| Dt125r-ash |
 Dt125r-ash Derestricted Danger
 Posted: 21:20 - 03 Sep 2013 Post subject: dt125r dep pipe! |
hi there, this might be a stupid question but, bought a new dep pipe today and im having trouble with fitting on to my standard exhaust, do i have to cut anything off on the standard exhaust to make the dep pipe fit onto it? as it wont fit to the standard exhaust. im not so sure :S but come on here for help. go easy please [/img] |
| prawny1 |
 prawny1 World Chat Champion
| Dt125r-ash |
| Boxing |
 Boxing World Chat Champion
 Posted: 21:31 - 03 Sep 2013 Post subject: |
You got the pipe for the correct year as yours? 1988-2003 or something like that is the ones to fit the DTR's.
You'll also need two O-rings. Similar to this: https://www.ebay.co.uk/itm/EXHAUST-RUBBER-SEAL-GASKET-O-RING-for-YAMAHA-YZ125-/160341274163?pt=UK_Motorcycle_Parts_13&hash=item255515ae33
Can find them cheaper and in a pack of two or three for about £3 just got to look for them.
You might need to take the silencer off to fit it, and it's a pain to line all the holes up. I do the two bottom 13MM bolts on the exhaust port then put in the bolt at the back near the frame then loosen the one near the engine and rotate it to fit properly.
If you have no one to help you fit the exhaust just sit on the floor and use your leg to hold it. It's what I do.
And go buy loads of ACF-50. I'd go through eBay, all bike shops and Halford's didn't have any near me. Sold me some garbage that didn't work and now my exhaust is all rusty.
The gutted standard expanny is best on the DTR's. Waste of £185 IMHO. The DEP's are all dented after a single drop.  |
| Dt125r-ash |
 Posted: 21:39 - 03 Sep 2013 Post subject: |
yes its the correct one mate.
and yeah lining them up is a bi*ch, thanks for that i will try it
and i only payed £20 for it so the rust already got there but just wanted to see if a down pipe would give it that more humph then i was gonna derestrict the standard one
and did you use the pipe to exhaust rubber on yours?
thank you so much for your advice very much appreciated  |
| Dt125r-ash |
| nathan k |
 nathan k Spanner Monkey
| Dt125r-ash |
| nathan k |
| Boxing |
| Dt125r-ash |
 Posted: 01:25 - 04 Sep 2013 Post subject: :D |
| Boxing |
 Posted: 01:28 - 04 Sep 2013 Post subject: |
Loosen the silencer holding bolts, and then try and connect them. If you can't get the bolts to line up on the frame, loosen both bolts for the expanny, NOT the 13MM ones on the port though, then there is play on the exhaust to line the bolts up.
Don't forget that rubber, it's important. |
| Dt125r-ash |
 Posted: 01:34 - 04 Sep 2013 Post subject: :( |
awwwwwwww great mine is the 2002 dt125r model
and what do you mean by buy an athena, i think im just gonna try and make the hole a bit bigger to fit on the exhaust, iva way im only losing £20, i only wanted to see if it made a improvement then buy a whole set, as my dtr wont go past 55-60 on a good day
much appreciated with helping me out tho guys anymore help would be appreciated to  |
| Boxing |
| Dt125r-ash |
 Posted: 01:44 - 04 Sep 2013 Post subject: ! |
7-8 if im lucky but thats with the standard pipe and exhaust.
lucky for you i get overtaken by mopeds, yeah MOPEDS :O :'(
and get ready for it (drumroll) 62,000 and i dont no previous owner said he never done anything to it but its only had 3 owners including me, and the engine sounds and runs to sweet to not have had a engine rebuild last 10k, oh and btw the guy i bought it off used it for work then got it mot'd then left it for a year... thansk for the reply  |
| Dt125r-ash |
| Boxing |
 Posted: 01:49 - 04 Sep 2013 Post subject: |
Sounds fishy now mate. (A person doesn't just put a bike away for a year if nothing is wrong with it and they haven't upgraded / got a car.)
You have the exhaust off? Get a torch and look up the exhaust port. Move the kick start down slowly with the ignition off and check the piston, if it's scored there's your problem.
With it being a 2002, chances are all the de-restrictions have been done...
And mopeds beating you, unless they're Runner 170-180's it shouldn't be possible. My DT smokes peds even with a wrecked topend it was thrashing them. |
| Dt125r-ash |
| Boxing |
 Posted: 02:01 - 04 Sep 2013 Post subject: |
Them RS 125's always seem to get swapped when they're about to blow up.
Get Athena silencer, and get your expanny done, should be good to go.  |
| Dt125r-ash |
| Dt125r-ash |
The last post was made 12 years, 226 days ago. Instead of replying here, would creating a new thread be more useful? |
