| Draco87 |
 Draco87 Renault 5 Driver
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 18:52 - 04 Oct 2013 Post subject: |
I think the mixture is too lean. If it was too rich the engine would run colder, VTR1000SP had rich mixture on the back cylinder to cool down the exhaust valves. Take of the spark plug and check it for:
https://www.aa1car.com/library/reading_spark_plugs.jpg ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
| Draco87 |
 Posted: 22:34 - 05 Oct 2013 Post subject: |
Thanks for your reply it has been very helpful the problem o have noticed is when I run the run the bike I can smell a petrel scent from the engine and I had changed the spark plug due to issues starting the old one had alot of black soot on the bottom, ive had some advice that the bike may be running too rich and by doing some research on the plug it also corrisponse with that but I do still have trouble starting without the choke and the bike seems to be using a lot of fuel |
| RhynoCZ |
| Draco87 |
| RhynoCZ |
 Posted: 14:12 - 06 Oct 2013 Post subject: |
Well, the easiest thing to do here is to take the manual and set the carburetor to default settings. The mixture is probably too lean = too much air coming through the carburetor = not enough fuel going into the combustion chamber. Also use proper spark plug and air filter.
About the smell, does your engine lose oil or have you ever cleaned the engine? It's air cooled and more dirt you've got on it hotter it gets. Plus some brake pads get smelly when they're worn and get hot, to tell you, you should change them.
Start with the manual and try to set the carb right.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| Draco87 |
 Posted: 16:08 - 06 Oct 2013 Post subject: |
I can now confirm that the bike was running slightly lean, ive the carb back off and blown through it all turned out the pilot jet was blocked and adjusted this also adjusted the mixture screw the bike is also ticking over better later on I will take her out and see how she runs, the smell I think was actually coming from the over flow as the pipe was a little wet hopefully fixed that too Double checked spark and it was white at the end which idicates you were right showing signs it is running lean, but ill let you know on the progress  |
| Draco87 |
 Posted: 17:58 - 08 Oct 2013 Post subject: |
Just letting you know got the bike running right now she still bogs out a little which hopefully some fine tuning on the carb will fix  |
| RhynoCZ |
 Posted: 18:04 - 08 Oct 2013 Post subject: |
Good to hear you're getting there.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| 2wheelsteve |
 2wheelsteve Spanner Monkey
| RhynoCZ |
 Posted: 18:42 - 08 Oct 2013 Post subject: |
| 2wheelsteve wrote: | I recently removed my air box and replaced with air filter pods, the bike at first runs brilliant, starts first time often without choke but after about five miles winding the throttle off and the revs don't drop as they should, running hot as now too much air.
getting a dyno kit for the carbs though I heard with my bike turning up the fuel inlets 5 turns does the job.
Messing around with the carbs is something I hate as it rarely ends well but didn't realise changing to pods would cause so much of a problem.
either you have messed with the air filter/s or fiddling with the carb has caused your problem but since you said you messed with the air filter that would be the first and easiest to check, good luck. |
That could actually be a crack/air leak on the manifold between the carburetor and the head. To check that, spray something flamable on the rubber manifold while the engine runs, if the revs raise then you've got to get a new manifold I'm afraid.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| 2wheelsteve |
The last post was made 12 years, 363 days ago. Instead of replying here, would creating a new thread be more useful? |
