change brake fluid
stranger12
PostPosted: 15:05 - 10 Oct 2013    Post subject: change brake fluid Reply with quote
Good afternoon,
As per haynes manual, I would like to change my brake fluid. it is currently red, can i drain the system fully and then use brown color brake fluid in it ?
I guess you can remove all fluid from the caliper by pushing the pistons back while the brake pipe nut is off.
Then put it back together and bleed the system.
is that ok ?
I suppose mine is dot4
thanks
SV650 Red
R6 Red
Islander
PostPosted: 15:18 - 10 Oct 2013    Post subject: Reply with quote
To change the fluid, just bleed the old stuff through using the normal procedure (tube on bleed nipple, other end in jar with brake fluid covering the open end, crack open bleed nipple, squeeze lever, hold lever, tighten nipple - repeat until done) and topping the reservoir up with the new stuff as you go.
Brake fluid colour doesn't matter as long as the DOT rating is correct.
stranger12
PostPosted: 16:35 - 10 Oct 2013    Post subject: Reply with quote
no brown and yes in the garage for the past 2 years with the cap on so still should be ok as used it in my other bike.
SV650 Red
R6 Red
Islander
PostPosted: 16:43 - 10 Oct 2013    Post subject: Reply with quote
Sealed or just with the cap on?
Brake fluid is hygroscopic and your life may depend on your brakes working correctly. Brake fluid is also cheap.
stranger12
PostPosted: 17:18 - 10 Oct 2013    Post subject: Reply with quote
just cap on in my utility room. I did put it in my 125 and was ok . I can buy another one though just thought this may be wasted hence why wanted to use it again.
would it absorb water even if the cap is closed ? it is a 4 liter bottle
SV650 Red
R6 Red
DrDonnyBrago
PostPosted: 17:27 - 10 Oct 2013    Post subject: Reply with quote
I had a half empty, opened bottle and a sealed bottle on a shelf for about 18 months. The fluid in the opened bottle was darker than that in the sealed bottle when I finally needed brake fluid again.
Buying brake fluid in large bottles is pointless unless you have a few vehicles to do at once. It might be ok, but fortunately it is cheap enough to bin it and buy more anyway.
The last post was made 12 years, 354 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.89 - MySQL Queries: 13 - Page Size: 51.02 Kb
