Tuned H100SJ back from tuners, update
cb1rocket
PostPosted: 21:45 - 26 Sep 2013    Post subject: Tuned H100SJ back from tuners, update Reply with quote
Hi all, long time since any write up about my project bike, but I have since had to resort to the workshop section - yes I crashed my H100 due to a seizure and rear wheel lock up!
The power is there, apparently 20bhp of it! However it seems to over heat and cause 4 corner seizure on the piston. Anything above 60mph and the bike seize.
I'm running a 160 jet and the plug is a standard coffee tan colour so it can't be running lean, however I have a slip on expansion chamber set up and there is a gap at the exhaust port which I'm guessing is letting air in from the exhaust side and causing it to lean out due to speed of air entering it? Is this even possible?
PostPosted: 22:45 - 26 Sep 2013    Post subject: Reply with quote
What has been done to tune it? Is the timing standard?
dougon2wheels
PostPosted: 23:05 - 26 Sep 2013    Post subject: Reply with quote
Is it getting enough oil ?, had a similar problem with my mito 350, fine below 8k, but prolonged use above would make it nip up, turned out to be restrictive oil inlets on the dellorto's I was using at the time
cb1rocket
PostPosted: 23:13 - 26 Sep 2013    Post subject: Reply with quote
Mods as followed:
Cylinder head squish band increased to lower compression
one off exhaust
125cc athena barrel and piston
6 petal reed block
standard 18mm carb upjetted from 125 to 160
foam pod filter, and no its not the cone type as told that could cause resonating and upset the mixture.
standard spark plug BR8HS standard H100 is on BR7HS
photos to follow shortly on next post
cb1rocket
PostPosted: 23:16 - 26 Sep 2013    Post subject: Reply with quote
https://s212.photobucket.com/user/CB1Rocket/slideshow/h100%20destruction
rather than paste it all see the slideshow. (decided to paste links anyway!)
what does everyone make of the carbon escaping on the outside view of the exhaust stub? That is a leak surely?
https://i212.photobucket.com/albums/cc108/CB1Rocket/h100%20destruction/DSCI0057_zps43c7549b.jpg
https://i212.photobucket.com/albums/cc108/CB1Rocket/h100%20destruction/DSCI0056_zps6e8422d5.jpg
https://i212.photobucket.com/albums/cc108/CB1Rocket/h100%20destruction/DSCI0053_zpsddcaff73.jpg
https://i212.photobucket.com/albums/cc108/CB1Rocket/h100%20destruction/DSCI0052_zpse60a7fbc.jpg
https://i212.photobucket.com/albums/cc108/CB1Rocket/h100%20destruction/DSCI0050_zpsfd947f85.jpg
https://i212.photobucket.com/albums/cc108/CB1Rocket/h100%20destruction/DSCI0047_zps9950ed50.jpg
https://i212.photobucket.com/albums/cc108/CB1Rocket/h100%20destruction/DSCI0046_zpsec8fe498.jpg
https://i212.photobucket.com/albums/cc108/CB1Rocket/h100%20destruction/DSCI0037_zpsbe05bd1e.jpg
https://i212.photobucket.com/albums/cc108/CB1Rocket/h100%20destruction/DSCI0033_zps77aadaf6.jpg
https://i212.photobucket.com/albums/cc108/CB1Rocket/h100%20destruction/DSCI0031_zps6083b091.jpg
https://i212.photobucket.com/albums/cc108/CB1Rocket/h100%20destruction/DSCI0029_zpsaa10a65f.jpg
https://i212.photobucket.com/albums/cc108/CB1Rocket/h100%20destruction/DSCI0028_zps06443cf4.jpg
https://i212.photobucket.com/albums/cc108/CB1Rocket/h100%20destruction/DSCI0022_zpsb405fe23.jpg
https://i212.photobucket.com/albums/cc108/CB1Rocket/h100%20destruction/DSCI0025_zpsede2cc10.jpghttps://i212.photobucket.com/albums/cc108/CB1Rocket/h100%20destruction/DSCI0024_zps4c7fe8c1.jpg
https://i212.photobucket.com/albums/cc108/CB1Rocket/h100%20destruction/DSCI0023_zpsae776ebc.jpg
cb1rocket
PostPosted: 23:30 - 26 Sep 2013    Post subject: Reply with quote
dyno graph for anyone's info, comparison versus standard.
https://i212.photobucket.com/albums/cc108/CB1Rocket/h100%20destruction/DSCI0059_zps5c2c64ce.jpg
bypass2
PostPosted: 23:34 - 26 Sep 2013    Post subject: Reply with quote
what spark plug is in it BR8HS or BR7HS if on the BR7HS maybe to hot a plug
PostPosted: 23:37 - 26 Sep 2013    Post subject: Reply with quote
Err, not sure if it is just the way I am seeing the pictures, but the paint on the barrel appears quite thick (almost like powder coating). Possible it is acting as insulation?
You have gone up a long way on the main jet, but not mentioned anything on the needle which could now be a limiting factor. That said, you suggest the plug colour is good.
cb1rocket
PostPosted: 23:55 - 26 Sep 2013    Post subject: Reply with quote
it is running a BR8HS, have been told a BR9HS would help but can't think it could contribute that much to overheating?
Kickstart: looks like powdercoating but that how's the barrel came.
Basically anything over 60mph for more than 30 secs and it nips up
bypass2
PostPosted: 00:05 - 27 Sep 2013    Post subject: Reply with quote
what aboat the oil pump setting may need more oil. I had a standard h100 running on a BR9HS that run allright. maybe BR9HS would help.
cb1rocket
PostPosted: 00:09 - 27 Sep 2013    Post subject: Reply with quote
running pre-mix for the time being.
No one seems to have pointed out whether a leak at the exhaust causes lean running? Does it?
Those who will remember I had a Suzuki GP100 that seize up on me several times, due to the carb cover blanking plugs missing which leaned out the mixture at speed. I'm thinking I have a similar problem but at the exhaust side of things
PostPosted: 00:11 - 27 Sep 2013    Post subject: Reply with quote
The heat range of a spark plug is down to how much insulation there is in it and how much heat it can thus transfer out of the combustion chamber.
I honestly do not know how well powder coating transmits heat (although I would also suspect that if it were powder coated then it would melt at any hot spots such as just above the exhaust), but it is something that would concern me when it appears to be a fairly thick coat on an air cooled engine.
You are at almost triple the power of the standard engine which does suggest a massive amount more heat being generated
PostPosted: 00:15 - 27 Sep 2013    Post subject: Reply with quote
While it might have a minor effect from changing the way the exhaust works, you are probably getting a massively greater effect from the different exhaust anyway. In theory I suppose at some revs the exhaust could push some air drawn in through a leak there back into the combustion chamber.
On the intake side an air leak can have a massive effect.
bladerunner
PostPosted: 00:34 - 27 Sep 2013    Post subject: Reply with quote
From my experience a 4 point seizure is caused by over heating...cooler plug for a start...you've nearly tripled the bhp !!!!! You may want to try as cool as a 10 or 10.5 plug even rather than just one grade hotter...but this is going to be an all or nothing motor with that tune...so expect it to kill plugs if not worked hard. And as said before...a bigger main jet maybe if it's seized with wide open throttle....if its doing it at 3/4 throttle then bigger emulsion tube and probably a different needle as well. Always start big and work your way down. I know when setting up my race rgv's on the dyno....it would need maybe 4 jet sizes different in the real world and your air cooled so possibly even more difference with air temp etc......head colour looks nice and even and on the safe side if anything so I don't think your far off. What carb are you using?
PostPosted: 00:41 - 27 Sep 2013    Post subject: Reply with quote
He is using the standard 18mm carb according to an earlier post in this thread, which strikes me as way too small for that much power.
bladerunner
PostPosted: 00:43 - 27 Sep 2013    Post subject: Reply with quote
Oh and leaking exhaust never a good thing so get that sorted however I don't think that's your main issue. Mick abbey knows how to make road bikes fast as well as race bikes...if anything I think by looking at the head and top of the piston you have a few bhp yet to gain....no sign of detonation or hot exhaust gasses causing over heating on the piston crown.....what piston to bore clearances are you using? Also it's a cast piston I'm guessing which will expand less than a forged type piston....maybe if your using a proper carb that's setup a little more bore clearence might help if your running on the close side of things?
cb1rocket
PostPosted: 01:01 - 27 Sep 2013    Post subject: Reply with quote
yes seizure is happening at WOT, Mick tells me the standard carb should be more than enough for the job. Accordingly the bigger the carb the slower the velocity of air sucked in? Please can you tell me what an over heating crown looks like?
Piston to bore clearance is as per the kit from the box.
For the barrel and piston kit, this is what i'm using.
https://www.2strokeparts.de/shop/product_info.php?pName=tuningzylinder-athena-125ccm-f%FCr-honda-mtmtx-80&cName=mtx-80-luftgek-tuningzylinder-zubeh%F6r&SESS=
Not sure whether its a forge kit or not. Its an aluminum block I know for sure with possibly what i believe is a nikasail coated bore.
m3-paul
PostPosted: 08:44 - 27 Sep 2013    Post subject: Reply with quote
To me that looks a little lean from the plug colour or maybe the flash of the camera has washed the colour out too much?
I went up two sizes on my TZR250 just with new pipes. I would go up a couple more sizes on the main on the basis you also have a pod filter and look at the oil pump. That exhaust collar looks too clean.
Mine have a light oily finish but then my oil pump is more towards the rich side to avoid seizure, but, I have never had a problem with oiling plugs.
Yamaha TZR250 - love the smell of TTS!!!!
CBR900RR Fireblade - so much fun
PostPosted: 09:30 - 27 Sep 2013    Post subject: Reply with quote
It's seized where the thickest part of the aluminium is on the piston. Overheated I would say. You might be able to rescue the barrel since that nikasil coating is goddamn hard, but the piston is clearly trashed.
Kickstart's point on the barrel coating is valid - what is that?
PostPosted: 10:29 - 27 Sep 2013    Post subject: Reply with quote
The H100 has an iron bore which can be rebored. However it could be that when bored out to 125cc it has landed up instead being plated rather than a bigger liner.
cb1rocket - I am very surprised that carb size is adequate (unless the carb has been bored out). You have ~20hp, which is about the level of power of a mid to late 1980s liquid cooled 2 stroke. As an example I think an MBX125 ran a 24mm carb (not certain, from memory), which is about 80% bigger. I don't expect this to cause the over heating but I would expect this to limit power.
There are ways to get more heat to go down the exhaust. A ceramic coating on the exhaust port would help. A ceramic coating on the cooling fins would make things a hell of a lot worse though!
PostPosted: 10:44 - 27 Sep 2013    Post subject: Reply with quote
I am not certain on the coating, it is just something that concerns me especially on a bike putting out around 3 times the power of standard (and so generating far more heat).
Think in theory being black should slightly increase the heat transfer, but the type of coating could more than counteract that
PostPosted: 10:48 - 27 Sep 2013    Post subject: Reply with quote
Know nothing about these but I'd back up Kickstart in carb size. I have a VM22 which is a 26mm carb on my 14hp bike running a 90 main jet standard but for road use it requires a 110/115 if you want to do any form of speed.
The minimum you can have is a 26mm on that and its a 140cc with less power.
misscrabstick
PostPosted: 11:08 - 27 Sep 2013    Post subject: Reply with quote
Same as Kickstart when I looked at the barrel I thought that paint looks thick anyway, that piston in my opinion has suffered due to excessive expansion/overheat, see this page
https://www.theultralightplace.com/pistons.htm
Some useful diagnosis tips there on piston failure.
The last post was made 12 years, 265 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.28 - MySQL Queries: 13 - Page Size: 140.05 Kb
