Air filter pods.
Hetzer
PostPosted: 18:03 - 03 Oct 2013    Post subject: Air filter pods. Reply with quote
I'm thinking of junking the airbox and fitting individual pods to the carbs.
In Japan I had to take the carbs off my Blade and fit a K&N jet kit as I'd fitted a full system (Micron). It involved drilling holes in x4 somethings. Everything went back together fine and the bike ran perfectly.
Now I read up on doing it again and everyone sucks their teeth and mentions dyno runs and carb-balancing. Did I just get lucky with the Blade or is it safe to wing it again?
Gazza M
PostPosted: 18:33 - 03 Oct 2013    Post subject: Reply with quote
I've got pods on my ZRX - I'm pretty sure it's been set up properly on a dyno though as the carbs are the 40mm ones off a ZZR1100, and I have a custom exhaust (all done by the blokes before me).
Couple of threads here and here from the ZRX forum may be worth a read - ask them too as I don't really know how much extra setup will be required.
But yeah, they look the dog's danglies and make a sweet induction sound too. Not to mention the extra space you get under the seat! Smile
EDIT: having a look around people are saying you will almost definitely have to rejet, although baseline settings are fairly easy to find depending on which exhaust you have, then you can put it on a dyno to see what adjustments if any are needed.
Past: '07 YBR125, '00 GPZ500S, '99 ZRX1100, '98 CBR600 track bike, '97 ZX9R
Present: '05 R6 track bike, 140 pit bike
Hetzer
PostPosted: 18:55 - 03 Oct 2013    Post subject: Reply with quote
I've read that the low-end issue is due to K&N needles being pretty shit. Ivans are highly rated and don't have the same issues. Thinking
Already seen those links, but thanks anyway. Thumbs Up
Yes, ZRX.
I can do all the work myself, just not the fettling/fine tuning. Apparently the K&N recommended clip settings are well over-rich.
PostPosted: 19:36 - 03 Oct 2013    Post subject: Reply with quote
Bare intake trumpets look awesome on these. Probably end up with bits in your engine, which isn't ideal though.
temeluchus
PostPosted: 20:44 - 03 Oct 2013    Post subject: Reply with quote
You will NEVER get the bottom end to perform as well as an airbox with pods, no matter how much you fuck with it.
Fitting a DJ stage 3 kit, getting it well set up will let the motor run OK and may even give you a little bit more power up top, but CV carbs don't work well with the turbulent slow air you get with no airbox when revs are low. You can drill the slide holes to be a little larger and that overcomes the problem a little.
I went down the same route with my GPz1100E (same engine) and put up with the slight performance hit low down as the ease of servicing is worth it.
If you are deadly serious and want to spend some money, Mikuni RS38, Keihin FCR39 or Lectron are the best bet for getting it running well with pods.
Fizzer Thou
PostPosted: 22:18 - 03 Oct 2013    Post subject: Reply with quote
I fitted pods to the Exup and it has made a differance to the roll on power from about 4,000 rpm upwards but has lost some bottom end rideability despite the fitting of a Stage 3 K&N jetting kit
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Honda%20750/My%20bikes/20100611_1.jpg
On some bikes the slides are drilled,on others the springs are replaced.The design/flow rate of the Dynojet main jets are also differant to the standard Mikuni mains.But the biggest change are the needles,and this is where most of the development went into the kit.I had the Stage 1 DJ kit with the standard airbox but with a standard replacement K&N air filter,and this improved everything throughout the rev range-even improving the fuel consumption.As far as I can make out,it is the intake length which smoothes the air flowing into the carb from the airbox.When pods are fitted,this smoother airflow is disrupted,so causing the low rev stumble.According to the Exup1000 forum,some have gone back to the standard airbox because of this disruption.
Factory Pro also make jet kits https://www.factorypro.com/products/carb.html
Always have a 'Plan B'
evoboy
PostPosted: 22:34 - 03 Oct 2013    Post subject: Reply with quote
I have foam 'pods' on my ZRX11, with ZZR cams, full Akra system and a DJ stg 3 kit.
It pulls perfect low down, so much so it reaches for the sky quite abruptly at 3k rpm if your a bit eager on the grip....but will also pull 5th from 30mph at very low revs, 2 up, without any hesitation what so ever.
When I got the bike, it was set to the DJ specs. It would judder at around 1/4 throttle. After chatting with temeluchus about it, I dropped the needles a notch and it ran perfect.....apart from the fact it would'nt rev beyond 7k...but that turned out to be poor pod filters that had a 'restriction' inside.
It fuels perfect IMO and is super smooth to ride....it looks and sounds far better aswell.
APT Motorcycles
temeluchus
PostPosted: 22:35 - 03 Oct 2013    Post subject: Reply with quote
The airbox also causes the air to speed up, this aids the operation of the vacuum controlled slides.
If money is no object, straight slide carbs are a better bet for pod filter equipped bikes as it avoids the hassles of the CV's vacuum jiggery pokery,
Hetzer
PostPosted: 08:17 - 04 Oct 2013    Post subject: Reply with quote
Vincent wrote:
Does the bike not run too well with the standard airbox?
It runs perfectly, so yes, I'm a fool for wanting to mess with it.
As I understand it the DJ instructions are to put the needle on the 4th clip. You have yours on the 3rd? And everything else per the instructions? Did you have to re-balance the carbs? Any dyno runs involved?
My Rex is nearly the same as yours; full Arata (Ti) system and ZZR cams.
I'm thinking maybe foam pods reduce the turbulence...?
Hetzer
PostPosted: 08:40 - 04 Oct 2013    Post subject: Reply with quote
I guess these might have been the jobby if they were set up for my bike. But they're not.
https://www.ebay.co.uk/itm/Mikuni-RS38-D19-K-flatslide-carbs-and-filters-/111180910040?pt=UK_Motorcycle_Parts_13&hash=item19e2e60dd8
stevo as b4
PostPosted: 09:32 - 04 Oct 2013    Post subject: Reply with quote
As long as your using big enough air filters spaced out enough from the carbs and fitted with bell mouth plates inside, I can see no reason why with enough tuning time and re-jetting that you cannot make individual air filters work well, and give decent carburation throughout the rev and load range.
It's the same with 2strokes, where people say it's a huge no no to fit individual air filters and bin the airbox. If the filters are big enough in terms of surface area and the end plate is sufficiently far from the carb mouth, then you should be able to jet them up to get decent fueling, you might not gain power or torque over running the std airbox, but with the right filters and the right dyno tuned setting up, it should end up rideable and smooth IMO.
Hetzer
Vincent wrote:
I was reading about CR, smooth Bore carbs on the CB1100 forum the other day. A lot of septics spend a fortune on these carbs and I was surprised to find that better alternatives are out there for this particular bike, including using early GSXR1100 carbs which fit with very little alterations. It's done on the CBFs as the original carbs were suspect, especially if trying to use with a tuned engine.
They may look nice but fitting aftermarket carbs on a road bike can be a real pain in the arse, same with filters. I'd stick with something that's known to work with this particular bike then you shouldn't be back and forth to the Dyno trying to get it right.
Is there a turbo for the ZRX? Twisted Evil
Which is why I'm hoping I can drop a kit into the existing carbs according to a known formula and have it all working fine just like it did with the Blade in Japan. Praying
No interest in a turbo at all.
P.
PostPosted: 09:38 - 04 Oct 2013    Post subject: Reply with quote
No, this is not the Hetzer I know. Fvck this, scvm that. More power, Oh no thank you.
Thinking Wink
stevo as b4
PostPosted: 10:10 - 04 Oct 2013    Post subject: Reply with quote
You can't blame the big man for wanting to keep the character of a big angry snarling rasp, but just to have a bit more of it! Thumbs Up
On a bike like the ZRX i'd go for high compression pistons and a big bore kit every time over a turbo! Once you start lowering compression for big boost Forced induction set ups you lose some low end torque and ruin the low down roll on response to an extent.
Big instant torquey grunt on a litre+ naked is where it's at. I'd not turbo anything that was not a long low slippery fully faired machine, with 200mph+ aspirations personally.
P.
PostPosted: 10:17 - 04 Oct 2013    Post subject: Reply with quote
Never ridden a ZRX, naturally though, I expect power from a litre bike. Laughing
Hetzer
PostPosted: 10:22 - 04 Oct 2013    Post subject: Reply with quote
Vincent wrote:
£300(ish), would get you a set of these:-
https://page22.auctions.yahoo.co.jp/jp/auction/l214152171
About £200 at the moment. I'm tempted, I could get my in-laws to grab them, but there's not enough info on them. And it looks like the auction is ending in less than an hour.
Hetzer
PostPosted: 10:33 - 04 Oct 2013    Post subject: Reply with quote
Vincent wrote:
They may shoot up in a bit, I've seen them go for up to £700.
Well that would be plain daft, brand new Mikunis are going for around £500 from the states.
Hetzer
PostPosted: 10:55 - 04 Oct 2013    Post subject: Reply with quote
Well, the chap at PDQ says it's entirely possible for a bloke like me to drop the kit in per the instructions and get a perfectly well-running result without recourse to balancing or dynoing (so long as I don't fiddle with anything not included in the instructions).
Otherwise it's £180 for three hours' worth of setup on their dyno, on top of the £200 plus for the kit and pods.
He also says they remove Ivan kits to replace them with K&N stuff.
temeluchus
PostPosted: 10:59 - 04 Oct 2013    Post subject: Reply with quote
Won't fit the ZRX motor, and are CV's in any case so no use at all.
The last post was made 12 years, 129 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 140.64 Kb
