How do I keep the sky-fluid out?
Jonathan A
PostPosted: 20:40 - 14 Sep 2013    Post subject: How do I keep the sky-fluid out? Reply with quote
On the last weekend of this month, I am riding to London from Derby to see my sister. It has just occurred to me that on the 120 miles of M1, at this time of year it is bound to rain at least 23 times.
Can anyone suggest a good (lowest possible price) set of rain gear? I have tried a £6 builders rain suit, but it was too tight over my gear, causing both parts to split.
Cheers Very Happy
PostPosted: 20:49 - 14 Sep 2013    Post subject: Reply with quote
Search on BCF for rainsuit.
Nick 50
PostPosted: 20:53 - 14 Sep 2013    Post subject: Reply with quote
Boom:
https://www.getgeared.co.uk/BLH_BERING_Eco_Light_Motorcycle_Rain_Suit
/thread
Mr. Green
LockyUK
PostPosted: 20:56 - 14 Sep 2013    Post subject: Reply with quote
waterproof is all shit and not to be taken seriously unless it is goretex or a variant of.
https://www.surplusandoutdoors.com/shop/outdoor-clothing/waterproof-clothing.html
bendover
PostPosted: 21:06 - 14 Sep 2013    Post subject: Reply with quote
My "El Nino " one peice is not Gortex and never ever has let a drop of water in ,although its not exactly a budget waterproof but there's nothing worse than being cold and wet on a long ride ,so money well spent me thinks Thumbs Up
LockyUK
PostPosted: 21:12 - 14 Sep 2013    Post subject: Reply with quote
i just googled, no mention of what the hydrostatic head is, so as for 90 quid ? sod that
PostPosted: 21:17 - 14 Sep 2013    Post subject: Reply with quote
My rubbery lined army surplus trousers have been waterproof in every situation I've used them in, as has my roadworks-style thermal placcy jacky.
What they're not is breathable, which is where Goretex comes in. I'll go check my lottery numbers...
Skudd
PostPosted: 21:24 - 14 Sep 2013    Post subject: Re: How do I keep the sky-fluid out? Reply with quote
Jonathan A wrote:
Something something something sister .something something something
Did you say something?
Jonathan A
PostPosted: 21:32 - 14 Sep 2013    Post subject: Reply with quote
Oh haha ha ha haha
-Matt-
PostPosted: 21:35 - 14 Sep 2013    Post subject: Reply with quote
Ive got an RST rainsuit, 50 quid, size up for leathers (with hump) fits great
daverave999
PostPosted: 22:02 - 14 Sep 2013    Post subject: Reply with quote
Stay away from the RST Slice textiles! Supposedly waterproof and in less than half an hour of not particularly heavy rain on Friday, I had my own personal puddle in my trousers. Unimpressed. *whinge*
I've got a Flexothane coverall I got from ebay that I'd read good things about on BCF. It's the Montreal, and being lanky I was surprised the size charts actually give you something that fits. I've not tried mine yet so don't wish to comment on how waterproof it actually is, but it certainly looks like it will do a better job than anything else I've seen for the money. There's a size chart here if you fancy a try, and if you're a M, L or 3XL Shocked there are some yellow ones on ebay for under £30 at the moment. It's stretchy too so should eliminate any splitting issues you've experienced before.
Hope this helps!
2007 Versys 650 2001 Yamaha XJ600S Diversion
HT: Imagine a bike......A bike designed by way of crude polls, assembled by cretins using the finest hammers that Lidl had on offer.
Jonathan A
PostPosted: 23:04 - 14 Sep 2013    Post subject: Reply with quote
To be honest I think I will go with https://www.getgeared.co.uk/BLH_BERING_Eco_Light_Motorcycle_Rain_Suit
would xxl be a good size to get?
Nick 50
PostPosted: 23:09 - 14 Sep 2013    Post subject: Reply with quote
Well that depends on what size you are? Laughing
Mine is pretty roomy to be honest. I think they are designed purposefully to go over motorcycle gear, so have plenty of room.
sabian92
PostPosted: 23:36 - 14 Sep 2013    Post subject: Reply with quote
Appears you've been under a rock then. Goretex isn't the be all and end all of waterproofing. It's nice to have but it's bloody expensive.
c-m
PostPosted: 23:57 - 14 Sep 2013    Post subject: Reply with quote
As stated earlier Gortex isn't the only waterproof system. There are others that perform as just as well. The only reason Gortex is recommended so often is the guarantee. Bear in mind the 'lifetime' guarantee isn't actually a lifetime, but instead the estimated (by gortex) life of the item. So for your expensive item that could be 1 year or it could be 10 years. You'll never know unless you need to send it back.
barrkel
PostPosted: 01:38 - 15 Sep 2013    Post subject: Reply with quote
I've never seen good seams on non-goretex gear. That includes all the goretex clones, sheltex etc.; they might be breathable, but they don't have good seams.
Seams are the weak point of waterproof stuff. There's extra stretch there from how the garments are cut and put together, and intrinsically from how they're worn. All non-goretex gear I've examined uses a clear rubbery tape that has a different degree of flex to the material it's stuck to. In my experience, it inevitably develops "bubbles" on the seam itself, and eventually creases that work their way to the edge of the seam tape. And that's a leak.
If the tape is clear, they're really easy to see, because the tape is lighter coloured and more opaque after it has come away from the fabric.
All my goretex gear, meanwhile, use some kind of bonded fabric tape. I've not seen the same failure mode yet.
From what I know and have heard (my boss used to sell outdoors goretex gear), when you buy goretex gear you're covering the cost of higher spec machinery, higher quality QA (to meet contract requirements with Gore - a certain proportion of garments off the production line are constantly tested), a guarantee (effectively an insurance policy), and some inefficiency overheads from certification and marketing.
How much of the extra cost is down to marketing and bureaucracy etc., and how much to the actual work needed to create a consistent high-spec garment, I don't know. I do know that (a) my goretex gear is the only stuff that has actually been waterproof for any length of time, and (b) I wasted a lot more money on non-goretex gear than I spent on goretex gear in the end.
And you're right that it's not the ultimate. I have goretex lined leather gloves. Once the leather gets wet, they steam up inside. The goretex doesn't keep the damp out. They have to be paired with muffs or something similar to be effective.
wots
PostPosted: 08:08 - 15 Sep 2013    Post subject: Reply with quote
I use these https://www.amazon.co.uk/Silverline-282424-Class-Hi-Viz-Trousers/dp/B000LFS2TU/ref=sr_1_2?ie=UTF8&qid=1379232117&sr=8-2&keywords=silverline+trousers
I bought some specific motorcycle waterproof over-trousers, spada I think £30-40 and these are better by far, the spada's leaked. I have 3 pairs, they fold down nicely and will fit under the seat of some bikes. I have a set at home, a set at work and one in the topbox usually. That way I usually have a dry pair for getting caught short.
I do use these over my Richa armoured motorcycle trousers and don't get any ingress. Trousers was always the worst part for me, as water would collect in traffic and permeate the groinal area. I have a textile jacket that on the whole is 'waterproof' and tends to drip dry and not let the rain in.
LockyUK
PostPosted: 10:04 - 15 Sep 2013    Post subject: Reply with quote
correct goretex is not the be all and end all, but by far one of the best commercially available waterpoofing, buy them crappy rainsuits at 50 quid and such, well, buy cheap buy twice
sabian92
PostPosted: 10:07 - 15 Sep 2013    Post subject: Reply with quote
Generally it's a case of what you pay for though isn't it? I mean expensive non-goretex stuff is obviously going to be better made than the cheap stuff but just because it isn't goretex it shouldn't mean after 6 months it's going to leak and have you turning up at work looking like a drowned rat Laughing
I'd love a set of goretex waterproofs but like you said it's expensive simply because it's expensive to make etc. Maybe one day, eh.... Very Happy I've got waterproof stuff I bought with the intention of commuting through the winter but as it stands my credit check bounced and I was declined so there's a waste of money Mad until I can afford it outright in January at least. Still though, it is waterproof enough for now so that'll do.
LockyUK
PostPosted: 10:17 - 15 Sep 2013    Post subject: Reply with quote
like i said above, military surplus, get jacket and trousers for 70 quid...
c-m
PostPosted: 10:45 - 15 Sep 2013    Post subject: Reply with quote
Can anyone recommend a waterproof over jacket with long arms?
Every one i've tried so far leave a gap at my wrists when in the riding position.
A waterproof jacket needs to go over the top of your gloves otherwise the water just runs down the sleeve and into the cuff of the glove eventually spreading all round the grove.
bendover
PostPosted: 11:18 - 15 Sep 2013    Post subject: Reply with quote
Hydrostatic Head !!!!!!!!,
Hey Lockwood were talking Waterproofs not tents you bellend Rolling Eyes ,
[/quote]
CG Sam
PostPosted: 11:30 - 15 Sep 2013    Post subject: Reply with quote
I just wear these trousers https://www.ebay.co.uk/itm/Mens-Reissa-Cordura-Textile-Waterproof-Motorbike-Motorcycle-Trousers-Pants-/120925746537 and either of my two textile jackets, nothing has let water in yet
CG125, SV650S, CBR600F, GSXR600 SRAD
LockyUK
PostPosted: 11:32 - 15 Sep 2013    Post subject: Reply with quote
[/quote]
the material still has a quoted hydrostatic head you fucking moron, you know? the measurement of how waterproof such a material is, now go and die you fucking mincer
c-m
PostPosted: 14:23 - 15 Sep 2013    Post subject: Reply with quote
He's right. Hydrostatic head is used to measure to the waterproofness of material. You'll have a problem finding the HH of most listed though.
The last post was made 12 years, 170 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.24 - MySQL Queries: 13 - Page Size: 133.04 Kb
