| Chilled76 |
 Chilled76 L Plate Warrior
| j.silvs |
 j.silvs World Chat Champion
| supZ |
 supZ World Chat Champion
| jjdugen |
 jjdugen World Chat Champion
 Posted: 18:27 - 03 Sep 2013 Post subject: |
929's do have an issue with the wiring loom. A large number of earths are gathered into a block inside the loom, just under the tank. Once these start to verdigris it gives rise to all sorts of wierd electrical faults from instrument clusters going erratic, lights and indicators not working properly to actual miss fires or failure to start.
But, a very easy fix with a good soldering iron and an hour or so unpicking the loom and making the earths good.
My info is that the alternator is fine on the 929, its the 954 onwards that causes problems.
Treat OEM reg/recs as a consumable item, replace with R1 - Fazer 1000 units, much better design (Mosfet current limiter, not current dump).
CCT's don't seem to be much of a problem either, very easy fix if it does start to rattle.
Only downer noted is the early F.I. system is snatchy just coming onto throttle, can make trickling along a bit jerky, not really that bad actually.
A bit more power than the earlier carbed 'blades, but not that much faster, does (finally) have a 17'' front wheel and gigantic discs up front. Bit of a rush job on Hondas part to try to catch up to the R1, which it didn't! ____________________ The CBR900RR has been sold. Aprilia Falco worms its way into my heart.
Try Soi 23 on Amazon for a good read.... Self promotion? Moi? |
| Aff |
 Aff World Chat Champion
 Posted: 18:50 - 03 Sep 2013 Post subject: |
Don't let it put you off. All of their problems can be avoided or lessened with some preventative maintenance.
Fit a voltage display to warn you when your RR is about to go or your stator starts playing up, this will stop them destroying your loom.
Make sure all of the earths are in good nick too, especially the common earth block (behind the dash, not under the tank).
The CCT rattle can supposedly be fixed with a single M6 bolt, I am yet to test it though. Otherwise just swap it out to an APE MCCT.
The low down fuelling can be completely sorted with a Power Commander.
I love mine, it's a brilliant bike. ____________________ Current Bikes:Honda 929RR Fireblade, Honda CD200 Benly (Project), Stomp Z2 140
Electric Bike Project |
| Chilled76 |
| Aff |
| Ariel Badger |
 Ariel Badger Super Spammer
| Chilled76 |
| swampy |
 swampy World Chat Champion
| ThoughtContro... |
 ThoughtContro... World Chat Champion
| Doovy |
 Doovy World Chat Champion
| The Tot |
 The Tot World Chat Champion
 Posted: 22:57 - 03 Sep 2013 Post subject: |
Hello, I am here!
The 929 should really have a Ducati sticker on the tank, especially from the Texas Pacific Era! Mine's an RRY so in addition to the issues that have been raised, here's what to check out for.
Fork Bottom Recall
Honda probably employed some retard metallurgist and got their material specification wrong for the fork bottoms making them susceptible to SCC; Stress Corrosion Cracking - I can't be bothered to explain this on the forum, but effectively, chlorides and other ions + stress loading from the shock movement + susceptible material = brittle fork bottoms. If your bike is affected, as mine was, check that the recall was done.
Now the issues I've had on my bike - in order of cost
Bear in mind I used my bike as RAT rider - It's now on 44k miles, clocking 12k miles a year under my ownership!
Cam Position Sensor Fault - £500
A bloody dog to diagnose! It throws up no fault codes and won't allow your engine to spark. Typical symptom of an earth fault, so it took a while for the mechanics to trace this down. Sensor itself was £150, most of it was diagnostic labour! So if your bike is fully charged, but won't spark up and not throwing fault codes, this is a common culprit! Has been known to occur on CBR600's too
: Regulator Rectifier x 3 - £220
2 Reg Recs blew; considering that I also had the alternator rewound/replaced TWICE! The 3rd time, I took sickpups advice and bought an 09 R1 MOSFET reg/rec (shindingen) off ebay. Bypassed the internal charging loom, so my battery is effectively connected to the reg rec and alternator directly - I assumed there was a fault in the loom which I couldn't be bothered to trace down. Problem hasn't recurred in the last 2 years
Rewound Alternator x 2 - £160
So if your charging system, typically your battery, is throwing wobblers, check the rest of your system! So, my battery was showing 14.3-14.7 V at 5k RPM when I ran my regular checks. This is where a volt-meter wired in directly is a wise mod, especially by being able to tell what sort of juice you're showing up when at >4k RPM
Earth Fault - £120
I used my bike every day, including in the snow, so this was more of an inconvenience that left me stranded in Oxfordshire! Allow dat! I just don't have the patience to track down wiring faults, so left this one at Branson's honda
Speedo Fault - £120
I rode to the BCF BBQ with no speedo! Multiple instances of 929 clocks having corrupt EPROM chips leaving your digital display completely blank! Your indicator lights work, but that's all! A known issue, and there's a chap in Kings Lynn that makes a living out of reflashing the EPROM chips - Honda basically tell you to find a replacement clock on ebay if you can, or try scorpio electonics.
Other gripes being that you CANNOT remove your tank! There is no quick disconnect line from the fuel pump. The fuel pump itself does not seal or isolate itself. Swingarm bolts directly to the back end of the crankcase, so bear that in mind when you want to take the bike apart etc.
BUT discounting that, it is probably one of the sweetest handling litre bikes out there! It's a connoisseurs superbike. Chavs went for R1, nutters went for gixxers, and fuddy duddy types went for the ZX-9R.
I treat my 929 like a 600 on roids and the handling is second to none! When the chassis is THAT good, you can make some concessions, like on power. Bike is settled on whatever surface your on. Yes it can get flighty, but rest assured, if you're going THAT fast, you'll be glad you're on a composed 929!
954 is THE blade to get.
FYI, bimetallic corrosion issue was prevalent on 06-07 Fireblades - Honda vehemently refuse to take accountability.
Great bikes, but has its issues. But 929/954 will make you smile more than most because you can use a lot of the bike, a lot of the time.
Quite economical too - 150 to the tank on serious hoons is achievable!
A bit of whoring, but here's my 13 year old Lad - Marco
https://fbcdn-sphotos-g-a.akamaihd.net/hphotos-ak-ash4/998669_10151756606080712_1784622856_n.jpg ____________________ The Tot 2019 Z1000SX - 2007 R1
Never argue with autism |
| thelamoth |
 thelamoth Borekit Bruiser
| The Tot |
| thelamoth |
| thelamoth |
| The Tot |
| Chilled76 |
 Posted: 08:05 - 04 Sep 2013 Post subject: |
Thanks for such a detailed response, really appreciate the advice.
How do I know if it is an RRY? it just says RR on the log book?
Will a Honda Main dealer be able to tell me if this work has been carried out?
This scares me
Reg/Rec...£220! Is that each or for all three? It's had a new one fairly recently... how long before it goes again?
Again is that each?
Earth Fault - £120
This sounds common
Speedo Fault - £120
Again a scary prospect for a Jap built "reliable" manufacturer
I won't be going that fast, it's going to be my first bike and I WILL treat it with EXTREME caution
I can't afford a 954 and there is a two owner from new 18k example of a 929 in the local garage which has got me looking at them. I prefer the size and position to all the 600cc bikes I've sat on. I think I will be able to do 200 mile trips easier on it and ultimatly it will end up on a track on the occasional weekend hence looking at one of these over a VFR.
How much juice do they hold?
And I guess you've answered my question, seems they are fairly unreliable.. more so than a CBR600 of similar age and mileage? |
| Aff |
 Posted: 08:54 - 04 Sep 2013 Post subject: |
| Chilled76 wrote: |
Remember to take into account that Tot has done a lot of mileage, a lot of which has been in bad London winters. I think Tot was a bit unlucky with some things, and some of the prices seem very high because he was paying for dealer diagnostics labour, which is never cheap.
I genuinely don't think they are any more unreliable than any other bike, and with regular maintenance they shouldn't be a problem.
They have common issues, but they are generally common issues to all Honda's of this time period.
Also remember that generally you only hear about it when things go wrong, for instance my 929 is on 28K miles and it still has original CCT, Stator and RR and most of my issues so far have been small electrical problems which required nothing other than my time to fix.
Ultimately it's up to you, if it is a bike you think you want to own, buy one, if it turns out you don't like it a couple of months down the line then sell it, I doubt you will loose that much.
Just make sure before you buy you check as much of the electrical system as possible, I took a multimeter to the dealer when viewing mine so I could check the charging system. ____________________ Current Bikes:Honda 929RR Fireblade, Honda CD200 Benly (Project), Stomp Z2 140
| The Tot |
 Posted: 13:53 - 04 Sep 2013 Post subject: |
In my case, my bike was an extemely used example. I was putting on 1500 miles a month for 2 years. I got it at 11k miles in 2009. By 2011, it hit 43k! In the last 2 years, I've only done 1300 miles and now lives in a garage.
Most of my issues started at around 30-35K miles. First reg-rec went at 20k, then went again at 38k.
I couldn't afford to have the bike off the road since I needed it for long distance commutes, but I had all the money to let somebody else have a look at it.
If you do less than 8k on it whilst keeping it garaged, then you'll be fine. Mine lived outdoors, uncovered mostly, for 3 years! So, that will explain why my reliabilty has been horrendous!
Juice; it holds 18 litres.
If it's about 30k, get the suspension refreshed to restore its handling! Like i said, brakes and suspension are its stronges points. Brilliant chassis! ____________________ The Tot 2019 Z1000SX - 2007 R1
| The Tot |
| Chilled76 |
| Aff |
| Chilled76 |
The last post was made 13 years, 22 days ago. Instead of replying here, would creating a new thread be more useful? |
