Datacrap system 3 alarm
killa
Won't Shut Up
PostPosted: 15:08 - 01 Oct 2013    Post subject: Datacrap system 3 alarm Reply with quote
As the title suggests, I hate this thing, when it goes wrong.
I had an issue last night where the battery has ran so slow the alarm sapped the last bit of juice and the alarm wouldn’t stop going off.
Cue me outside in the wet and cold with neighbors having a go at me for the noise. I managed to muffle the sounds of the alarm with tape and a towel and then obtain a jumpstarter from my mate.
I attached the jumpstarter but there’s nothing on the key, no lights, no nothing. So my first question is, has something gone wrong other than the battery? Or is it as flat as a pancake?
I had to leave the jump starter on overnight so that the alarm thought there was some juice. I came out this morning, couldn’t disarm the alarm with the fob and still, nothing on the key.
I’m going to pick up a proper charger tonight to charge the battery fully. Has the alarm now run out of back up or something? Will I have to replace that battery, or does it charge from the 12V supply?
Cheers Thumbs Up
*Edit* Shout to Paddy for assisting me on the phone for a bit whilst i elbowed the alarm fob with one arm and covered the speaker with my free hand Laughing
GrantT
PostPosted: 16:30 - 01 Oct 2013    Post subject: Reply with quote
sounds like its totally discharged the battery. It'll recharge off of the bike charging circuit once you've got it going again.
I've done it a few times on the Speed Four, but it's never set the alarm off strangely enough.
lihp
PostPosted: 16:34 - 01 Oct 2013    Post subject: Reply with quote
Why blame the alarm when it is your bikes electrical system that has a fault. Unless your friends jump pack is fully charged then you won't get much from it.
stu_m
PostPosted: 17:26 - 01 Oct 2013    Post subject: Reply with quote
as above why blame the alarm!
these alarms go in to a sleep mode when the battery reaches a certain discharge and if your battery has totally gone then thats probably the reason your alarm has gone off!
the only way to get the alarm out of sleep mode is to turn the ignition on then turn the alarm off with the fob
PostPosted: 17:31 - 01 Oct 2013    Post subject: Reply with quote
I'm pretty sure there is serious hate for the system 3, I hated mine and it was installed properly by someone else, qualified too Shocked
It just died, no idea why... Sad
c-m
PostPosted: 17:33 - 01 Oct 2013    Post subject: Reply with quote
The datatool system 3 is really easily bypassed if you're in a bind. I never needed to bypass mine, but I did unplug the speaker so I didn't have to have listen to those annoying beeps, but still keeping the immobilizer active.
killa
Won't Shut Up
PostPosted: 18:38 - 01 Oct 2013    Post subject: Re: Datacrap system 3 alarm Reply with quote
_Iain_ wrote:
Interrupted an interesting evening of hot sauce and efukd that did. Laughing
You weren't using it as lube were you?
As for the above comments, thanks for the input. I just had a bad evening as it was such a nightmare trying to rip the thing out from the side of the rear seat cowel which was in pitch black. It wasn't fun. No the alarm has been good for sometime but this is just annoying as the fob did fuck all when it was going off with no option to turn it off as i had no ignition, no power.
I've just put the battery on charge and the lights are green, showing near enough full charge. The bike has not been acting like full charge and now as i said, no lights or anything on dash when the key is turned. I think the bike may have died in the rain. Sad
Marmaduke
PostPosted: 18:42 - 01 Oct 2013    Post subject: Reply with quote
Fuses?
Current: '03 Tuono RSV1000, '05 Van Van, '91 Zephyr 550
Previous: Multistrada 620,Bandit 600,Kawsaki ER-5, BMW K-75
killa
Won't Shut Up
PostPosted: 18:50 - 01 Oct 2013    Post subject: Reply with quote
Marmaduke wrote:
Fuses?
Good point Thumbs Up
Any other suggestions?
Fisty
PostPosted: 19:01 - 01 Oct 2013    Post subject: Reply with quote
Take the fucking thing off. I had one fitted to my TL and it was nothing but trouble. Took all of 30 minutes to strip off.
Fatter and faster than Fret
killa
Won't Shut Up
PostPosted: 19:03 - 01 Oct 2013    Post subject: Reply with quote
Ok... how do i feed it out of the loom or whatever? Is it just plugged in with connectors? I honestly haven't been able to look at that yet.
Fisty
PostPosted: 19:11 - 01 Oct 2013    Post subject: Reply with quote
Just follow the wires from the unit to the loom, the "should" be soldered in. Find where the loom has been bridged and rejoin it.
Fisty
PostPosted: 19:19 - 01 Oct 2013    Post subject: Reply with quote
If you need a hand I am free tomorrow night.
killa
Won't Shut Up
PostPosted: 21:04 - 01 Oct 2013    Post subject: Reply with quote
Thanks bud. I'll put the battery back on tomorrow and then i'll let you know. If there's nothing on the key at all, removing the alarm won't help. I'll check fuses while im at it Wink
PostPosted: 21:06 - 01 Oct 2013    Post subject: Reply with quote
To bypass it just link the immobiliser circuits and pull the power fuse. When the internal battery runs down it'll stop wailing. Pinout diagram attached.
sickpup
Old Timer
PostPosted: 21:57 - 01 Oct 2013    Post subject: Reply with quote
So a ten year old alarm thats working perfectly is to blame because you didn't put it into service mode?
Rowey
PostPosted: 21:58 - 01 Oct 2013    Post subject: Reply with quote
When I got my Ninja the guy before me had let the bike's battery run down a few times and used a cheap trickle charger to keep the battery topped up.
A few weeks of owning the bike the Datatool 3 did the same as yours. It started going off randomly and the fob wouldn't turn it off until I switched the ignition on and then hit the fob a few seconds later. It got worse until one day it went off a few times during the day, then the night. I ended up removing the cover and the speaker with it.
When I removed the cover I saw that the internal battery (green one in Pete's picture) had split and leaked every where. There was also a bulging capacitor. I rang Datatool and they said that draining the battery, a faulty charging system or a cheap trickle charge can kill them.
If your alarm has done the same as mine then the only fix is to get a whole new "motherboard" or removed it all. Datatool don't make the motherboard any more. I bought a full system from ebay and just swapped all the internals out of the fried box. Works like a charm now.
Hope this helps.
ZX6R C6F.
woo
PostPosted: 08:20 - 02 Oct 2013    Post subject: Reply with quote
my advice take it and throw it away into the fires of mount doom!
datatool alarms well alarms in general have given me nothing but greif better to get a tracker from www.tracker.co.uk than waste money and time on alarms.
id rather venture into the void and free morgoth than deal with these pesky alarms
Elen sila lummen omentielvo!
prizefighter
PostPosted: 08:33 - 02 Oct 2013    Post subject: Reply with quote
I took mine out a few weeks ago as it had completely immobilised my bike. As people have said, just trace the wires back into the loom, cut out the alarm and solder the split wires back together.
The amount of wires coming out of the alarm made the job seem pretty daunting but it really wasn't Thumbs Up
Just make sure you heatshrink and then tape up the exposed wires afterwards though.
ZX6r J1
Aprilia RSV1000R
killa
Won't Shut Up
PostPosted: 09:06 - 02 Oct 2013    Post subject: Reply with quote
I didn't have a chance, there was no ignition to switch it into that mode.
killa
Won't Shut Up
PostPosted: 09:13 - 02 Oct 2013    Post subject: Reply with quote
Thanks for the input guys, I will give it a look tonight or at the weekend. I was just disappointed that with the fob but no power, I can't shut the thing up.
PostPosted: 11:09 - 02 Oct 2013    Post subject: Reply with quote
The alarm doesn't cut main power, in fact it requires it. Check your 30a fuse.
lihp
PostPosted: 13:24 - 02 Oct 2013    Post subject: Reply with quote
Don't need ignition to go to service mode.
Top button, then press bottom button with 3 seconds of the indicators stopping flashing iirc
The last post was made 12 years, 346 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 136.69 Kb
