cleaning carbs
mudcow007
PostPosted: 14:44 - 09 Oct 2013    Post subject: cleaning carbs Reply with quote
right
i have been reading as much as i can about this but i haven't really found what im looking for
the last time i tried to start my bandit the floats seemed to be stuck open as it dropped shit loads of fuel out of the bottom of the bowls - an woudlnt start
i have removed the carbs but cant get the screws off the bowl to take a peek (i have replacement allen key headed bolts to replace the cheese screws) so i think i will dremel slots into the heads
when i get the bowls off
do i spray the funk out of each carb with cleaner (valve & needles)
or do i ideally need to get them ultrasonically cleaned?
ta very much
Suntan Sid
PostPosted: 16:06 - 09 Oct 2013    Post subject: Re: cleaning carbs Reply with quote
Spray & clean 'em, then blow them through with some compressed air!
Worked for me in the past!
Quote Me Happy
PostPosted: 16:17 - 09 Oct 2013    Post subject: Reply with quote
When you get the float bowls off you'll probably see the crud in there causing them to stick.
Just dismantle the float, check the tip of the needle valve isn't worn. Unscrew the jets and blow hard through them and then spray everything liberally with carb cleaner.
mudcow007
PostPosted: 18:06 - 09 Oct 2013    Post subject: Reply with quote
muchas gracias
im hoping to strip em tonight
fingers crossed i dont break anything
The last post was made 12 years, 359 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 39.84 Kb
