| DrSnoosnoo |
 DrSnoosnoo World Chat Champion
 Posted: 18:13 - 05 Oct 2013 Post subject: Electrics - reg rec again |
So following from my broken down thread earlier. I got her home using no lights and got the multimeter out.
The battery was at 11.56V with engine off.
It then stayed at 11.5V when the engine had been jumped and idling at 1.5k
Then again, the voltage stayed at 11.5V at 5-6k revs
I took my side fairing off to get into the reg rec and have a look at this. I was shocked. Wires from stator to connector block, one had obviously cooked the surrounding plastic so bare wire was showing.
Then I looked into the connector block and saw melted connector block with more exposed wiring. Ive tried to attach pictures but tablets aren't the best to use for this..
https://db.tt/t3Q7MwxS
https://db.tt/zZ15z4Qn
Links are https://db.tt/t3Q7MwxS
My questions are, what are those connector blocks actually called so I can get a new one to replace them and also, providing no wires are exposed and connecting to each other, what figures should I look for with the voltmeter?
Oooooo also its a 6 wired plug, could I get a better reg rec to replcae this one out with like what has been mentioned in the past?
Cheers ____________________ I'm Sam; Northern, Ginger, Lover
Did have: '95 ZZR600 '83 CG125 '97 ZZR1100 '15 Hypermotard 821 SP Do Have: '10 ZX10R |
| CaNsA |
 CaNsA Super Spammer
| DrSnoosnoo |
| DrSnoosnoo |
| Vincent |
 Vincent Banned
 Posted: 21:17 - 05 Oct 2013 Post subject: |
It's a six-pin female spade, wiring connecter block. You won't be able to get one from the maker, they come with the loom - you'll need to use a specialist supplier. Should be one on eBay. You see the bent tang on the back of the exposed spade connecter? You need to get a small screwdriver or similar to bend down that tang to get the wires out. Make a record of where they go before removing.
https://kojaycat.co.uk/Connectors-Bullet ____________________ Space Is Deep
| DrSnoosnoo |
| Vincent |
 Vincent Banned
| DrSnoosnoo |
 Posted: 09:17 - 07 Oct 2013 Post subject: |
Aye, dropbox takes a bit of extracting the actual image URL from.
You can buy terminals suitable for fitting in connector blocks from a company called Vehicle wiring products.
I personally would cut the connector block off and replace them with non-insulated bullet connectors with individual silicone covers. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| J.M. |
 J.M. World Chat Champion
 Posted: 11:17 - 07 Oct 2013 Post subject: |
| DrSnoosnoo |
| DrSnoosnoo |
The last post was made 13 years, 9 days ago. Instead of replying here, would creating a new thread be more useful? |
