostPosted: 13:10 - 04 Sep 2013    Post subject: Reply with quote
Forgot to mention that all the listed prices are cumulative totals.. So reg recs are between £60 for the OEM replacement, to £90 for the shindingen R1 jobbie.
Bear in mind in the noughties, there was a raft of legislation changes etc which affected material/cost choices. Rumour has it that the PCB material changed in that time which caused some early niggles and headaches. Hence why it's better to get 954 where most of the issues have beeb ironed out.
Chilled76
PostPosted: 17:42 - 04 Sep 2013    Post subject: Reply with quote
Thanks once again.
I've got a photocopy of the v5 from the garage.
It's had 1 former keeper who had it from new in March 2001 then the second owner had it from 2004 until he sold it the garage that is now selling it (I'm presuming he wanted a quick sale).
What do you guys make of this MOT history? To me the really low mileage and gaps between MOT expiry tells me it was probably used more as a track bike than on the road?
Registration mark:
I've deleted this
Make/Model:
HONDA / CBR900RR
Colour:
BLACK
VIN/Chassis No:
Deleted
Approximate date of first use:
01/04/2001
Type of fuel:
Petrol
Date of test:
26/06/2012
Certificate issued (Pass)
Odometer reading:
18,480 Miles
Test number:
227128972114
Test expiry date:
25/06/2013
Full Test History, starting with first recorded vehicle and test results
Registration mark:
deleted
Make/Model:
HONDA / CBR900RR
Colour:
BLACK
VIN/Chassis No:
deleted
01/04/2001
Type of fuel:
Petrol
Date of test:
05/04/2006
Odometer reading:
16,072 Miles
Test number:
deleted
Test station name:
THE BIKESHOP
Test station number:
63618
Test station telephone number:
01159732862
Test class:
II
Test expiry date:
04/05/2007
No Advisory Notice issued
Date of test:
16/07/2007
Odometer reading:
16,210 Miles
Test number:
383657797199
Test station name:
THE BIKESHOP
63618
01159732862
Test class:
II
Test expiry date:
15/07/2008
Date of test:
01/08/2008
Odometer reading:
17,352 Miles
Test number:
582734818291
Test station name:
THE BIKESHOP
63618
01159732862
Test class:
II
Test expiry date:
31/07/2009
Steering movement slightly 'notchy' (2.2.1b)
Date of test:
21/09/2009
Odometer reading:
17,600 Miles
Test number:
511454969284
Test station name:
STREET MACHINE
62331
01159394477
Test class:
II
Test expiry date:
20/09/2010
Date of test:
04/04/2011
Odometer reading:
17,779 Miles
Test number:
136674891469
Test station name:
STREET MACHINE
62331
01159394477
Test class:
II
Test expiry date:
03/04/2012
Date of test:
26/06/2012
Odometer reading:
18,480 Miles
Test number:
227128972114
Test station name:
STREET MACHINE
62331
01159394477
Test class:
II
Test expiry date:
25/06/2013
Front Tyre worn close to the legal limit (4.1.3(ii))
It's only on just shy of 19000 miles now and the front tyre needs replacing. I'm thinking it is the same tyre that was on it in the summer of 2012?
The garage will MOT it if I agree to buy it but they won't do one until they have a buyer so it will always go with a full MOT.
Aff
PostPosted: 17:45 - 04 Sep 2013    Post subject: Reply with quote
Do you have a link to the bike?
Chilled76
PostPosted: 18:50 - 04 Sep 2013    Post subject: Reply with quote
No it's not on any websites, they don't seem to advertise online... bit weird... after posting that I nipped out on an off chance....
and...I've just spoken to the previous owner (he still lives at the address on the log book).
Bit weird but once he realised why I'd given him a knock he was cool.. only 5 mins from where I live.
It's never been on the track, genuinely needed a quick sale on a bike he rarely used so sold it to the garage. Has seen 160mph regularly but always warmed up etc properly.
Bit miffed though, he sold it them for £1350... they've got it on for £2500.
I was hoping to get it with a full MOT, 6 months tax and a bit of warranty for £2200
He says the only issue it has that he knows of is it drops a really tiny bit of oil after it's been running, thinks it is coming from a rocker cover. It started happening after he had a head gasket and rocker cover gasket done at 17000 miles in order to do the tappets.
Could this be a sign the head gasket wasn't done right? Or will it likely be the rocker cover not sealed right? I guess if it's been 1500 miles since the head gasket was done it won't be that?
The last post was made 13 years, 71 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.10 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 145.74 Kb
