| Hetzer |
 Hetzer Super Spammer
| Gazza M |
 Gazza M Crazy Courier
 Posted: 18:33 - 03 Oct 2013 Post subject: |
I've got pods on my ZRX - I'm pretty sure it's been set up properly on a dyno though as the carbs are the 40mm ones off a ZZR1100, and I have a custom exhaust (all done by the blokes before me).
Couple of threads here and here from the ZRX forum may be worth a read - ask them too as I don't really know how much extra setup will be required.
But yeah, they look the dog's danglies and make a sweet induction sound too. Not to mention the extra space you get under the seat!
EDIT: having a look around people are saying you will almost definitely have to rejet, although baseline settings are fairly easy to find depending on which exhaust you have, then you can put it on a dyno to see what adjustments if any are needed. ____________________ Past: '07 YBR125, '00 GPZ500S, '99 ZRX1100, '98 CBR600 track bike, '97 ZX9R
Present: '05 R6 track bike, 140 pit bike
| _Iain_ |
 _Iain_ Banned
 Posted: 18:36 - 03 Oct 2013 Post subject: |
You have a ZRX dont you?
If so, dynojet kit stage 3 required. Can work, has been done however the motor runs iffy low down, so not much good unless you're riding it hard 24/7. Workshops been having fun with a customers trying to trace this non existant fault, turns out it's a fairly common complaint.
Depends how you plan to use it really. ____________________ Please be aware that the above post may be full of complete nonsense.
| Hetzer |
 Posted: 18:55 - 03 Oct 2013 Post subject: |
I've read that the low-end issue is due to K&N needles being pretty shit. Ivans are highly rated and don't have the same issues.
Already seen those links, but thanks anyway.
Yes, ZRX.
I can do all the work myself, just not the fettling/fine tuning. Apparently the K&N recommended clip settings are well over-rich. ____________________ "There's the horizon! Ride hard, ride fast and cut down all who stand in your way!" |
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 19:36 - 03 Oct 2013 Post subject: |
Bare intake trumpets look awesome on these. Probably end up with bits in your engine, which isn't ideal though. ____________________ My Flickr |
| temeluchus |
| Fizzer Thou |
 Posted: 22:18 - 03 Oct 2013 Post subject: |
I fitted pods to the Exup and it has made a differance to the roll on power from about 4,000 rpm upwards but has lost some bottom end rideability despite the fitting of a Stage 3 K&N jetting kit
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Honda%20750/My%20bikes/20100611_1.jpg
On some bikes the slides are drilled,on others the springs are replaced.The design/flow rate of the Dynojet main jets are also differant to the standard Mikuni mains.But the biggest change are the needles,and this is where most of the development went into the kit.I had the Stage 1 DJ kit with the standard airbox but with a standard replacement K&N air filter,and this improved everything throughout the rev range-even improving the fuel consumption.As far as I can make out,it is the intake length which smoothes the air flowing into the carb from the airbox.When pods are fitted,this smoother airflow is disrupted,so causing the low rev stumble.According to the Exup1000 forum,some have gone back to the standard airbox because of this disruption.
Factory Pro also make jet kits https://www.factorypro.com/products/carb.html ____________________ Just talk bikes.What else is there?
Always have a 'Plan B'
| evoboy |
 evoboy World Chat Champion
 Posted: 22:34 - 03 Oct 2013 Post subject: |
I have foam 'pods' on my ZRX11, with ZZR cams, full Akra system and a DJ stg 3 kit.
It pulls perfect low down, so much so it reaches for the sky quite abruptly at 3k rpm if your a bit eager on the grip....but will also pull 5th from 30mph at very low revs, 2 up, without any hesitation what so ever.
When I got the bike, it was set to the DJ specs. It would judder at around 1/4 throttle. After chatting with temeluchus about it, I dropped the needles a notch and it ran perfect.....apart from the fact it would'nt rev beyond 7k...but that turned out to be poor pod filters that had a 'restriction' inside.
It fuels perfect IMO and is super smooth to ride....it looks and sounds far better aswell. ____________________ Suzuki GT250 x7------- Fazer 600------CB250RS------Aprilia Rally 70----- Bandit 600
APT Motorcycles |
| temeluchus |
| Vincent |
 Vincent Banned
| Hetzer |
 Posted: 08:17 - 04 Oct 2013 Post subject: |
| Vincent wrote: | Does the bike not run too well with the standard airbox? |
It runs perfectly, so yes, I'm a fool for wanting to mess with it.
| evoboy wrote: | I have foam 'pods' on my ZRX11, with ZZR cams, full Akra system and a DJ stg 3 kit.
It fuels perfect IMO and is super smooth to ride....it looks and sounds far better aswell. |
As I understand it the DJ instructions are to put the needle on the 4th clip. You have yours on the 3rd? And everything else per the instructions? Did you have to re-balance the carbs? Any dyno runs involved?
My Rex is nearly the same as yours; full Arata (Ti) system and ZZR cams.
I'm thinking maybe foam pods reduce the turbulence...? ____________________ "There's the horizon! Ride hard, ride fast and cut down all who stand in your way!" |
| Hetzer |
| Vincent |
 Vincent Banned
 Posted: 09:16 - 04 Oct 2013 Post subject: |
I was reading about CR, smooth Bore carbs on the CB1100 forum the other day. A lot of septics spend a fortune on these carbs and I was surprised to find that better alternatives are out there for this particular bike, including using early GSXR1100 carbs which fit with very little alterations. It's done on the CBFs as the original carbs were suspect, especially if trying to use with a tuned engine.
They may look nice but fitting aftermarket carbs on a road bike can be a real pain in the arse, same with filters. I'd stick with something that's known to work with this particular bike then you shouldn't be back and forth to the Dyno trying to get it right.
Is there a turbo for the ZRX?  ____________________ Space Is Deep |
| stevo as b4 |
| Hetzer |
| P. |
 P. Red Rocket
| Vincent |
 Vincent Banned
| Vincent |
 Vincent Banned
 Posted: 10:01 - 04 Oct 2013 Post subject: |
| stevo as b4 |
 Posted: 10:10 - 04 Oct 2013 Post subject: |
You can't blame the big man for wanting to keep the character of a big angry snarling rasp, but just to have a bit more of it!
On a bike like the ZRX i'd go for high compression pistons and a big bore kit every time over a turbo! Once you start lowering compression for big boost Forced induction set ups you lose some low end torque and ruin the low down roll on response to an extent.
Big instant torquey grunt on a litre+ naked is where it's at. I'd not turbo anything that was not a long low slippery fully faired machine, with 200mph+ aspirations personally. |
| P. |
 P. Red Rocket
 Posted: 10:17 - 04 Oct 2013 Post subject: |
Never ridden a ZRX, naturally though, I expect power from a litre bike.  |
| Hetzer |
 Posted: 10:22 - 04 Oct 2013 Post subject: |
About £200 at the moment. I'm tempted, I could get my in-laws to grab them, but there's not enough info on them. And it looks like the auction is ending in less than an hour. ____________________ "There's the horizon! Ride hard, ride fast and cut down all who stand in your way!" |
| Vincent |
 Vincent Banned
 Posted: 10:31 - 04 Oct 2013 Post subject: |
| Hetzer wrote: |
About £200 at the moment. I'm tempted, I could get my in-laws to grab them, but there's not enough info on them. And it looks like the auction is ending in less than an hour. |
They may shoot up in a bit, I've seen them go for up to £700. ____________________ Space Is Deep |
| Hetzer |
| Hetzer |
| temeluchus |
The last post was made 12 years, 127 days ago. Instead of replying here, would creating a new thread be more useful? |
