| c-m |
 c-m World Chat Champion
| bacon |
 bacon World Chat Champion
| pits |
 pits World Chat Champion
 Posted: 17:36 - 26 Sep 2013 Post subject: |
Having the axle through the forks makes for quicker and more neutral steering. Having the axle through a block in front of the forks introduces a fork offset which causes the steering to want to centre more readily as the fork bottoms are essentially 'hanging' off the axle. ____________________ a.k.a 'Geri'
| Teflon-Mike |
 Posted: 18:09 - 26 Sep 2013 Post subject: |
It IS usually to reduce trail.
Common on dirt bikes due to 21" front wheel, and greater rake than a road bike.
If you draw line through axis of the head-stock, to where it interects the floor, that's the steering center. Now measure back from there to the center of the contact patch of the tyre. That distance is the trail.
More trail you have, the more the steering will try and self-center through castor effect.
Now, bigger the wheel, the further behind the steering center the contact patch is going to be. Think about it, all else equal, you have a 19" wheel, radius is 1" smaller than a 17" wheel, so the axle is going to be 1" further back, further from the steering center, ergo 1" more trail.
Now, rake the forks more, from the steep angles run on sports-bikes, steering center moves even further ahead of the contact patch, so more trail still.
Dirt bikes have big front wheels, and more rake, hence they use 'Leading Axle' forks to reduce trail and keep castor effects in check, without having to have such huge off-set in the fork yokes.
If you look at some scooters; they have 'trailing axle' forks, the wheel spindle on a boss behind the fork slider, for the exact same reason, the other way. Steep fork rake, coupled with diddy wheel, its needed to actually give the thing some trail and castor effect.
Adventure sports? Related to dirt bikes; tend to have larger front wheels. Use leading axle forks for same reason as dirt bikes. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Ste |
 Ste Not Work Safe
| sickpup |
 sickpup Old Timer
 Posted: 22:19 - 26 Sep 2013 Post subject: |
| Teflon-Mike wrote: | It IS usually to reduce trail.
Adventure sports? Related to dirt bikes; tend to have larger front wheels. Use leading axle forks for same reason as dirt bikes. |
And this almost completely misses the main issue.
More travel in dirt bike forks = longer springs+longer stanchions. When the forks are compressed the stanchions go into the fork bottoms, if there was an axle in the way they wouldn't be able to have such long travel. Move the axle clamp to the front of the fork and it doesn't get in the way of compression and the front end stays a reasonable height off the ground. |
| MattJ |
 MattJ World Chat Champion
| sickpup |
 sickpup Old Timer
| Raffles |
 Raffles World Chat Champion
| sickpup |
 sickpup Old Timer
| kestrel |
 kestrel Nearly there...
| bacon |
The last post was made 13 years, 50 days ago. Instead of replying here, would creating a new thread be more useful? |
