| cb1rocket |
 cb1rocket World Chat Champion
 Posted: 21:45 - 26 Sep 2013 Post subject: Tuned H100SJ back from tuners, update |
Hi all, long time since any write up about my project bike, but I have since had to resort to the workshop section - yes I crashed my H100 due to a seizure and rear wheel lock up!
The power is there, apparently 20bhp of it! However it seems to over heat and cause 4 corner seizure on the piston. Anything above 60mph and the bike seize.
I'm running a 160 jet and the plug is a standard coffee tan colour so it can't be running lean, however I have a slip on expansion chamber set up and there is a gap at the exhaust port which I'm guessing is letting air in from the exhaust side and causing it to lean out due to speed of air entering it? Is this even possible? ____________________ Honda H100S2 Rebuild - https://www.bikechatforums.com/viewtopic.php?t=253852
 Posted: 22:45 - 26 Sep 2013 Post subject: |
| dougon2wheels |
 dougon2wheels Nitrous Nuisance
| cb1rocket |
| cb1rocket |
 Posted: 23:16 - 26 Sep 2013 Post subject: |
| cb1rocket |
 Posted: 23:30 - 26 Sep 2013 Post subject: |
| bypass2 |
 bypass2 Spanner Monkey
 Posted: 23:37 - 26 Sep 2013 Post subject: |
Err, not sure if it is just the way I am seeing the pictures, but the paint on the barrel appears quite thick (almost like powder coating). Possible it is acting as insulation?
You have gone up a long way on the main jet, but not mentioned anything on the needle which could now be a limiting factor. That said, you suggest the plug colour is good.
| cb1rocket |
| bypass2 |
| cb1rocket |
 Posted: 00:09 - 27 Sep 2013 Post subject: |
running pre-mix for the time being.
No one seems to have pointed out whether a leak at the exhaust causes lean running? Does it?
Those who will remember I had a Suzuki GP100 that seize up on me several times, due to the carb cover blanking plugs missing which leaned out the mixture at speed. I'm thinking I have a similar problem but at the exhaust side of things ____________________ Honda H100S2 Rebuild - https://www.bikechatforums.com/viewtopic.php?t=253852 |
 Posted: 00:11 - 27 Sep 2013 Post subject: |
The heat range of a spark plug is down to how much insulation there is in it and how much heat it can thus transfer out of the combustion chamber.
I honestly do not know how well powder coating transmits heat (although I would also suspect that if it were powder coated then it would melt at any hot spots such as just above the exhaust), but it is something that would concern me when it appears to be a fairly thick coat on an air cooled engine.
You are at almost triple the power of the standard engine which does suggest a massive amount more heat being generated
| bladerunner |
| bladerunner |
| cb1rocket |
| Vincent |
 Vincent Banned
| m3-paul |
 m3-paul Spanner Monkey
 Posted: 09:30 - 27 Sep 2013 Post subject: |
It's seized where the thickest part of the aluminium is on the piston. Overheated I would say. You might be able to rescue the barrel since that nikasil coating is goddamn hard, but the piston is clearly trashed.
Kickstart's point on the barrel coating is valid - what is that? ____________________ a.k.a 'Geri'
| Vincent |
 Vincent Banned
| P.addy |
 P.addy Red Rocket
| misscrabstick |
 misscrabstick Crazy Courier
 Posted: 11:08 - 27 Sep 2013 Post subject: |
Same as Kickstart when I looked at the barrel I thought that paint looks thick anyway, that piston in my opinion has suffered due to excessive expansion/overheat, see this page
https://www.theultralightplace.com/pistons.htm
Some useful diagnosis tips there on piston failure. |
The last post was made 12 years, 265 days ago. Instead of replying here, would creating a new thread be more useful? |
