O-rings popped out, new chain?
goto10
PostPosted: 15:49 - 08 Oct 2013    Post subject: O-rings popped out, new chain? Reply with quote
As per title - I just cleaned my chain and noticed that a couple of O-rings have jumped out - does this mean the chain is soon to be scrap metal and needs to be changed soon?
Linked to the photo as well as embedded-
https://dl.dropboxusercontent.com/u/71877235/chain.jpg
doggone
PostPosted: 16:19 - 08 Oct 2013    Post subject: Reply with quote
I wouldn't set off on a tour of Europe, but if you keep it well lubed it might go for a while yet.
jimspeed
PostPosted: 23:23 - 08 Oct 2013    Post subject: Reply with quote
Been cleaning it with petrol? it looks like a solvent of some kind has softened the O rings and made em expand.
It will probly go a bit longer but its getting rainy season now so once the wet gets in there it will quickly wear out.
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
Mark65
PostPosted: 08:40 - 09 Oct 2013    Post subject: Reply with quote
Lube with 90w gear oil, get loads out of it yet. Thumbs Up
Islander
PostPosted: 09:20 - 09 Oct 2013    Post subject: Reply with quote
When you clean your chain, just use paraffin or diesel neither of these will damage O rings. The chain is perfectly usable but make sure you keep it well lubricated and clean and inspect it regularly. Thumbs Up
DrDonnyBrago
PostPosted: 10:20 - 09 Oct 2013    Post subject: Reply with quote
The chain looks clean and pretty much new, any reason this wouldn't be covered under the chain's warranty?
Islander
PostPosted: 10:59 - 09 Oct 2013    Post subject: Reply with quote
If it was damaged by the use of incorrect cleaning solvents... Whistle
Minty
PostPosted: 12:38 - 09 Oct 2013    Post subject: Reply with quote
What make is it, out of interest and how many miles'ish?
My fingers smell of your mum.
PostPosted: 13:07 - 09 Oct 2013    Post subject: Reply with quote
DID by the markings.
Minty
PostPosted: 14:17 - 09 Oct 2013    Post subject: Reply with quote
I've never had a problem with any of my DID's. Then again, outside of fresh from the box, none of my DID's have ever been that clean.
What does the OP clean with? Thinking
goto10
PostPosted: 14:50 - 09 Oct 2013    Post subject: Reply with quote
It is indeed a DID chain, I replaced it about 8k miles ago - I've never cleaned it using solvents before, I have a PDoiler running a decent amount of lube and I manually oil it with a rag once every month or so - this time I bought a new brush and cleaner to give it a really good going over - (Wurth Chain cleaner ( https://www.wurth.co.uk/product/brakechaincleaner ) - it's pretty aggressive stuff and brought the chain and sprocket up to looking like new - I also used a Tirox 360 chain brush (https://www.amazon.co.uk/Tirox-360-Motorcycle-Chain-Brush/dp/B00527IR7O) ) - although I noticed the Orings were out before I started cleaning, so they weren't to blame.
Ah well, I'll keep it well oiled and hopefully make it to the next service (5k ish) and get it changed then.
It's a shame because so far I haven't needed to adjust it whatsoever, so aside from the Orings it would've had a lot of life left in it.
nighthawk250
PostPosted: 18:25 - 09 Oct 2013    Post subject: Reply with quote
Please visit the NC forum site, where this is a known problem, a lot of chains (RK) were replaced on a recall, but the DID chains they used were still causing problems.
My own NC700X DID chain was getting stiff links, I have now sold that bike.
goto10
PostPosted: 22:51 - 09 Oct 2013    Post subject: Reply with quote
nighthawk250 wrote:
Please visit the NC forum site, where this is a known problem, a lot of chains (EK) were replaced on a recall, but the DID chains they used were still causing problems.
Funnily enough I had to replace the original DID chain because of stiff links - it was causing the chain to stretch and I ran out of adjustment in the end. I replaced it with a non-OEM chain (it's still a DID but it was meant to be a beefier chain) so it shouldn't be an NC700 specific issue on this one.
PostPosted: 22:53 - 09 Oct 2013    Post subject: Reply with quote
Send the pictures to DID, they are a reputable company you never know your luck!
goto10
PostPosted: 14:29 - 10 Oct 2013    Post subject: Reply with quote
I've just done that, along with the short history of the chain.
I suspect I'll get the 'sorry to hear that....but we're not doing anything' type of nicey nicey Email. As you say, it's worth a shot though.
nighthawk250
PostPosted: 18:58 - 10 Oct 2013    Post subject: Reply with quote
Japan may have a grease shortage, they use very little of it on new bikes.
goto10
PostPosted: 11:34 - 15 Oct 2013    Post subject: Reply with quote
Had a reply - so the chain (or lube/cleaning) wasn't to blame...
Reference your enquiry to DID in Japan
We do not know if the chain was fitted by yourself or by a dealer but we are able to advise what has caused this problem
The chain is running out of alignment between the rear wheel and the engine sprocket - this will cause the inner side plates to push against the rear sprocket on one side and jam up against the outer side plates When this happens the inner plates will crush the sealing rings and will no longer pivot causing the relevant links to become stiff
This can be observed in three ways - there will no longer be a clearance gap between the inner and outer side plates , the rear sprocket will show more wear on the flat surface of one side and the squashed sealing rings will only be on one side of the chain ( https://dl.dropboxusercontent.com/u/71877235/chain.jpg
We hope we have been of help to you
Regards
nighthawk250
PostPosted: 20:30 - 26 Oct 2013    Post subject: Reply with quote
I can understand that reply from DID, how do you know when the wheel is in line, you can't trust the graduations on the swing arm or counting the threads on the adjusters. Using a straight edge between the wheels is hit and miss and so is the string method.
Thankfully I solved my problem, sold the NC700S and brought a shaft drive bike.
Islander
PostPosted: 21:28 - 26 Oct 2013    Post subject: Reply with quote
You can check rear wheel alignment by measuring the distance between the centre of the swing arm pivot and the centre of the rear wheel spindle on each side of the bike. If the wheel is aligned correctly they should be equal.
totalllama82
PostPosted: 23:14 - 26 Oct 2013    Post subject: Reply with quote
+1 this. It's how I do my adjustment.
Gone: Haotian HT125-8 / Yamaha YZF 600R Thundercat / Kawasaki ZX9R C2
Current: Kawasaki ZZR 1400 A7F
YBR Ric
PostPosted: 10:23 - 27 Oct 2013    Post subject: Reply with quote
Two straight edges placed either side of two identically sized tyreless cast rims Smile
When you can't fit a piece of paper between any of the eight contact points WITH the rear wheel spindle correctly torqued, job done.
PS
Shaft drive alignment is only as good as the person fitting the shims.
nighthawk250
PostPosted: 20:37 - 21 Nov 2013    Post subject: Reply with quote
Thanks for the measuring tip between spindles, however a bit late for me and the NC, I brought a shaft drive bike, luxury.
The last post was made 12 years, 217 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.22 - MySQL Queries: 13 - Page Size: 116.73 Kb
