gsx600f air leak?
rsuttons
PostPosted: 17:41 - 11 Oct 2013    Post subject: gsx600f air leak? Reply with quote
Hi i recently got a gsx 600f 96. Whitch wouldnt start but thanks to the helpfull people on here i got it to fire up Thumbs Up now the only problem is i can get. it to idel fine but wen i toutch the throttel it just dies, wen i do manage to rev it it take a few seconds to die down, also wen i put the choke on the revs shout up a fair bit. I fitted new exhaust gaskets cuz it was blowing and found one of the holes for the bolts rounded off (is much better with new gaskets but still blowing slightly) and wen i cleaned the carbs i had to cut one of the clamps off cuz the screw was rusted to f**k, could that be the problem? Too muck air gettin in throu it? And once again thanks for the help last time people.
Fizzer Thou
PostPosted: 18:05 - 11 Oct 2013    Post subject: Reply with quote
If you spray some WD40 around the inlet manifolds and the revs rise there is an air leak.
Always have a 'Plan B'
rsuttons
PostPosted: 18:36 - 11 Oct 2013    Post subject: Reply with quote
Is there any other way to test it cuz ware i live i cant just pop out to get some lol. Duno if i menshioned it but i neva put a nother clamp round the manafold.
rsuttons
PostPosted: 14:00 - 15 Oct 2013    Post subject: Reply with quote
Hi i got another jublie clip on the manifold thay all look fine ie no cracks or nothing tried with wd40 didnt seem to make much difference. Someone set to adjust fuel/air screw to 3 turns out, did that an the engine sounds a little better when ideling but still dies wen u toutch the throttle unless the choke is on. Need to get it sorted soon or it will have to go Crying or Very sad
CaNsA
PostPosted: 16:43 - 15 Oct 2013    Post subject: Re: gsx600f air leak? Reply with quote
yessss blud, i houp yu iz wel appy wiv yur noo weelz innit.
it sonds a pyar beest!
rsuttons
PostPosted: 17:59 - 15 Oct 2013    Post subject: Reply with quote
Wa u ona bout mate?
Marmalade
PostPosted: 18:06 - 15 Oct 2013    Post subject: Reply with quote
rsuttons wrote:
Wa u ona bout mate?
There are not many on here who speak fluent chav, try english.
CaNsA
PostPosted: 18:07 - 15 Oct 2013    Post subject: Reply with quote
rsuttons wrote:
Wa u ona bout mate?
yu iz telin me abart yor noo biek innit.
soz that i carnt ansa ane ov yor fings yu arksed but i wonted tu let yu no i iz hapi for yu innit
rsuttons
PostPosted: 18:53 - 15 Oct 2013    Post subject: Reply with quote
Sorry some of us do 13 hour shifts a day so dont have time to sit round a computer spelling properly
PostPosted: 18:59 - 15 Oct 2013    Post subject: Reply with quote
Take the tops off the carbs (be careful, there is probably a tiny O ring near one corner of each of them and you don't want to lose those) and check the condition of the diaphragms in them
CaNsA
PostPosted: 19:05 - 15 Oct 2013    Post subject: Reply with quote
Many BCF members work 13hr shifts, some even longer, and yet they have the time to spell correctly.
"TXT speak" really doesn't go down well here, or on any forum IMO.
Remember that how you post reflects upon you as a person.
If you want to be considered a chav/retard then please do continue in the fashion that you deem acceptable.
However, if you would like to be taken seriously by BCF then use 3 seconds to proof read your post and correct any mistakes prior to clicking the Submit button.
Marmalade
PostPosted: 19:08 - 15 Oct 2013    Post subject: Reply with quote
on a Friday i do Salisbury to Paris to Sheffield and back to Salisbury. It's 1000 miles and i can still spell properly that night when i go on the forum
rsuttons
PostPosted: 19:25 - 15 Oct 2013    Post subject: Reply with quote
Hi the carbs are all fine the sliders are set on 3rd notch down i dont think its the carbs, and sorry im far from a chav. I dont get many breaks so i got to message the wife whos ready to drop baby no2, try and get as much info as possible for when i get 5 mins to fix the bike and have a fag in the space of 10 minuets. Il try spelling properly then. And all you had to do was say instead of taking the piss
PostPosted: 19:37 - 15 Oct 2013    Post subject: Reply with quote
Also check the vacuum pipe to the fuel tap. The way it is running does sound like the symptoms of it being lean from an air leak.
bypass2
PostPosted: 19:51 - 15 Oct 2013    Post subject: Reply with quote
what about the diaphram in the petrol tap. is the petrol tap working properly a good petrol flow. have you cleaned the petrol tap.
rsuttons
PostPosted: 20:32 - 15 Oct 2013    Post subject: Reply with quote
Hi yeah i cleaned and checked the petrol tap and its all fine. Got a good flow of petrol. It does sound like an air leak i just dont know what could be causing it. Everything seems to be fine
bypass2
PostPosted: 21:20 - 15 Oct 2013    Post subject: Reply with quote
between the carbs and the cylinder head. the hardened rubber fitting. is there 4 caps are they good and 4 0 rings are they good maybe air leaks there. what about your air filter, can you show a picture around the carbs/fitting
rsuttons
PostPosted: 07:18 - 16 Oct 2013    Post subject: Reply with quote
Sorry i tried to upload a pic before, for some reason it wont let me. The inlet manafolds are fine and so is the o rings, could it just be the engines gone?
trevor saxe-coburg-gotha
PostPosted: 07:29 - 16 Oct 2013    Post subject: Reply with quote
https://i50.tinypic.com/35a3u3m.jpg
rsuttons This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
PostPosted: 09:48 - 16 Oct 2013    Post subject: Reply with quote
Say what you want about dad - but he's good in bed. Ask my brother.
The last post was made 13 years, 32 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 111.47 Kb
