Car Clunking over bumps?
dransy
PostPosted: 09:19 - 10 Oct 2013    Post subject: Car Clunking over bumps? Reply with quote
When i go over bumps/potholes my car is making a loud clunking noise from the left front wheel.
im presuming its some kind of worn rubber?
Any ideas cheers marco!
Matt B
PostPosted: 09:30 - 10 Oct 2013    Post subject: Reply with quote
Might help if you mentioned what car it is....
dransy
PostPosted: 09:49 - 10 Oct 2013    Post subject: Reply with quote
Citroën xsara
Irn-Bru
PostPosted: 09:51 - 10 Oct 2013    Post subject: Reply with quote
Had an old fiat that did it (also on left side), needed a new shock and lower control arm.
Minty
PostPosted: 09:52 - 10 Oct 2013    Post subject: Reply with quote
My Focus did that and it turned out to be summat to do with the wishbones. Was under a £100 to fix so assume it was bush related etc.
My fingers smell of your mum.
dransy
PostPosted: 10:08 - 10 Oct 2013    Post subject: Reply with quote
Whats the best thing to do , should i just whip the wheel off and check anything rubbery?
Minty
PostPosted: 10:12 - 10 Oct 2013    Post subject: Reply with quote
Use something as a pry bar and check things for movement in directions it isn't meant to move.
PostPosted: 10:28 - 10 Oct 2013    Post subject: Reply with quote
Springs on Citroens should be considered as consumable parts. The C3 is particularly bad, but Mrs B's Xsara Picasso went through a few as well.
DrDonnyBrago
PostPosted: 10:30 - 10 Oct 2013    Post subject: Reply with quote
Ball joints and bushes are the most likely culprits. Rather than trying to replace just the dodgy ball joints/bushes, it tends to be much, much simpler to replace the whole part (i.e. a control arm etc).
Matt B
PostPosted: 11:33 - 10 Oct 2013    Post subject: Reply with quote
First thing to check on those is the Anti-Roll bar links. Whip em off (2 nuts) and give the joints a wiggle. I changed these on our Punto to cure the exact same thing.
Ordered from these guys on ebay and changed them in under an hour. At less than £15 it's worth a go.
https://www.ebay.co.uk/itm/Front-Anti-Roll-Bar-Link-Citroen-Xsara-Picasso-99-07-/280964982821
misscrabstick
PostPosted: 12:05 - 10 Oct 2013    Post subject: Reply with quote
really it could be anything and you need to jack it up and have a wobble to find any freeplay, top of my head wild guess though antiroll bar link.
RideLimousin
PostPosted: 13:14 - 10 Oct 2013    Post subject: Reply with quote
ARB drop link is a common fault on Xsaras.
Motorcycle Touring Holidays in France: Ridelimousin
See my ridelimousin renovation blog: https://ridelimousin.blogspot.fr
See my renovation thread: https://www.bikechatforums.com/viewtopic.php?t=244340
Nexus Icon
PostPosted: 13:30 - 10 Oct 2013    Post subject: Reply with quote
Don't forget to check the top rubber in the suspension turret under the bonnet.
Greetings from Shitsville!
tbourner
PostPosted: 13:59 - 10 Oct 2013    Post subject: Reply with quote
The easiest check first is to see if your shock is leaking any goo.
Trev, now a biker?
Looking for first big bike.
PostPosted: 14:50 - 10 Oct 2013    Post subject: Reply with quote
The same idiot-savante got his hands on other designs too, I can replace one on a C3 in about 15 minutes now. Brick Wall
Although now I'd either scrap it, or take it in to the local garage, with whom I've built a relationship of trust, and say "Fix it, mister."
nighthawk250
PostPosted: 19:02 - 10 Oct 2013    Post subject: Reply with quote
The road springs can snap. I've had 3 fitted so far on my Berlingo in 12 years, but I do put bikes inside it.
Nobby the Bastard
Harley Gaydar
PostPosted: 19:28 - 10 Oct 2013    Post subject: Reply with quote
Track rod end.
Triumph Sprint ST 1050
Cashhead
PostPosted: 21:04 - 10 Oct 2013    Post subject: Reply with quote
My guess would be the lower swing arm p-bush, I had a 306 which is basically the same and it ate them.
They're a bit of a pain to do, angle grind them off then hammer the new ones on.
Nobby the Bastard
Harley Gaydar
PostPosted: 21:33 - 10 Oct 2013    Post subject: Reply with quote
Jack the front wheel up under the engine (or other suitable mount point that ISN'T part of the suspension.)
Get someone to hold the steering wheel firmly.
Wiggle the wheel whilst grabbing the bottom and the top. When I say wiggle, yank the bastard as hard as you can. Pull/push from the topand then the bottom. if there is movement it's the bushes.
Do the same from side to side (obviously grabbing the left and right of the wheel.) If there is movement (make sure that the steering wheel doesn't move) it's the track rod end/ball joint (same thing).
If there is no or minimal movement look to see dampness on what you consider to be the suspension strut (there will be crap round it, but you will see light coloured dust, and dark coloured dust) if you see light and dark dust and an obvious line between the two, the damper is fucked.
Failing that check the spring. A break will be obvious.
I'm betting on a track rod end though.
PostPosted: 22:19 - 10 Oct 2013    Post subject: Reply with quote
How much?
I'll put my money on drop link to win, with broken spring to place.
Nobby the Bastard
Harley Gaydar
PostPosted: 22:26 - 10 Oct 2013    Post subject: Reply with quote
Rogerborg wrote:
How much?
It's always a track rod end.
Unless the car is 20 years old.
I'll bet you a 'fuck you, I was right' against your 'I'm wearing a flourescent jacket and am always right'
Deal?
PostPosted: 23:12 - 10 Oct 2013    Post subject: Reply with quote
I'll bet a posted hi-vis on drop link or spring. What are you putting on track rod end?
Nobby the Bastard
Harley Gaydar
PostPosted: 23:27 - 10 Oct 2013    Post subject: Reply with quote
A picture of me forcing my apradrvia back into my bell-end?
PostPosted: 23:31 - 10 Oct 2013    Post subject: Reply with quote
Well, the line's right here, if you want to step over it, as a man might.
Posted vi-vis vest against... Question
Nobby the Bastard
Harley Gaydar
PostPosted: 23:36 - 10 Oct 2013    Post subject: Reply with quote
I don't get it.
I've said that I will post a picture of ME forcing a METAL BAR through the end of my DICK (my other half decided that she preferred things 'natural' about 6 years ago) and you you post a picture of your profile picture?
The last post was made 12 years, 338 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.28 - MySQL Queries: 13 - Page Size: 127.54 Kb
