Electrics - reg rec again
DrSnoosnoo
PostPosted: 18:13 - 05 Oct 2013    Post subject: Electrics - reg rec again Reply with quote
So following from my broken down thread earlier. I got her home using no lights and got the multimeter out.
The battery was at 11.56V with engine off.
It then stayed at 11.5V when the engine had been jumped and idling at 1.5k
Then again, the voltage stayed at 11.5V at 5-6k revs
I took my side fairing off to get into the reg rec and have a look at this. I was shocked. Wires from stator to connector block, one had obviously cooked the surrounding plastic so bare wire was showing.
Then I looked into the connector block and saw melted connector block with more exposed wiring. Ive tried to attach pictures but tablets aren't the best to use for this..
https://db.tt/t3Q7MwxS
https://db.tt/zZ15z4Qn
Links are https://db.tt/t3Q7MwxS
My questions are, what are those connector blocks actually called so I can get a new one to replace them and also, providing no wires are exposed and connecting to each other, what figures should I look for with the voltmeter?
Oooooo also its a 6 wired plug, could I get a better reg rec to replcae this one out with like what has been mentioned in the past?
CaNsA
PostPosted: 18:35 - 05 Oct 2013    Post subject: Reply with quote
Protip: If you lose the s from https your images will show up.
DrSnoosnoo
PostPosted: 18:47 - 05 Oct 2013    Post subject: Reply with quote
Ive done that dude but they obv dont work still. Must be because they're dropbox
DrSnoosnoo
PostPosted: 19:43 - 05 Oct 2013    Post subject: Reply with quote
DrSnoosnoo
PostPosted: 21:21 - 05 Oct 2013    Post subject: Reply with quote
Vincent wrote:
It's a six-pin female spade connecter block. You won't be able to get one from the maker, they come with the loom - you'll need to use a specialist supplier. Should be one on eBay.
I was hoping I could get those spade connectors out of the current block and replace what needs replacing and put them in a new one. So I wont be able to find a shop that sells them, I mean in person so I can get something done tomorrow. Its my form of transport to work
DrSnoosnoo
PostPosted: 09:02 - 07 Oct 2013    Post subject: Reply with quote
Thanks for that info, I've ordered one of them.
I didn't get out to the garage yesterday to have a tinker because we bought a pet instead!
PostPosted: 09:17 - 07 Oct 2013    Post subject: Reply with quote
Aye, dropbox takes a bit of extracting the actual image URL from.
You can buy terminals suitable for fitting in connector blocks from a company called Vehicle wiring products.
I personally would cut the connector block off and replace them with non-insulated bullet connectors with individual silicone covers.
J.M.
PostPosted: 11:17 - 07 Oct 2013    Post subject: Reply with quote
https://photos-4.dropbox.com/t/0/AABI6nsAUmoQ__kKb5qmzX4udifypkKJaqh1eymYte2fdA/12/133422869/jpeg/320x320/1/_/0/2/2013-10-05%2017.19.31.jpg/OSO3TGb-5AASQBsX8TVh3tbt6oqY9YOl0E7fftXvfs0
https://photos-4.dropbox.com/t/0/AACZZBVFT-oJT1V-5NsyiZQDiEycF1RKdsarIoWH2bWrGA/12/133422869/jpeg/320x320/1/_/0/2/2013-10-05%2017.19.25.jpg/QWj7e-I53wrViEFHA6pkErQqBOIW2fH_GEkRS-ew4V4
I would probably do this too.
2004 R1 & 2018 XSR900
DrSnoosnoo
PostPosted: 11:55 - 07 Oct 2013    Post subject: Reply with quote
thanks for the pictures J.M!
And I've got a new block ordered with new spades so I'm gonna whip that full block off and get everything neat and clean again. I'll update with pictures again soon!
DrSnoosnoo
PostPosted: 09:54 - 08 Oct 2013    Post subject: Reply with quote
So I'm waiting for the connector block so I went to the garage to try take some readings from the stator.
I had the battery on charge on the optimate since saturday.
I took the plug off the rectifier and took the waterproof casing off - it was melted to one of the yellow phase wires.
I unplugged this lot from the stator to expose the three phase (I'm gonna call them) wires and it fired up off the battery, this was reassuring meaning I hadn't totally killed the battery. The multi meter showed around 36 AC V between each pair of phases at idle then around 60 AC V at about 4-5k. I took that as the stator being ok!
I simply got some electrical tape, separated all the touching, exposed wires (when I say all, I mean 2) and wrapped them to stop them from shorting each other. Got the multimeter out at the connector end and got the same V readings as down at the stator so to me it meant there was no breaks in the wires.
Plug them into the reg rec with some fiddling to make sure everything was connected and fired her up again. V at the battery not running was about 12.5V then at idle 13.4-9V then at 4/5 k 14.39 V. System charging!
But my headlight is blown, another task to tackle
The last post was made 13 years, 11 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.39 - MySQL Queries: 13 - Page Size: 78.57 Kb
