Vsync in Linux
RhynoCZ
PostPosted: 22:55 - 18 Sep 2013    Post subject: Vsync in Linux Reply with quote
Hello, does anyone know, how can I turn on vsync in Ubuntu 13.04? When I play a video, there's very noticeable image ''tearing''. I tried ATI pro X.Org but that did not work, in fact it caused that lot of things did not work. It is really annoying, I tried various videos, but it was the same so the problem is in the system.
Intel Q6600, HD6790
Thank you
Going
PostPosted: 04:13 - 19 Sep 2013    Post subject: Reply with quote
No idea, but what drivers are you using. Did this just start after an update, a new system install or is it a new card.
If a new install remove your current drivers and install a different set.
If just happened after an update, downgrade the drivers, then work out how to stop the drivers from updating.
If a new card and the old one wasn't ATi, remove the drivers for the old card.
I'm currently using ATi HD7950 with these (The older version, due to problems with the newer ones):
warning: ati-dri: ignoring package upgrade (9.1.6-1 => 9.2.0-2)
warning: mesa: ignoring package upgrade (9.1.6-1 => 9.2.0-2)
warning: mesa-libgl: ignoring package upgrade (9.1.6-1 => 9.2.0-2)
warning: xf86-video-ati: ignoring package upgrade (1:7.1.0-3 => 1:7.2.0-1)
RhynoCZ
PostPosted: 09:33 - 19 Sep 2013    Post subject: Reply with quote
I'm not that advanced, I use linux about a month. Earlier I couldn't run the GPU at all, I somehow figured it out a month ago. I still can not get Catalyst control center to work, my mate who earns money working with linux systems told me, that the CCC should work the same, just like in windows. By the way, I can not run CCC in windows either.
I once downloaded latest drivers for the ATi in windows and I've had no CCC since then. I uninstaled the CCC, drivers and errased it from registers, tried the SW cd that came with the GPU and nothing.
Could it be hardware problem? Thinking
EDIT: I tried different driver, in linux, but that caused that nothing worked, so I put back the open source driver.
When I put in the CCC I get: aticonfig: No supported adapters detected
Pigeon
PostPosted: 00:15 - 20 Sep 2013    Post subject: Reply with quote
For years I ran Slackware and NVidia binary driver. It was fine.
Then switched to ATI (chip used less power, ran cooler and was faster).
Great graphics, but terrible binary driver.
I know the tearing you mean. The screen almost splits in half horizontally. With the top half or bottom half shifting slightly one way to the other.
In the end, switched to the open source driver. My custom /etc/X11/xorg.conf file is
Code:
Section "ServerLayout"
  Identifier     "aticonfig Layout"
  Screen      0  "aticonfig-Screen[0]-0" 0 0
EndSection
Section "Module"
EndSection
Section "Monitor"
  Identifier   "aticonfig-Monitor[0]-0"
  Option    "VendorName" "ATI Proprietary Driver"
  Option    "ModelName" "Generic Autodetecting Monitor"
  Option    "DPMS" "true"
EndSection
Section "Device"
  Identifier  "aticonfig-Device[0]-0"
  #Driver      "fglrx"
  Driver      "ati"
  BusID       "PCI:1:0:0"
  #Option  "AGPMode"               "8"   #not used when KMS is on
  #Option  "AGPFastWrite"          "on" #could cause instabilities enable it at your own risk
  Option  "SWcursor"              "false" #software cursor might be necessary on some rare occasions, hence set off by default
  Option  "EnablePageFlip"        "true"  #supported on all R/RV/RS4xx and older hardware and set off by default
  Option  "AccelMethod"           "EXA" #valid options are XAA and EXA. EXA is the newest acceleration method and its the default.
  Option  "RenderAccel"           "true"  #enabled by default on all radeon hardware
  Option  "ColorTiling"           "true"  #enabled by default on RV300 and later radeon cards.
  Option  "EXAVSync"              "true" #default is off, otherwise on
  Option  "EXAPixmaps"            "true"  #when on icreases 2D performance, but may also cause artifacts on some old cards
  Option  "AccelDFS"              "true"  #default is off, read the radeon manpage for more information
  Option  "BackingStore"          "true"
  Option  "SubPixelOrder"         "RGB"
  #Option  "ClockGating"           "true"
  Option  "DynamicPM"             "true"
EndSection
Section "Screen"
  Identifier "aticonfig-Screen[0]-0"
  Device     "aticonfig-Device[0]-0"
  Monitor    "aticonfig-Monitor[0]-0"
  DefaultDepth     24
  SubSection "Display"
    Viewport   0 0
    Depth     24
  EndSubSection
EndSection
EDIT:
The above is in Mythbuntu 12.04 (based on Ubuntu 12.04)
Going
PostPosted: 01:15 - 20 Sep 2013    Post subject: Reply with quote
I've never had Catalyst Control Centre work under Linux. Then again, ATi for me has always taken longer to setup right, Nvida being easier.
My /etc/X11/xorg.conf file:
Code:
Section "Monitor"
    Identifier  "HDMI-0"
    Option   "PreferredMode" "1920x1080"
    Option   "Primary" "true"
    Option   "Position" "1280 0"
EndSection
Section "Monitor"
    Identifier  "DVI-0"
    Option      "PreferredMode" "1280x1024"
    Option   "Position" "0 0"
EndSection
The last post was made 13 years, 25 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.97 - MySQL Queries: 13 - Page Size: 49.82 Kb
