Sticky Tape
dolly3900
PostPosted: 13:51 - 18 Sep 2013    Post subject: Sticky Tape Reply with quote
Hiya, lots of qustions from me today Smile
Just got a set of headsets for inside the lids, so that me and SHMBO can chat whilst out (or at least, she can nag about how fast I am going).
The mic's and speakers fit in the lids nicely and the wires feed under and inside the padding rather hidden and lovely.
The problem I have is that where the main wire comes out of teh bacl of the lid, I keep on catching it and pulling it out a bit, menain gI have to re-fit the last inch or so back into the padding every time.
I have tried normal Duct tape to secure it, but as it is is secured partly on the outside of the lid and partly on the vinal padding un the read/neck pad, it just keeps on peeling off.
Any ideas on stronger adhesive tape to secure it?
Was thinking about carpet tape, would that do?
Cheers again
Mike
2002 Rieju RS2-50 (Sold, spares or repair), 2010 Suzuki DR-125SM (Traded for ->), 2007 Honda CBF 600 (Sold), 2010 Suzuki V-Strom 1000 (Briefly, now returned), 2007 Suzuki Intruder 1800m (Even More Briefly, traded in for ->), 2014 Suzuki V-Strom 650
Minty
PostPosted: 15:19 - 18 Sep 2013    Post subject: Reply with quote
Isnt carpet tape double sided? Can you not route any of the cable to go behind some padding or try taking the cable out of the side of the helmet instead of the rear. Thumbs Up
My fingers smell of your mum.
stickybackbob
PostPosted: 17:24 - 18 Sep 2013    Post subject: Reply with quote
The trouble with tape is the adhesive system used. Solvent based systems leech the plasticiser from the vinyl on your lid and leave a gooey mess behind. Water based systems just aren't up to the job as moisture will eventually get to them.
If you can't find any other way of sorting your wiring out, I'd recommend getting a cheap hot-glue gun off ebay and using that. You'll also find that you can use the gun and glue to fix all sorts of other stuff too (found that it's pretty good at fixing broken bobbles on fairings Smile )
Peirre oBollox
PostPosted: 18:32 - 18 Sep 2013    Post subject: Reply with quote
I have the headset cable (starcom) running out of the side of the helmet next to the strap, & zip tied to the strap anchor ring inside the helmet liner between the liner & the shell, then the rest of the cable runs out of the helmet neatly between the liner & the shell & down in front of my shoulder
Nobby the Bastard
Harley Gaydar
PostPosted: 20:24 - 18 Sep 2013    Post subject: Re: Sticky Tape Reply with quote
The traditional approach to this problem is to just ignore the screaming, blaming the wind noise for your lack of response when questioned after the event.
It'll be harder to ignore if you have a headset on feeding the comments on your riding, your sexual prowess and your parentage directly into your ear so I suggest dropping the idea straight away.
Triumph Sprint ST 1050
mysterious_rider
PostPosted: 22:50 - 18 Sep 2013    Post subject: Reply with quote
gluegun chap
KAWASAKIIIII
radicalrabit
PostPosted: 22:59 - 18 Sep 2013    Post subject: Reply with quote
there is a cable clip that allows cable to be fastened to glass or other panels so it has a small flat base with a very sticky pad on it then the cable clamp on top.
look in the pound shop..like this but much smaller
https://www.extak.com/catalog/23797/88140-17mm-BLK-SELF-ADHESIVE-CLAMP-50PK?ppc=google_shopping
https://www.choiceful.com/categories/productdetail/80782?utm_source=google&utm_medium=product%2bsearch&gclid=cnoi1keg1rkcfuxktaod72majg
VF1000 F2F, BLACKBIRD with carbs, 2nd VF1000F2F just need somewhere to go now..
radicalrabit
PostPosted: 23:01 - 18 Sep 2013    Post subject: Reply with quote
The last post was made 12 years, 149 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 56.85 Kb
