Stuck in a catch 22.
Hokum
PostPosted: 14:42 - 26 Sep 2013    Post subject: Stuck in a catch 22. Reply with quote
I took my Mod 1 last year on a 500cc, but due to the wife not working, I ran out of funds and couldn't take my Mod2.
Now I'm still short of funds (I have a disabled son and my wife still looks after him), but my Theory test/CBT runs out next April I'm starting to feel like I'm running out of time.
Should I go and take the Mod 2 on a 500 and get an A2 or should I have to retake my Mod 1 on a larger bike.
I know the Mod 1 is cheap but I get terribly nervous under test conditions and I'd be worried about ballsing it up and wasting money.
Thoughts?
Sane: To know when you are doing something crazy.
esullivan
PostPosted: 14:55 - 26 Sep 2013    Post subject: Reply with quote
The answer depends on quite a bit: how old are you? What are you riding now? What will you do if you pass your test? Are you going to have to renew your CBT anyway because you commute on the bike?
Current: '14 VFR800X Test passed 31/10/12.
Previous: '12 NC700S, '11 CBF 125, '04 SH 125.
Hokum
PostPosted: 15:17 - 26 Sep 2013    Post subject: Reply with quote
35yo, Daelim Roadwin 125FI (it's actually really good!), I'm currently commuting about 30 miles a day (15 each way) yeh I'll have to renew the cbt in April too.
I'd be tempted and just take the A2 so I dont' have to worry about the CBT and Theory, but if I later wanted to get the full A i'd have to do the theory again don't I? Cause riding a 650+ is so different in theory to riding a 500...
esullivan
PostPosted: 15:23 - 26 Sep 2013    Post subject: Reply with quote
No, you don't have to re-take the theory , just the practical tests again. Sounds like you should just go ahead and take the mod 2 for A2, if they will let you (I assume you've checked this).
You need the bike, day-to-day and the mod 2 will cost less than the CBT re-do, won't it? Even if money stays really tight and you can't do the full A tests for a while, you'll have plenty of bike choices on the A2. I have a full A and ride a naturally A2 compliant bike and it's actually quite good.
Hokum
PostPosted: 15:31 - 26 Sep 2013    Post subject: Reply with quote
What what what? I had assumed my old big bike mod 1 would class as an A2 mod 1?
esullivan
PostPosted: 15:35 - 26 Sep 2013    Post subject: Reply with quote
I don't know. The information is confusing. If you took your mod 1 under the old rules, but on a 500cc machine, does that count as an A2 mod 1 under the new rules? I just don't know. Would just take a phone call to your local test centre to verify.
Here's the DSA route-to-license diagram, which notes that you do not have to retake the theory test if you hold an A2:
https://assets.dft.gov.uk/dsa/dsa-routes-to-your-motorcycle-licence.pdf
esullivan
PostPosted: 15:40 - 26 Sep 2013    Post subject: Reply with quote
Actually, sorry Embarassed , I may be wrong about having to retake the theory test. The PDF is ambiguous. See the last slide, which I think applies to you? As usual, it's very confusing. If you are 21-23, and have an A2 license for more than 2 years, it clearly says no theory required -- straight to practical test. If you are over 24, what is a "valid" theory pass certificate, then? Oy.
ficedula
PostPosted: 15:59 - 26 Sep 2013    Post subject: Reply with quote
If you've got an A2 license, and you want to upgrade to full A license, then:
-Held your A2 less than 2 years and under 24? You can't upgrade yet.
-Held your A2 less than 2 years but you've now turned 24? You can go for a full A license, but you still need a theory certificate
-Held your A2 for 2 years or more? You can go for an A license and you don't need to retake theory.
A theory test pass is valid for 2 years - so in theory (ha) you could take a theory test when you're 23, get your A2 license, and then the moment you turned 24 go for an A license.
Because you'd held your A2 < 2 years, you would need a valid theory pass certificate - but your existing one would still count if it was <2 years old. If you'd passed your theory a long time before passing your mod1/2, then it's possible the theory certificate would be >2 years old in which case it's not valid any more - so you'd need to either retake the theory, or wait until you had 2 years experience on A2, at which point they waive the requirement for a theory certificate.
Bike history: YBR125 -> XJ600
pbt
PostPosted: 17:00 - 26 Sep 2013    Post subject: Reply with quote
Becuase you are over 24, although you took your mod 1 on a 500, is counted as a cat A pass. So, you have to take your mod 2 on a 600cc A cat machine.
PostPosted: 20:13 - 26 Sep 2013    Post subject: Reply with quote
Yup. That's my understanding. You have a "Big Bike" aka "DAS" aka category A mod 1 pass.
Have a look at your pass certificate. Does it say diddly about the bike that you took it on? It could have been a Hayabusa. Significantly, the only common old "A" test bike that's also a new "A2" test bike was the GS500 - all of the other 500s are neither fish nor fowl.
If you go and sit mod 2 on a 595cc+ bike making 40kW+ now, you'll should get a full category A license.
Don't take our word for it though, ask the DSA. You may be pleasantly surprised for once.
pbt
PostPosted: 21:16 - 26 Sep 2013    Post subject: Reply with quote
https://www.gov.uk/motorcycle-practical-test/rules-for-mopeds-and-motorcycles-used-in-the-practical-riding-test
Dave70
PostPosted: 22:33 - 26 Sep 2013    Post subject: Reply with quote
You could just up sticks and move to the Isle of Man, do your on road bike test (no mod 1 & mod 2 palaver) at 17 years of age on a 125 and then go out and ride any size bike you want, as it's probably easier than trying to figure out some of the UK's new rules. Seriously, reading and trying to understand those regs makes my head hurt.
ficedula
PostPosted: 09:08 - 27 Sep 2013    Post subject: Reply with quote
That's actually an interesting question (although not so relevant to OP) - what are the rules for who can take a test in the IoM? Because if I were 19, looking at getting a full license, the costs in the UK aren't cheap (CBT, theory, DAS course + mod1 + mod2, mod1 + mod2 + possible bike hire again 2 years later to upgrade to A...)
If it were possible to visit another country for a week to do training + test and get a full license - that's still recognised in the UK - it'd probably be cheaper, and you'd not have the hassle of upgrading from A2->A.
Hokum
PostPosted: 15:06 - 27 Sep 2013    Post subject: Reply with quote
I'll have to check what it says.
The last post was made 13 years, 11 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 81.79 Kb
