Motoped
Bike Chat Forums Index -> Biking News & Rumours
RhynoCZ
PostPosted: 10:59 - 06 Oct 2013    Post subject: Motoped Reply with quote
This little thing weights only 50kg and it was meant to be a downhill bike without the need of pedaling up hills. The engine, seat and tank is from Honda XR50, the rest of it is from a downhill bike in frame of their own construction. It all started as a kickstarter project, their goal was 250 000 USD, they could get 160k USD. Prototypes are already for sale. You can buy it completed or just the frame, swing arm and some other bits and finish it yourself. As I understand it, you may choose the engine, wheels, pedals, front end and so on = you can build it on low budget.
Original link: https://www.motorkari.cz/clanky/moto-novinky/neuvedeno/motoped-downhill-bike-s-pitbike-motorem-26281.html
The manufacturer: https://www.motopeds.com/
https://img.motorkari.cz/upload/images/cache/clanky/2013-09/26281/20130912073208-motopeds_50cc_jpg_resize_1000x830__type_jpg_.jpg
https://img.motorkari.cz/upload/images/cache/clanky/2013-09/26281/20130912073208-motopeds_155cc_jpg_resize_1000x830__type_jpg_.jpg
https://img.motorkari.cz/upload/images/cache/clanky/2013-09/26281/20130912073208-motopeds_50cc_2_jpg_resize_1000x830__type_jpg_.jpg
https://img.motorkari.cz/upload/images/cache/clanky/2013-09/26281/20130912073208-motopeds_155cc2_jpg_resize_1000x830__type_jpg_.jpg
PostPosted: 11:16 - 06 Oct 2013    Post subject: Re: Motoped Reply with quote
I had an idea to do this about 8/9 years ago.
Yet, I still reckon my idea was better Smile.
Weighs 'only' 50kg.
That is the big issue to my mind.
They have taken the weak stuff from a bike, but still got most of the weight of a motorbike.
Google shows a CR85 listed as 63.5kg.
Ok, it's a bit more. But for that extra 13.5kg you get much stronger wheels, suspension and brakes. You also get a rip-snorting 2 stroke motor. I appreciate the cub motors are getting pretty frisky these days, but the stock 2 stroke is often making over 20hp and has tuning potential on top!
Using a pit bike frame is lazy and I'm not convinced the best solution.
If it's a case of anything with a loop or similar, I think electric is a much better solution for this sort of thing. Can be a fair bit lighter.
However, you do lose out if you want to go longer distances without stopping to swap batteries etc.
prawny1
PostPosted: 11:33 - 06 Oct 2013    Post subject: Reply with quote
bodywork says crf engine says lifan Laughing .
Seating position looks wrong for "down hill" mtb riding and too far forwards to pedal whilst sitting which you would need to do on a public road (the sitting part).
I would much prefer a decent Honda camino with longer shocks and a kx60/80 front end (laced to camino rim).
hellkat wrote:
RhynoCZ
PostPosted: 11:34 - 06 Oct 2013    Post subject: Reply with quote
You actually gave me an idea, do you think it'd be possible for a rider to charge up the batteries via pedaling? I've no idea of how much power does it require to charge up a battery, but if pedaling was enough to slowly charge it, it'd be actually quite good. Thinking
PostPosted: 11:37 - 06 Oct 2013    Post subject: Reply with quote
Looks like the answer to a question that nobody was asking: where can I buy a very heavy expensive bicycle with no seat height adjustment that can only be used offroad?
Why are they even showing it with road tyres? I'm really baffled as to who the market for this would be.
PostPosted: 12:13 - 06 Oct 2013    Post subject: Reply with quote
Yes.
While you're riding, it'd be a bit silly, as you'd be better to use the power directly to the ground in most cases, rather than converting it to electricity, storing it in a lossy format and back again.
Charging a battery takes a chunk more power than it gives out. You'll also then lose some when converting that back to movement.
Much better is to have batteries which you can then swap out which are charged by solar/vehicle/genny/a bigger battery.
This is what RC vehicles tend to do.
Oh and I don't see any gearing to add to Rogerborg's critique.
If it was intended for DH, I'd expect to see 9/10 at the back.
fatpies
PostPosted: 12:29 - 06 Oct 2013    Post subject: Reply with quote
Er Solex velosolex 4800?
TBH you could make a cheap one with a Halford bicycle and a petrol chainsaw.
PostPosted: 12:57 - 06 Oct 2013    Post subject: Reply with quote
Wouldn't be great for off-road at a decent pace.
My idea was to use a (decent) air cooled minimoto engine.
Link it to the bike gears.
Should add a lot less weight with a lightweight gearless centrifugal clutch 2 stroke compared to a relatively heavy 4 stroke.
Maybe WC if you want a bit more go, but you can get about 6jp from an air cooled one. When you start getting to need everything even stronger, you might as well just get that CR85 in the first place to my mind.
prawny1
PostPosted: 12:58 - 06 Oct 2013    Post subject: Reply with quote
I would imagine that the effort involved with charging the battery would leave you with less potential energy than you put in.
Just think how long it takes to charge a battery vs your potential range, You could potentially pedal for four + hours to get one hours range.
If you set it up to only charge under coasting that would be free energy.
PostPosted: 13:13 - 06 Oct 2013    Post subject: Reply with quote
Also meant to say - the added cost and weight of regenerative charge controllers is rarely worth it.
The same money could be spent on getting better batteries, giving you a better overall solution.
Remember, the 'coasting' thing will be slowing you down if it's taking energy from the drive train.
Fine if you're going to be braking anyway.
moonzoomer
PostPosted: 23:51 - 06 Oct 2013    Post subject: Reply with quote
Prefer this one which is available in 50cc and 125 cc
https://ww1.prweb.com/prfiles/2009/08/06/118415/madass125003.jpg
PostPosted: 00:30 - 07 Oct 2013    Post subject: Reply with quote
Prefer it for what?
It weighs more than my full size KTM which makes probably 3x the power of the 125 with massively better suspension, handling and grip.
My 250cc trials bike weighs massively less than that, probably has a similar top speed but a lot more mid-range.
Unless you're stuck on taking a pillion, they just seem to be a slow and overweight pit bike.
moonzoomer
PostPosted: 00:37 - 07 Oct 2013    Post subject: Reply with quote
G wrote:
Prefer it for what?
I prefer the proper brakes and tyres plus it can be road registered, It only weights 95kg, I also like the tuning parts available at very little cost plus I can turf it in the back of the car easily. Just something for a bit of fun.
PostPosted: 00:41 - 07 Oct 2013    Post subject: Reply with quote
But why not just get a pitbike that is similar, but weighs a chunk less and is generally a lot cheaper?
(They too can be road registered/are available road registered, as with the KTM.)
Something like the KTM on the other hand would have to be significantly detuned to come near the peak power you are getting from a highly tuned madass; ditto for handling and if you've got SM wheels, you're going to be doing massively better in the way of grip, I'd say.
I actually really liked the idea of the madass before I saw the stats - as it is, it just seems pointless because the only way it's better than any of it's 'rivals' is that it can take a pillion, albeit badly with their feet resting on the swingarm.
moonzoomer
PostPosted: 00:51 - 07 Oct 2013    Post subject: Reply with quote
I just like the light weight, the big wheels, full size and the low cost and that it is a 4T, I have my ancient ty 175 Yamaha and TL 125 for near sensible off road stuff , they are pretty low powered machines especially the Honda which only makes around 9 bhp at best but it still climbs near vertical walls.
PostPosted: 01:00 - 07 Oct 2013    Post subject: Reply with quote
They are no more 'full size' wheels than a pitbike.
Both are 16" with skinny tyres - pit bikes get fatter tyres.
Weird that you like 4 stroke AND tuning.
95kg, that's about what my road legal KTM was.
What I was more trying to get at was - what will it actually do better than the other options?
In what situation does any of these stats actually make sense over other ways you could spend your money?
If it actually cost less than a road legal pit bike, I could see some argument that it was a choice.
But second hand they always seem to be more for a similar cc pitbike that's road legal - and a lot more than one without a v5.
moonzoomer
PostPosted: 01:09 - 07 Oct 2013    Post subject: Reply with quote
I like the theory behind the mountain bike conversion but it has a very poor centre of gravity and I doubt that honda engine makes any more than 2 bhp at best , had it have had a better design and a lower centre of gravity it would have made sense, I enjoy playing with small 4T engines, my own monkey bike started life as a 110cc semi auto but is now 180cc with watercooling, mono shock with full alloy long arm,full Yoshi system, disc brakes etc and from time to time a supercharger is fitted, just a bit of craic and no serious use as it can go through a back tyre in 25 miles.
PostPosted: 01:28 - 07 Oct 2013    Post subject: Reply with quote
The link to the mountainbike wannabe thing shows it using a variety of engines including a big capacity DOHC water cooled engine.
The question was - what riding situation (apart from taking a pillion) do you consider a madass to be better than other alternatives that weigh similar or less than it?
Oh and by the way, the CRF70 style pit bikes actually have a bigger dimater front wheel than the madass.
nathan k
PostPosted: 11:23 - 08 Oct 2013    Post subject: Reply with quote
A 4 stroke engine defeats the whole point of it being light? As mentioned a 50cc bottom end could yield 21hp+ with the right tuning...Now that would be fun...Fuck downhill riding just control that beast lol
Jonathan A
PostPosted: 12:35 - 12 Oct 2013    Post subject: Reply with quote
Looks like a toy for rich peoples. Could be sold in Harrods next to the £40,000 Pogo stick.
The last post was made 13 years, 19 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.29 - MySQL Queries: 13 - Page Size: 112.75 Kb
